Question about Sony PlayStation Video Game Consoles & Games
99 sebring xli stoppd running while driving and wont start
Stopped running while driving and now won't start. It will light up but crank but won't roll over
    Top Expert:
  • 5,332 Answers
Three things you should check for.
Spark, fuel pressure, and timing belt.
Spark is easy enough. Pull a plug wires and using a spark tester see if there is spark.
fuel pressure will require a fuel gauge. You can try a couple of shots of carb spray in the throttle body to see if the car starts. If it does than we know we have spark and this is a fuel issue.
Timing belt, AN ENGINE SIZE WOULD HELP, but basically you should be able to remove a couple of bolts from the top of the timing cover and see if the belt is turning. A broken timing belt will usually cause the engine to sound like it is turning over faster than normal.
Let me know what you find with the above and I'll see what I can do to help.
Don't forget to post an engine size as well.
Posted on Feb 15, 2012
vortash
  • 431 Answers
SOURCE: have a 99 sebring just changed battery and car wonk crank
Hi I am Vortash when you turn the key is there a sound from the engine a clicking noise this would be the pre engaged starter motor solenoid trying to engage if you do then the starter motor may be jammed or faulty or possibly has a bad earth check all your body earthing straps .. ( the lights would work as they dont take much drain but the amperage of the starter motor wouldnt ) .
If after checking the earths you dont hear this then I would suspect that the ignition switch is at fault and the starter motor contacts in the switch have burned out or the starter relay hope this is of help regards vortash
Posted on Jul 22, 2009
bhowell786
  • 88 Answers
SOURCE: xterra will not turn on.
Do you get any dash lights when you turn the key on? If not, you could just have a dead battery.
Posted on May 27, 2011
  • 33 Answers
SOURCE: manual window isn't connected to
inside the door is a winder, pull off the face of the door and check if the glass is coonnected with the winder. The glass is connected to the winder with silicone.
Posted on May 29, 2011
  • 14036 Answers
SOURCE: I HAVE A 99 ALERO OLDS.4CYL.& IT WON'T PASS SMOG
IF DECELERATION FUEL REDUCTION SYSTEM IS NOT OPERATING, FUEL ECONOMY WILL BE REDUCED WHILE HC AND CO EMISSIONS ARE INCREASD.SEE ON MANY ENGINES WITH DECELERATION FUEL REDUCTION SYSTEMS THE PCM STOPS GROUNDING THE INJECTORS IN A SPECIFIC RPM, DURING DECELERATION.
Posted on Jun 24, 2011
  • 183 Answers
SOURCE: my 97 sebring xli 2.5l
Probably the ECM. Lot's of checks to make to see if that is it. Does it try to fire up if ether is squirted in the intake? Is the security light on? Does the dash say "No Bus" Does the fuel pump come on?
If it has a security system don't bother with a junk yard ECM, the car will kill it. Run for 4 seconds and die.
Place in south Florida specializes in Dodge Reman ECM's guaranteed to work with the security system.
Posted on Sep 12, 2011
My 96 sebring coupe xli wont crank or start how do i check the starter relay
Is the transmission (automatic assumed) in "P"? If manual, are you holding the clutch pedal down?
Do you have functioning headlights? Does the starter TRY to crank the engine but not have enough power to do it? If so, check all your ground connections. Is the battery discharged or fully charged?
Put a voltmeter on the battery and have someone try to start the car. Watch the battery voltage when they turn the key - it should NOT drop below 9V. If it does, it's discharged or internally damaged.
It may be a pure coincidence - all batteries get to a certain point after which they can't be used any more. You may have just lost one cell in the battery. Or... when you changed the water pump, you may have disturbed something you shouldn't have disturbed.
Jul 29, 2014 | 1996 Chrysler Sebring
Just stopped running,won't restart
does it crank? does the fuel pump go on when you turn the key to the start position?are there any codes?
Jan 30, 2013 | 2004 Chrysler Sebring
The Electronic throttle control light is on. Car will crank but won't start anymore. No check engine light is on. 2007 Chrysler Sebring 2.4L
You will need to have the electronic engine control module scanned for fault codes, there will be a code even if thelight is not on.
Jun 26, 2012 | 2007 Chrysler Sebring 2.4
2005 silverado cranks but won't start
I had the same problem . on my 2002 silverado it turned to be the fuel pump failed because the fuel filter was clogged. I did the work myself could saved myself 219.00 and labor if I replaced a 7.00 $ Filter .
Apr 25, 2012 | Cars & Trucks
My interior lights stopped working, my radio won't come on, and my locks stopped working when the car is off I have to lock them manually. Also when I'm driving at night my brake and battery lights bl
Assuming you have checked all fuses, the next step would be to locate central grounding points (there may be several) and remove and clean battery terminals and the remote ends of the cables at their attachment points.Locating some of these may be easier with a manual covering the electrical system of the car:
Sebring manual
When removing battery cables, always start with the negative cable first and reattaching it last.
Dec 08, 2011 | 2001 Chrysler Sebring
My 97 sebring xli 2.5l v6 wont fire,timing belt is intact,have spark,have fuel,but wont fire,any suggestions?
Sep 12, 2011 | 1997 Chrysler Sebring
My 2000 Chrysler Sebring stops running. After a few minutes it will start again and run fine. This situation just started happenning a few months ago and is increasing in frequency
is the check engine light on??
i've done a few that had no light/codes.the most common problems are crank or cam sensor failures. really need to check when car stalls.
replacing crank sensor 6 mths ago & car has'nt had a problem. if you search these sensor on the sebring you'll find alot of info.
Jul 12, 2011 | 2000 Chrysler Sebring
Video Game Consoles & Games Logo
49 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
