Question about Samsung SCX-6345N Printer
Scx-6345n toner supply error
I bought a new Toner cartridge fro this printer and now I'm getting the error message: "Toner Supply Error" On the error report screen I get error code 06.004
  • sergio_giron
    sergio_giron Feb 15, 2012
    Do I need a new Firmware?
    Top Expert:
  • Samsung Master
  • 76,630 Answers
DID YOU RESET THE PRINTER TONER ERROR? CHECK YOUR USER GUIDE.
Posted on Feb 15, 2012
3 Suggested Answers
SOURCE: invalid toner
try to set your printers configurations fatory default 10. Maintenance > Of clear Of setting > Of all Of setting [OK] In the service menu (TECH MODE):
MENU> Of data Of setup > Of clear of count > Of clear Of all CNT
Posted on Jan 07, 2010
  • 525 Answers
SOURCE: samsung printer scx-4300 toner exhausted
replace toner cartridge
Posted on Jan 24, 2011
F2-40 ERROR
I am assuming your copier is a mono copier only & not full colour, if this is so then the error code refers to a toner supply fault. If you remove the toner cartridge & gently shake it side to side, turn the machine off & then on, refit the toner cartridge & check to see if the machine has reset. If the error is displayed again you may have to replace the toner cartridge with a new one. Again, powering the machine off & on should reset the error message.
Hope this helps.
Aug 13, 2014 | Sharp Office Equipment & Supplies
Printer gives error message "install toner"
Hi Steve,
The waste toner tank is the gray L-shaped container to the left of the cyan (blue) toner cartridge. Pull on the tab handle and either shake out the waste toner into a deep trash can (VERY messy) or outside into a trash can, then replace the old one if emptied or use a new one. Should be able to get it at a larger office supply store. Hope this helps.
Apr 02, 2014 | Samsung SCX-4725FN All-In-One Laser...
Printer Supply Error 10.1004
This kind of error are cause for a toner cartridge, install a new HP toner, a your problem go.
Jan 12, 2014 | HP LaserJet 2840 Printer
Toner supply error
hello sir...
when u face this problem then right side cover open and then close cover ur printer start again printing. otherwise open ur toner and again fix ur toner and then start ur printing
Dec 18, 2013 | Samsung SCX-6345N Printer
Invalid toner
Samsung strongly recommended original supplies as it has programmed sensor/fuse in it,
Dec 03, 2013 | Samsung SCX-4300 Monochrome Laser...
HOW CAN I SOLVE "THE TONER IS NOT SET INSERT THE TONER" ERROR ON MF3220 CANON, I've checked the sensor and cartridge gears.
TAke out the cartridge and unplug it and plug it back in and put the cartridge back in and see if thats the problem for you.
Dec 29, 2012 | Office Equipment & Supplies
Replaced cartridge still get error message
Clear the error, then hold the switch off then on.
Oct 14, 2012 | Canon imageRUNNER C2550 Color Copier
Independent-supply toner message
Treat the same as "Non-Genuine Toner". Caused by installing a refilled toner cartridge or taking out cartridge out, putting a new toner, and then putting the old one back in. Place a new toner in the machine, change SP5-051-001 to 1, and cycle power.
Jan 12, 2012 | Office Equipment & Supplies
I am getting the Replace Waste Toner error on my Ricoh CL3000. I have already emptied and cleaned the waste container, and blew off the section of the printer I install the waste bottle onto, but I'm...
not a solution - but a problem... i emptied the toner waste bottle in my MPW2400 and a new error message appears...says there is no toner and it keeps dumping toner from the new cartridge until it is coming out of every orifice of the machine. What is that about?
Sep 06, 2011 | Ricoh CL3000E Laser Printer
Samsung SCX-6345N Printer Logo
883 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
