Question about Cell Phones
What to do? help!
LG 32lc46 suddenly won't turn on anymore. The red light glows, but if i turn the tv on, the red light disappears and reappears after about 20 sec. no picture, sound or green light appears.
  • Fridtjof Darum Feb 16, 2012
    This is NOT a phone (dohh).. it's a TV of course..
    Problem Solver:
  • 17 Answers
I would like to be of more service, But might only be able to help a little. on the TV's motherboard(if you will) there are dry joints, when ever these over heat the TV will turn off, usually hitting it will make it work for a while because the dry joint moved back in to place, then over heats again and joint moves out of place. Not shore if this is the problem with yours but you can take it in to consideration...
Posted on Feb 16, 2012
  • Fridtjof Darum Feb 18, 2012
    Thanks for your help. i couldn't find any cracked dry joints or any out its place.
    But when I turned on the TV, I noticed a high frequency sound/beep coming from the power circuit board. Do you know if this is normal? might be from one of the transformers..
    Also the TV started malfunction whilst in standby. Don't know if that helps.
    Thanks again :)
I have problem a plasma TV LG 50PZ950-UA. The picture suddenly disappeared. Which board is malfunctioning?
There is no way to know what board until testing is done, my advice based on cost is to just replace the TV.
Jul 06, 2017 | LG Televison & Video
I have LG 32LC46-ZC TV. It suddenly stopped working, no picture, no sound. The LED blinks 5 times after turning on, but nothing else. Any suggestions?
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | LG Televison & Video
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
LG 32LH30 screen won't power up. Red light at bottom glows hi to low, but no picture. Unplugged and waited overnight, plugged in again, still no picture.
There is a way to tell if you have a bad board, or a bad panel.
1. Make the room dark and turn on the TV. Can you see it light up? If so, does it stay lit or turn right back off?
2. If the panel lights, but you have no picture, I would suspect the T-con. Some units now have the T-con incorporated with the main board, so you will need to check.
3. If you never get any light at all, then I would suspect the power supply.
4. If you only get light for a second or two, then you have a bad panel.
Apr 10, 2012 | LG 32LH30 32 in. LCD HDTV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
My LG 42LV4400 led tv won't turn on. Even the
Someone must open it and check voltages on the power supply board as the first step.
Depending on what is found boards may have to be ordered and installed to KNOW which will fix or not fix the set.
Mar 14, 2012 | LG Televison & Video
Cell Phones Logo
107 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
