OKI c5750 paper jam - Office Equipment & Supplies
  • 624 Answers
SOURCE: OKI C5100 printer repeated jams. Usually flashing the code of "380: paper jam" as the message.
You probably have already looked this up by just in case here is Okidatas instructions for clearing this jam: http://my.okidata.com/PP-C5100n.nsf?opendatabase. If you have already looked here and done this then I would suggest: -Open and close the rear cover. -Pull out and replace each of the toner cartridges. -Pull out the duplexer, ensure it is clear of jams and replace. -Pull out each of the paper trays (including the manual tray), ensure paper is installed correctly and replace. -Close the top cover. Per Okidata this has to be done last or else you will continue to see a jam error. -Try unplugging the printer and letting it set for a few minutes and retry. If that fails you might try purchasing a can of air from the computer store (about $3) and blow out the paper path to clear any paper or dust that may be blocking an optical sensor.
Posted on Dec 03, 2006
flopez
  • 161 Answers
SOURCE: Paper Jam in OKI B4300 Led Printer
This printer is designed with a dual toner/drum chamber. Do not separate these two parts. Upon opening the lid, you will find the toner/drum assembly right in front of you. Pick it up with both hands and pull straight up. After that, you should be able to take the jammed papers. Know this: once a paper is jammed, printing another paper will NEVER take the first out. Just make sure to remove the complete papers. If they break, make sure you extract all the pieces.
Posted on Sep 22, 2007
  • 260 Answers
SOURCE: oki 5250 380 paper jam
Sometimes you will find debris has fallen into the printer. Take off back to clean it out. Something as small as a staple can create this problem.
Posted on Apr 09, 2009
  • 44 Answers
SOURCE: oki c5250n paper jam
Unfortunately this may require and engineers visit. If you pull down the MP assembly by using the handle in the middle at the front of the printer you can then see a small "gearbox" at the right hand side of the transfer belt. This is common to feeds from both trays and could be worn. If you remove tray 1 and temporarily tape up the sensor arms to fool the printer into thinking it has a full tray installed, you can the test, by applying a little pressure to the feed roller, to see if it positively moves forward or if you are able to stop it turning. On a brighter note, you may just need new rollers instead of cleaning them.
Posted on Apr 18, 2009
  • 9 Answers
SOURCE: Oki C9300 - paper keeps
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Posted on Oct 31, 2009
How to clear a fake paper jam in oki B6250 printer
The usual cause of "fake" paper jams is a prior "real" paper jam. One of two things occurs.
  1. A small bit of paper tears off the jammed stock and hides from view, but keeps the printer jammed. These can be hard to find and remove, depending upon where they are.
  2. In the process of yanking the jammed paper out of the unit, the sensor(s) become damaged or misaligned and give false jam indications. This usually needs repair or replacement.
Jul 30, 2015 | OKI Office Equipment & Supplies
Reset drum oki c5750
I am impressed with the analyses and the solution to drum reset Paul Lorentze gave but I don't know if it is also applicable to Oki C5750. If so, I will like to know where to connect those two electrical wires that will be demonstrated and act like a fuse. Kindly give me an urgent answer to this please.
May 16, 2012 | Office Equipment & Supplies
Dear Sir(s) I have an OKI data OL400e the problem is "Message --Cover open" even i close it well Please advice Thanks
had the same problem. It is easily fixed.
On my printer a OKI C5750 is had to main covers, at the front (which you have to open to fix a paper jam) and a big cover on top (which you need to open to replace toners).
On the left is a piece of plastic which (when closed) presses on a switch.
When you open both covers, and close the top one, you can see it on the left when it comes down.
You can easily remove the error (only for a brief moment) by prushing the shining metal switch to the back.
But the problem is that one of the rollers is in a wrong position.
So just take a flat screwdriver and press on the bottom roller, and it will click and the problem will be gone when you close the covers.
Feb 11, 2010 | OKI OL 400e Led Printer
Close cover 310: cover open, but it isn't
Nov 23, 2009 | OKI C3400n Laser Printer
Oki 5250 380 paper jam
Apr 09, 2009 | OKI C5250n Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Oki b6200 paper jam
Have you checked to see if there is any paper jammed in the sensor, at the back in the 150-sheet feeder assembly, if not the paper could be stuck the 150-sheet assembly
Feb 26, 2009 | OKI B6200 Laser Printer
Oki c5200 paper jam
I used tweezers after I took every thing that could come out--out.
Feb 19, 2009 | OKI C5200n Laser Printer
Oki c3400 paper jam
Run Status Monitor and make sure it is really a paper jum that prevents printer from printing. It is very likely that another reason is in place. For instance - toner empty of change drum request. All of this causes the "Attention" LED to blink: it's not only paper jam that causes it.
Oct 07, 2008 | OKI C3400n Laser Printer
Aug 22, 2007 | OKI B4300 Led Printer
jasbo
jasbo
