Question about Samsung WEP250 AWEP250JBECXAR WEP 250 Bluetooth headset Black Worlds Smallest
WEP250 The LED indicator doesn't light up. Not even when power cable is connected. Is the whole thing broken?
2 Suggested Answers
frankgilbert
  • 613 Answers
SOURCE: when i press the power
That could mean a lens failure. Try to hook up adapter to computer if you haven't tried new batteries. Lens failure is quite common and it is best to spend a few bucks at a camera shop instead of trying to force it to work.
Posted on May 26, 2011
Tip
LCD TV TROUBLE SHOOTING
1.Do not power on .
1 .1 Please check AC cable if connect to AC plug. Is true the connector don't connect to AC plug. Please connect it.
2.2 Please check AC cable if connect to AC power. Is true the AC cable don't connect to AC power. Please connect it.
3.3 Please check power board of fuse if broken. If the F1 fuse is broken, Please pull out the AC cable from AC power. Please check AC L power and AC N ground by multimeter, The read number is infinite, the fuse is broke. Then look up power board if not burn out place. Is true it. Please change power board or be changed power board.
2. The power on switch of green extinguish.
2.1 The power of led(indicator light) is red light, To touch power on key when indicator light wink. Is true that the power DC output have somewhere short circuit. Check connector J39,J31 .If not connector direction is wrong. Or the mainboard somewhere of power short circuit.
FOR MORE CHECK THE LINK BELLOW
Electronics Equipment Repair Center
on Feb 14, 2015 | iLO Televison & Video
LED light doesn't light up on JL Audio XD 600/1
It could simply be a faulty or burnt out bulb, just find a small bulb at Ace Hardware or the similar, and replace it.
Aug 14, 2012 | Car Audio & Video
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
How to & where to connect Power led + - /power sw/reset sw/HDD led
Get the user manual here: User Guide
Chapter 2 Page 17.
The plugs just fit on to little pins in the bottom corner of the board.
If you connect them and hard drive indicator light on the front of the case does not come on then you need to swap the 2 connectors around.
It's an led which has to be connected the correct way to work.
Same goes for the power led on the front of the case.
Jan 26, 2012 | MSI MS-6378 Motherboard
When I turn on my 2 terabyte LaCie DD3US external hard drive, disk appears to rotate but I get a red light along with the blue, and clicking noises, and the drive's icon doesn't show on my iMac...
If the device doesn't show up in Mac System Profiler at all or as an unknown device:
The symptoms indicate there is a problem with the drive, how it is connected, or with the computer used for troubleshooting. The next best step is to change physical variables, and find a simpler problem than a broken product.
  • Change the data cable (USB, FireWire, Ethernet, etc.) A failure in the cable can cause this issue.
  • Change the external power supply or cable. If possible, obtain another power cabling to see if the problem is in that component. On drives that are powered via USB or Firewire, try using the included power sharing cable and connect it to another port.
  • Change the computer you are using. Computer problems can manifest themselves in many ways. Even if the computer appears to be working properly, this is a worthwhile test. Try it on a friend's computer and see if it works fine.
If the tests above don't help, it's possible that the drive was either dropped while running, had a hard drive 'head crash' or the circuitry inside the drive is fried.
Hope this helps!
Jun 20, 2011 | Computers & Internet
My father in-law just gave me a stereo system he wasnt using. It came with a technic suv98 amp. I hooked up everything but there is no sound coming out. The output indicators are not even showing...
Checked your amplifier connection, it supposed to be like this, amplifier has 2 audio connectors RED is Right White is Left channel, connectors cable should be connect to audio output of the receiver/DVD/CD etc.. and the other end of the cable connect to the input of the amplifier. hope this help thanks
Dec 04, 2010 | Technics SUV500 2-Channel Amplifier
Was using my Hp Pavilion dv7 laptop, suddenly turned off while the charger was plugged in. Turned back on then shut off again. Now my laptop wont even turn on, and there are no lights that even come on,...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 26, 2010 | HP Pavilion dv7-1245dx Notebook
Samsung WEP250 AWEP250JBECXAR WEP 250 Bluetooth headset Black Worlds Smallest Logo
37 people viewed this question
Top Samsung Radio Communications Experts
Michael Vincent Cruz
JP Services
JP Services
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
