Question about Home
I need replacement for my jet covers etc.for my thermasol whirlpool tub
brainyass
  • 242 Answers
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Posted on Oct 24, 2008
  • 14 Answers
SOURCE: Not all jets working on Hydrosystem Whirlpool Tub
I believe the below web site can help you with your problem. The jets are more then likely just turned off.
I hope this helps.
sanray
http://www.hydrosystem.com/hydro4/options/components/
Posted on Dec 27, 2008
PartsCenter
  • 125 Answers
SOURCE: my whirlpool bath tub has three jets that work & 3 jets that are
The suction IS the water intake. it takes the water from the tub into the pump and the water comes back out through the jets.
Posted on Feb 24, 2009
  • 74 Answers
SOURCE: How to Change White Water Whirlpool Tub Jet Hardware
First step is to remove the old hardware so you have something to compare it to. THere are two types/sizes of tub faucets on the market for deck mounted applications. If yours is mounted on the tub deck then it is a deck mounted application.
The faucet spread (distance between the threaded nipples on the bottom of the faucet) is going to be something close to 8" or it will be of variable distance. If the two handles and the spout are connected via hose then they are of variable length.
Bring the old faucet into the hardware store and compare it so you know you are getting the correct one. It is not hard but also not fun to have to adjust the holes in the tub deck to accommodate a different size.
AS for the suction.....I am assuming that you are referring to the inlet part o the pumping system and all of the equipment behind the tub. I always recommend that you use parts from the same manufacturer. It is extremely helpful to call them with all of the numbers you have to get a list of acceptable replacement parts.
Hope this helps.
Posted on Apr 27, 2009
  • 10865 Answers
I recommend that you consider spray painting the gold hardware with brushed nickel rusteoleum paint. IF you decide to go this route you must lightly abrade the gold surface with emery cloth then prime with rusteoleum primer, let that dry and the final coat will be the brushed nickel. I have done this and it turned out excellent. I get compliments on it.
Regarding your other issues, you will be happiest with white water parts. That being said, it is likely that locally procured parts might fit. I would get one set of parts and try them.
You will likely find the model number etc. on a plate in the mechanical compartment of the spa.
Posted on May 29, 2009
I have a whirlpool tub and need to find some caps to cover the jets. Not sure what brand tub is, sides are all covered. Can you help?
try a plumbers shop as it is a whirlpool tub
you state that it is a whirlpool tub then you say don't know what brand of tub it is
whirlpool is a brand name
any way the plumbers display of bathroom units and tubs will help you as the jets used are generic and not specific for the tub
Nov 16, 2015 | Whirlpool Home
I want to replace the 5 jet covers and suction cover for my Spurlin whirlpool tub. Where can I get replacement parts?
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: sales@uspartscenter.com
Mar 09, 2013 | Home
Hello, I don't have a problem, but more of a 'change' in mind. I have a maax whirlpool tub but really miss soaking in a tub with bubbles, or oils, or oatmeal treatments, etc. I feel I cannot do this...
your friend is correct. Actually the oils will not hurt the system either but not sure about Oatmeal in the tub. As long as the jets were not turned on with the Oatmeal thingy going you would be just fine.
Jan 13, 2011 | Maax Home
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
My lasco whirlpool tub leaks scum from the jets do they make covers to completely seal off the jets?
you need to use a cleaning solution to get the bacteria out of the plumbing lines. suggestions: Jet Cleaner
Oct 31, 2009 | Whirlpool Home
In our rental home there is a thermasol jacuzzi bath tub model 1100. How can I get a user manual?
Call Thermasol. Their website doesn't show this model:
West Coast:
800.776.0711
East Coast :
800.631.1601
Jul 09, 2009 | Home
Whirlpool tub, jets come on and won't shut off. No water in tub.
Is it a jetted tub, or a air bath tub with holes or jets in the floor? If it has holes or jets in the floor, the control box is bad and needs replaced. If it is a jetted tub, there may be a water level sensor, if so the sensor may be bad causing the tub to turn on.
Jun 13, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
Whripool covers
The likely hood of finding jet trim for a tub made that long ago is very remote. If you can email us pictures of what you have perhaps we can match them up for you. send photos to: sales@uspartscenter.com
US Parts Center
Jan 13, 2009 | Home
Home Logo
283 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
