Need remote control code for sony trinitron KV-28LS35U
Have a new remote control gadget. volume and mute buttons do not work
    Top Expert:
  • Televison & ... Master
  • 74,459 Answers
Hello
Here are some setup codes for Sony TV. Select one which will have maximum functionality. Check with all of them, and select one which can operated maximum function with tV. It is a trial process. If one stup code won't allow to some functions, try an other one, till you get maximum functions can be controlled with.
0128 0013 0002 0071 0380
002/ 006/ 071/ 128
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Posted on Feb 16, 2012
SOURCE: Sony TV Trinitron is on standby
standby light flashes tv wont turn on
Posted on Jun 01, 2009
SOURCE: sony trinitron tv kv-32s42 has no volume
Change the audio amplifier Ic
Posted on Nov 04, 2008
SOURCE: need remote codes for Sony trinitron kv-27s66
I have the same T V and i used the code 11100 and it worked . Give this a try and it should work. for T V Sony Bravia lcd
Posted on Apr 10, 2009
SOURCE: Verizon FIOS remote buttons all work except
I had the same problem with a Sony Trinitron KV-32FS320 32" TV. I reset the remote to factory default.
  • Press and hold STB
  • While holding STB, press OK
  • Release both keys, wait for device keys to blink twice
  • Press 9-0-0. The STB key will blink three times
Then I reprogrammed the TV control.
  • Turn your television on
  • Press STB to enter Set Top Box mode
  • Press and hold TV
  • While holding TV, press OK
  • Press 1-1-2-7. This is one of the Sony TV codes
After this, the volume + and - worked to control the TV.
  • Program any other devices, such as DVD using procedure similar to above.
I hope this works for you.
Posted on Jun 29, 2009
stonephoenix
  • 563 Answers
SOURCE: Sony FD Trinitron WEGA KV-32HS500...red standby light blinks 6 ti
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with
troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one
circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 11, 2009
Trinitron KV-27EXR15 speaker settings
If the mute function is set to OFF, there should be sound, as you increase the volume level. If there is no sound, check the speaker and audio output circuits.
Jul 11, 2013 | Televison & Video
Sony KV-13FS100 - channels cycling
you need to change the control board or the touch buttons
Apr 12, 2008 | Sony FD Trinitron WEGA KV-13FS100 13" TV
My remote worked fine, but suddenly won't work at all. TV is older Sony Wega 24" Trinitron (KV-24FS100). The satellite remote will change the channels, cause it's using the box, but it won't control...
Could be the IR receiver in the TV.
Make sure nothing is in front of the TV that would block the IR from receiving commands from the remote, I've seen customers put VHS tapes on the front of their TV that caused the remote to not to work.
Good luck
N Sabre
Nov 09, 2009 | Sony FD Trinitron WEGA KV-24FS100 24" TV
The Sony TV remote doesn't work (with good batteries).
NSE urc22b-12 please pin code forTV SONY model KV-A2921D
Sep 28, 2009 | Sony Televison & Video
RC codes for ge-24914-d to control sony Trinitron TV KV-27S42.
the codes for sony are 0128, 0013, 0002, 0071, 0380, or 0152
1) Make sure the tv is on.
2) Press and hold the set up button till the red light on the left hand corner stays on.
3) Then press tv then release quickly so that the red light flashes once. (its pretty quick so pay attention).
4) Then enter one of the four digit codes and the red light will turn off.
5) Then press channel up.
If it goes up u have the right code. If not start from the begining (holding the setup button down) and do the same steps for each of the codes, one of them should work if not u have to do a code search. Follow steps #1, 2, 3, and 5 but on step 5 press it repeatedly (for up to 300 times and it says that on the instruction manual) until the device can be controled. The red light blinks then stays lit
6) press and release mute to install the code. The light will go off.
Jun 27, 2009 | GE JASRM24912 Remote Control
Verizon FIOS remote buttons all work except Volume. Sony Trinitron WEGA remote has to be used. Volume is Fixed. Can something be done to control volume with the Verizon remote?
  • Press and hold TV
Apr 25, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega KV MOdel
hello, you may have a manual switch botton problem, check those volume control switch, do some test, check the board for some cold solder or short connection. ty
Nov 19, 2007 | Sony FD Trinitron WEGA KV-36FS320 36" TV
Tv remote codes
I have a Zenith universal remote that i want to program to a sony 27 inch Trinitron, what are the codes?
Nov 03, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Televison & Video Logo
176 people viewed this question
Top Televison & Video Experts
Electro Med Services...
