Question about Garden
Engine knocking Engine all of a sudden making loud knocking noise. It still runs ok but obviously something wrong
    Sergeant:
  • 316 Answers
Hello sir, check to see if the engine is over full on oil and gas in the engine .this will make starter drag eventually ruining starter.this is the only thing i can think of other than engine having high compression except valves not opening and the pressure relief valve not working,or engine low on oil 30 WT, is also important to keep good oil in engine and full. the solenoids under the carburetor will go bad,and cause flooding, if you have one. make sure you keep battery charged. if it is follow these directions ,well it is a simple fix,but a lot to correct problem, parts needed,1 new spark plug,1 new solenoid,1 quart of 30wt oil,1 pan to catch old oil in. tools needed,1 spark plug wrench,1,7/16 or 1/2 or 9/16 open wrench,pen&paper. ok, empty fuel tank or clamp off fuel line,make a drawing as how the wires are connected to the solenoid,white & black wires,unplug wire fittings,remove solenoid, in stall new solenoid,plug wires in. now drain oil & gas out of engine,remove old spark plug,important so follow directions,after oil is drained plug is out crank engine so to clean out cylender of excess oil & gas,it would be a good ideal to let oil drain for a while. add oil & spark plug,engine will smoke for a while but should clear up.when you go to the parts store you will need engine horse power,engine brand,mobel number,type number,parts should cost around 50.00. including everything you need,check oil often you can put a inline fuel shutoff in the fuel line about $5.00, or replace solenoids for $40.00.hope this helps,don't forget the 4 thumbs up,any comments welcome,thank you,,after you need to check this, ``
Posted on Feb 20, 2012
Why is my 2002 Mazda Tribute making a loud knocking noise when I start it
loud knock and for how long
is it a diesel or petrol
broken engine mount
loud tapping is tappets ..should go away once oil reaches top of motor
water pump or bearing something running off drive belts
if high milage engine
a loud knock at engine revolution or half revolution
big end bearings or
piston slap or gudgeon wear
Oct 07, 2016 | Mazda Cars & Trucks
Knocking rattling noise from engine appeared while driving loss lil power running but loud knocking in engine
You didnt state vehicle however if the engine knocks the knock sensor will back off the timing thinking its detination not an actual knock if its knocking loudly stop driving it, something is going to let loose
Oct 06, 2015 | Cars & Trucks
F22a engine produces strange noise most obvious at 2000 rpm, what could the problem be?
Without a general description of what the noice sounds like, squeal as compared to knocking, it is impossible to help you. Engines make a lot of different noises, so try and help by describing noise. I would suspect it is belt related, or tension pulley related as these are RPM variable noises, belts tend to slip when you accelerate and can be quite loud with a serpentine belt as example.
CERACOAT-NANOTECH.com
May 14, 2015 | 1996 Honda Accord
Loud knocking as engine is running
if is realy loud is coud be the piston the engine needs to be checked bt am 80% is that
Jan 08, 2013 | 2000 Ford Excursion
My truck is making a loud knocking sound when I drive it
first you need to check the oil level (with engine off) if level is good than listen to engine knock with the hood open make sure it is coming from the engine and not the belt tensioner or something external on the engine,if nothing is found than engine will need to be repaired best thing is to bring it to a local shop for evaluation.best not to drive it much longer like this ,it could leave you stranded.
Nov 25, 2010 | 1994 Isuzu Trooper
Would there be a knocking in the motor and would my van be sluggish when stopped if there was something wrong with the water pump?
if something wrong with water pump vehicle can and will overheat which can cause minor to extreme motor damage such as blown head gasket --warped heads--****rod knock****seized engine loud knocking usually means lower end damage to engine which can be from engine rebuild to engine replacement
Feb 23, 2010 | 2000 Dodge Caravan
The engine is making a really loud knocking noise and the oil light is on. it also smells like something is burning or running hot
Doesn't sound good. Check oil level. Also check for metal in the oil once you pull the dipstick. A loud knocking noise is a sign of a blown engine may be you spun a rod in which case you would need engine replacement or rebuild
Oct 23, 2009 | 2001 Dodge Stratus
Whining noise while accelerating in 1st gear
Check the idler and tensioner pullys for your serpentine belt. I suspect the whining noise heard earlier was due to the fact one was getting a bit stiff or rough turning. When you gave it that extra fuel, the sudden load may have finished it off. Sometimes they lock up, and sometimes they fall apart. Check those items first.
Aug 26, 2009 | 2006 Audi A3
MAKING NOISE AT CENTER OF TOP ENGINE UNDER MANIFOLD LOUD NOISE
Is it a ticking or knocking noise? or does it sound like something is leaking could be a bad manifold gasket which would be better than a ticking or knocking.
Jul 08, 2009 | 2005 Jaguar XJ-Series
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
