Technika tv clock slow
The clock on this TV has always ran slow losing 2 or 3 minutes every hour. I exchanged the first TV for this one because it showed the same problem. It's the clock used for on screen display, and switching the tv on at a preset time. I doubt it's adjustable but where is the chip and driver timer crystal- it may be worth changing. Or better yet, has anyone come across the problem and got a solution? thanks!!!!
  • 11 Answers
SOURCE: Sharp LC-46SB54U Keeps losing picture intermittantly
i believe your tv is getting overheated, possibly from dust getting onto the electronic components inside. or the inverter board for the lcd panel inside is going bad, alot of times it is the capacitors on the lcd inverter board going bad.
Posted on Jun 12, 2009
MNfisherman
  • 11896 Answers
SOURCE: tv shut down and wont power back up, but circuits stay powered up
Check to see that the fuse is good. If so, test power supply. It is common for these to go out..
Posted on Sep 13, 2009
  • 63 Answers
SOURCE: Hitachi 50" hd TV displaying black lines on screen
Sounds like your YBL-Y Buffer lower board is going out. There are 3 boards here. The Y buffer upper which controls the top half of the display, The Y buffer lower controls the bottom half and the Y-SUS main control those two boards. They work in unison. Usually if one goes out you have to replace all. You can also get lucky and just repalce the YBL and all may be well. Now if they are vertical lines up and down the OSD-On screen display, then this is indicitive on dry solder joints on the D, G E, F boards. Hope this helps...
Posted on Jun 30, 2010
SOURCE: toshiba regza 32hl67 losing its' picture and motion is slow
I have a toshiba regza 32hl67 LCD tv which is only 2 1/2 years old. The picture on this unit just started to go the other day (screen darkens but images are still visible and the motion/movement is very slow). I contacted Toshiba and they just said to unplug the tv for 3 minutes to reset the tv. This doesnt work. I am VERY upset with Toshiba, after paying $800 for a tv that only lasted 2 1/2 years. If anyone has had similar issues and know how to fix it, please let me know. Thanks
Posted on Feb 13, 2011
caroldon
  • 17130 Answers
SOURCE: I have a Technika 32" TV and it's been working
Check your Remote and see if this works. If not check these tips to test the remote;
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
Now there is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Jul 29, 2011
My 22" technika tv has
look through the menu for "clock" or "timer" functions...it must have a timer program activated.
Apr 13, 2011 | Televison & Video
The item is a technika cr-109ip ipod docking station and clock radio but it has not come with and instruction manual and we cannot figure out how to change the time, the alarm time can change but not the...
1)touch and hold both the M and E touch pads for at least 1 second to enter clock setting mode- the hour digits will now flash
2)set/change the hour by touching either of the the arrow touch pads on the top panel to increase or decrease the hour digit
3)when the hour is set correctly touch the E touch pad to confirm
4)the minute digit will now flash. Set the minutes by touching either arrow touch pad on the top panel to increase or decrease the minutes
5) when the minutes are set correctly touch the E touch pad to confirm
the clock is now set
Dec 25, 2010 | Audio Players & Recorders
HOW TO CHANGE THE TIME ON A Technika CR-109IP
2)set the hour by touching either of the the arrow touch pads on the top panel to increase or decrease the number
4)the minute digit will now flash. set the minutes by touching either arrow touch pad on the top panel to increase or decrease the minutes
Sep 19, 2010 | Audio Players & Recorders
How to connect my playstation 2 to Technika full HD led tv ?
i have a play station 2 slim and i am trying to wire it up to my technika tv and it only has the red and yellow insert in the tv and theres no white in the tv for the sound need help please.
Sep 07, 2010 | Sony PlayStation 2 (PS2) Console
Bose Wave Radio/CD clock running very slow. Now that I've moved it across the pacific ocean(US to NZ) the clock is suddenly running very slow, losing 10-15 minutes per hour while running on any...
My guess is that the clock in the radio is based off of the AC line frequency (not voltage). In the US the line frequency is 60hz (hertz). I'm guessing that the line frequency in NZ is 50hz, which would seem to explain that extreme amount of time loss. I would check with Bose, but I'm betting they make different 50hz models for export.
May 16, 2010 | Bose Wave Radio
Toshiba regza 32hl67 losing its' picture and motion is slow
Apr 26, 2010 | Televison & Video
Two clocks are set at 6am one clock gains 30 seconds every hour and the second clock loses 1 minute every hour. at what time will the faster clock be 30 minutes ahead of the second clock
Compute the difference in clock-speeds, namely 90 seconds per hour.
Convert the units of time: 30 minutes becomes 180 seconds.
So, divide 180 by 90 to get '2', namely 2 hours after the 6 o'clock "start" time, which makes it 8 PM.
P.S. There is at least one error in the above solution. If you truly understand the solution, make the necessary correction, and submit the corrected "homework" to your teacher.
Jan 07, 2010 | M2K Garfield: It's All About Math Math...
Mt atomic clock is always 2 hours slow no matter
How to Change the Time Zone
Press and hold the “-“ button for 3 seconds the letter P will appear where the seconds are than press and release the “-“ button until the correct letter for your time zone appears. The four time zones are P is Pacific, M is Mountain, C is Central and E is Eastern Time zone. Press the SET button to confirm or leave the setting to confirm and exit automatically.
Sep 26, 2009 | Acu-Rite Adagio Clock Radio
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
