How to set time
Batteries fell out ... time reset to 00:00
  • lamurillo
    lamurillo Feb 15, 2012
    solar dual lcd clock xc0213
  • lamurillo
    how do I get this clock to work again
Flashing clock after dead battery?
The car manual will tell you how to reset the clock. Or contact the dealer OR
go to manufacturer web site for manual download.
Nov 18, 2015 | 2006 Renault Scenic 1.9
Why does nikon j1 clock reset each time the camera starts up
Yes, there is a separate battery for the clock and all of your saved settings that is not user replaceable. All Nikon 1 cameras are still in warranty because the camera only recently became available. I would phone Nikon USA's Service Department at (800) 645-6687 Monday through Friday from 7:00 a.m. to 8:00 p.m. and they will tell you how to proceed.
Jun 28, 2014 | Nikon 1 J1 Digital Camera
Reset to Dec 31
Try activating auto-update time in settings
Feb 08, 2014 | Samsung Star 3G GT-S5603 (16 GB) Cell...
Howard Miller Christopher Quartz mantel clock chime adjustment
Try pulling the batteries out, set the clock to 5:45 then put the batteries back in. Set the time to 6:00 and count how many times it strikes. If it strikes 6 then your good. If it strikes a different number say 5, take the batteries back out, and set the clock to 4:45 then put the batteries back it, set clock to 5 and count the strike. Most quartz clocks reset their chimes to 5:00 when new batteries are installed regardless of the time shown on the face. I hope this helps. Good Luck.
Nov 30, 2013 | Howard Miller Christopher Quartz Windsor...
Melnor 4 zone aqua timer dosent follow program
Water timers and Melnor timers last a year or two. They come with 1 year warranty for defects in workmanship.
Change batteries, reset timer if there is a reset protocol, buy another timer. Melnor, Orbit, are major brands. Gardena is not supported. Yardworks repackages other brands.
Copy following link for all watering and irrigation timers on market, with links to manuals for each brand:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Add a comment and say what you find.
Jun 20, 2013 | Aqua Hardware & Accessories
Want to use larger second hand and set other to zero. have small one working now and the larger one would work if i pressed the top button on side of watch now it wont do anything if i press button dont...
This watch is a chronograph. The true second hand is the one you mentioned that is currently running (what is called the subdial hand).
To use the chronograph hand,
1) Press the button at the 2:00 location to start timing.
2) Press the button at the 2:00 location to stop timing.
3) Press the button at the 4:00 position to reset the chronograph hand(s) to zero.
To reset the chronograph hands to zero, set the crown to either click position one (usually date setting) or two (usually time setting), and use each button to test which subdial hand it will zero out.
Usually it is the first crown click position, and pressing the 2:00 or 4:00 button to zero out.
Warning: Leaving the chronograph function running will drain your watch battery much faster than using the standard second hand, as it is a complication meant for the purpose of timing an activity or other event.
If this does not zero your watch, you must either send it back to Michele, or visit your nearest Certified Master Horologist to assess the issue, as the movement may have a defect.
Feb 25, 2011 | Michele Coquette 71-800-CL-301-72 Wrist...
How do you set the clock nissa versa 08
Clock set
If the clock is not displayed with the ignition
switch in the ACC or ON position, you need to
select the CLK-ON mode. Press the MENU button
repeatedly until CLK-OFF mode is displayed.
Use the TUNE/SEEK button to enable CLK-ON
mode.
1. Press the MENU button repeatedly until
CLK-ON mode appears.
2. Press the MENU button again, the time will
start flashing.
3. Press the TUNE/SEEK button
or to adjust the hour.
4. Press the MENU button again; the display
will switch to the minute adjustment mode.
5. The minutes will start flashing. Press
TUNE/SEEK button or to adjust
the minutes.
6. Press the MENU button again to exit the
clock set mode.
The display will return to the regular clock display
after 10 seconds, or press the MENU button
again to return to the regular clock display.
Resetting the time
Hold the MENU button down and then press the
TUNE/SEEK button, the time will reset as follows:
c If the displayed minutes before the reset are
in the range of :00 - :29, the hour displayed
before the reset will stay the same and the
minutes will be reset to :00.
in the range of :30 - :59, the hour displayed
before the reset will advance by one hour
and the minutes will be reset to :00.
For example, if the MENU button and the
TUNE/SEEK button are pressed while the time
displayed is between 8:00 and 8:29, the display
will be reset to 8:00. If the buttons were pressed
while the time was between 8:30 and 8:59, the
display will be reset to 9:00. At the same time the
display will return to the audio.
Nov 11, 2008 | 2008 Nissan Versa
I have a Canon A430 Powershot digital camera, when new batteries are inserted they lose their charge in a few minutes. Recently I downloaded a number of images from the camera to my computer..since then...
What kind of batteries are you using? Try regular AA Duracell Coppertop Batteries. I have a Canon A560 and I have the best luck with them. Forget the rechargeable they are hopeless. Mine rechargeable don't hold a charge.
You can also try wiping the battery terminals well with a dry cloth. The terminals may be dirty from fingerprints or dirt.
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
Give them a call. Unfortunately, I cannot find any support for your camera.
The only other thing I can think of is a glitch and you may want to reset to factory settings.
RESETTING SETTINGS TO THEIR DEFAULT VALUES
--SET UP MEMNU
--RESET ALL
--OK
Settings cannot be reset when the camera is connect to a computer or printer
Good luck and could you please rate this. Thanks so much!
Mar 27, 2008 | Cameras
43 people viewed this question
 Grubhead
Grubhead
