Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Sometimes won't start spinning cycle
Sometimes, and becoming more frequent, the tub will not spin when it goes into the spin cycle (it will time through the cycle even without spinning). The motor is running and sounds normal, except no spinning. When I catch it, or reset it to the beginning of the spin cycle, I open the lid, rotate the tub a little, and nearly close the lid, enough to start the spin circuit. If it starts spinning, it will continue. If it doesn't, I rotate the tub some more and try again, usually having success the first or second try.
Any guess on the culprit?
  • drakesouth Oct 26, 2008
    The lid switch closes and the motor starts, but the tub doesn't spin. When I open the lid, the motor stops, I rotate the tub a bit, close the lid, the motor stops and the tub usually starts spinning.
    It's like the transmission has a "dead spot".
  • kilowattman3 Jan 03, 2009
    Mine does the same thing, It just sits there and hums. I can open the lid and shut it and it starts spinning every time. This is the second time I've seen this problem with a washing machine. I'm going to try jumping the lid switch out, but breaking and making the switch works everytime, so I realy don't think thats the problem. I think the motor is running but "something" is not releasing and allowing the tub to spin freely.
    Scholar:
  • 112 Answers
In most cases, this is caused by a faulty lid switch.
Posted on Oct 25, 2008
I have a Hitachi PAF-1260 PX washing machine. It goes through the wash cycle and drains the water but it does not spin. As a result, the clothes are still soaking wet. Can you help please. Thank you.
Just guessing but if you can select another programme that works such as rinse and spin or spin only the fault is likely to be with the controller but if the spin doesn't work on any programme I think the motor speed control is likely to be the culprit, though unfortunately these often share the same board.
One thought though, if the system thinks the tub still has water spinning cannot proceed. I am not sure what method modern machines use to tell the brain the state of water level in the tub but they used to use an air pressure sensor/switch connected to the tub by a length of small diameter hose that used to sometimes become blocked.
Jun 27, 2016 | Washing Machines
Kenmore washer needs two spin cycles
Have you checked the timer? Sometimes the little motor inside of it gets stuck or the concacts become burnt.
Good luck,
Marty
Jun 21, 2014 | Kenmore Washing Machines
Washer hums but will not fill or start/ spin has water pressure and tub seems to move freely the model #on tag LTF2140ES0
If it doesn't fill it won't start any other cycle unless you move it ahead yourself. If it hums I am thinking it is trying to fill. Sounds like the valve is turning on to let water in but it is not getting through. My washer has a screen where the hoses go on and sometimes the screen becomes plugging with scale. If that is ok then the solenoid must be coming on but the valve is stuck. Does neither hot or cold settings work? Please rate my answer so I am rewarded points for it.
Jan 27, 2012 | Frigidaire Washing Machines
Bosch nexxt essence won't spin
Either a blocked filter or worn carbon brushes
Oct 11, 2017 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washer sometimes halts after filling. Sometimes opening and closing the lid brings it back to life. Sometimes moving the dial brings it back to life. Sometimes nothing brings it back to life. The problem...
been a servicer for 18 years and had one yesterday that had me in a daze for a bit ,but finally figured it out... it was doing the same thing and if you pulled on the timer knob sometimes it would restart and sometimes you had to move it to the next cycle to get it working...it seemed to always happen on the spin cycle or rinse when the unit was suppose to start the tub operation... i finally determined it had bad contacts in the timer and had to replace it for the customer.... hope this helps you out... wish you luck
Feb 13, 2011 | Whirlpool Washing Machines
Spin cycle sometimes does not work
Yes - the timer is faulty and needs replacement
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Washing Machines
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
144 people viewed this question
Dan Webster
Dan Webster
Sal De
