Question about Dell Dimension 1100 PC Desktop
Dell Dimension 1100 PC Desktop - restore to factory settings
How do i set it back to factory settings without the restor cd?
    Genius:
  • Dell Master
  • 1,274 Answers
If it comes with windows 7 or vista you can try and tap f8 until you get a boot menu and there should be an option to repair your computer, if it's windows xp you're kinda screwed unless you can access the recovery partition.
Posted on Feb 16, 2012
  • 3940 Answers
SOURCE: Restore factory settings.
Here is the Dell tech support article for PC Restore to re-image the system to the factory settings.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?journalid=5A9D1CCAB17AB24BE040AE0AB5E12BFE&docid=325300
Posted on Nov 04, 2008
pamthegreek
  • 148 Answers
SOURCE: Dell 4600 desktop PC
If you are running Windows XP do a system restore. But BEWARE. You will lose everything you have installed since you started operating.
Posted on Jul 08, 2008
Jubert
  • 249 Answers
SOURCE: CD RESTORE DELL DIMENSION 1100
La mejor manera de hacer esto es reinstalar el sistema operativo entero del rasguño. No hay restablecimiento de la PC para este sistema ni pudo ser dañado muy probablemente ya si usted tenía uno. Para probar, presionar ALT+F11 cuando usted enciende la computadora en la insignia del dell. Si esto no trabaja, usted necesitará insertar el CD de la reinstalación de Windows en la impulsión y cambiar formato su sistema entero y comenzar del rasguño. Después eso. usted necesitará instalar los conductores y las utilidades para el sistema del dimensiono.
Posted on Mar 25, 2009
SOURCE: restoring my dell to factory settings
If you want to clear off all of your files and reset it to how it was when you first got it (Factory settings), hit CTRL + F12 when the computer is booting up.
See this link.
Posted on Jul 13, 2009
digritz
  • 530 Answers
SOURCE: how can i restore factory setting with my dell
Most newer computer do not include any media disc for the purpose of restoration. This is for a couple reasons first it cuts down on the cost of the computer and second it cut down on piracy or in other words taking those media discs and installing them on another computer.
However Dell as well as many other computer manufactures use another method that will allow you to restore your computer back to the way it came out of the box.
At the end I included a couple links.
The first one is your "Owner's Manual". You can find all these steps in this manual as well.
The second are other documents relating to your xps400.
Good Luck and I hope this helps.
"Happy (insert preference here)" and "Merry New Year"
To restore your PC to factory settings:
Warning: Anything you added to your system after you purchased it will be deleted. The only way to recover those files and programs are to back them up. I would advise you to get some CD/DVDs and back everything up just to be on the safe side.
  1. Turn on you computer. During the boot process, a blue bar with www.dell.com appears at the top of the screen.
  2. Immediately upon seeing the blue bar, press <Ctrl><F11>. (If you do not press <Ctrl><F11> in time, let the computer finish starting, and then restart the computer again). If you do not want to proceed with PC Restore, click Reboot in the following step
  3. On the next screen that appears, click Restore.
  4. On the next screen, click Confirm. The restore process takes approximately 6–10 minutes to complete.
  5. When prompted, click Finish to reboot the computer. NOTE: Do not manually shut down the computer. Click Finish and let the computer completely reboot.
  6. When prompted, click Yes. The computer restarts. Because the computer is restored to its original operating state, the screens that appear, such as the End User License Agreement, are the same ones that appeared the first time the computer was turned on.
  7. Click Next. The System Restore screen appears and the computer restarts.
  8. After the computer restarts, click OK.
http://support.dell.com/support/edocs/systems/xps400/om/WD741A03.pdf
http://support.dell.com/support/edocs/systems/dim9150/9150_XPS400/
Posted on Dec 21, 2009
Need to reset factory settings (which wipes everything out) on a Dell Dimension 1100 PC Desktop. I DO NOT need to restore to an earlier date. I do have a Windows CD to re-install--don't need ideas on how...
Follow the prompts on the os re-install disk and select to reformat the partition in use.
This will wipe everything. you will need to re-install all your drivers too.
Sep 27, 2013 | Dell Dimension 1100 PC Desktop
Restore Dell Dimension 2350 PC Desktop to factory settings
If you have not reinstalled you OS yet you can still set the pc to factory settings using a couple of keystrokes. Turn off you pc. When you turn on the pc hold CTRL button and tap F11 this will open the Dell pc restore option. Just follow the wizard and it will set the pc to factory settings. Warning, this will delete you files. If it does not work, you may need to do it the long way using the setup CD's that came with it.
Apr 19, 2011 | Dell Dimension 2350 PC Desktop
I need to restore the factory settings for my Dell Dimension 8770 and I do not have the cd. I do have a D: backup, but dont know how to restore from D drive. Can you help me restore to factory settings? ...
Telephone Dell, but first get the unique Dell asset-tag number from the decal on the back of the desktop. With that number, Dell will ship you a set of "System Restore" CD/DVD disks, via overnight courier.
Use those disks to reinstall Windows.
Sep 15, 2010 | Dell Dimension C521 PC Desktop
How do i restore my dell dimension c521 to the way
This is done 1 of three ways depending on how your restore information is stored. 1. After you push the power button start pushing the F8 key and when you get the option screen select restore to previous or restore to factory settings. This method works if your system has a special restore partition still. If you received System Restore Disk insert the CD in the CD player and reboot the system. It will boot from the CD and present the Restore menu for you to make a selection from. Your third choice is to select System restore from the system tools sub menu under the Accessories menu in your program list and chose to restore to factory settings.
Jul 23, 2010 | Dell Dimension C521 PC Desktop
How can i perofrm system restore to factory settings on a dell 9150
Have you tried prssinf the f11 key while rebooting to see if it brings up the Dell pc restore option? If that doesnt work If your dell came with restore Disks you need to set your cd/dvd drive as your boot drive and load your restore cd in that mode to do a restore.
Jun 10, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
How do i return my dell dimension 4300 to factory settings without cds
you can try a system restore but that may or may not dso it. you are going to need a Windows CD.
Jun 02, 2009 | Dell Dimension 4300S (Refurbished)...
Need factory setting
If your computer came with Restore CD's then boot to the CD and follow the onscreen prompts.
If you have a restore partiton Reboot the computer and press ALT +F11 at the Dell Boot Spash Screen. Follow the onscreen prompts.
Mar 30, 2009 | Dell Dimension E521 PC Desktop
Need to reboot my dell/windowsXP hard drive to factory settings
You have to put in the cd that came with your dell, then boot your computer. It will boot from the cd and give you an option to restore your factory condition. It will take around 1-2 hours for the process to complete.
Jan 29, 2009 | Dell Dimension 3000 PC Desktop
Dell Dimension 1100 PC Desktop Logo
810 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
