Question about Nintendo DS Lite Console
I spilt a bit of soap and water on my ds lite
My ds was dirty so i wiped it with wet tissue with a bit of soap on it and it whent in side the button what do i do
    Sergeant:
  • 199 Answers
You'll need to open your ds and clean it with alcohol and a small brush. this should help your system go back to normal, you should do it ASAP as it can built corrosion on your system.
Here is a link on where to open your system: http://www.techrepublic.com/photos/cracking-open-the-nintendo-ds-lite/171256
Thanks
1RepairStop.com
Posted on Feb 15, 2012
  • 35 Answers
SOURCE: DS LITE GOT WET
I dont think so. Srry, but u gotta get a new one :(
Posted on Dec 27, 2007
  • 63 Answers
SOURCE: how to open ds lite
There are two cross head screws under the rubber feet at the slot1 side, there are two tri-wing screws on the left (stylus side) and inside the battery cover (under the battery) there is a cross head screw at the top and a tri-wing screw at the bottom (in the corner).
The screen is held together by 4 screws under the ruber pads and then the outer case slides up about 5mm and then pulls clear.
Take great care when putting it all back together to line up the volume and power switches and plastics as the power switch breaks quite easily.
HTH
Posted on Mar 02, 2008
SOURCE: nintendo ds lite
open it up and clean out the ds
Posted on Apr 12, 2008
  • 103 Answers
SOURCE: Nintendo DS not reading games
Looks like a defective Slot1. DS Games are using different pin-connectors in Slot1. There is a possibility that one of more connector-pins for using DS games are not making contact
Posted on Sep 22, 2008
  • 3 Answers
SOURCE: Nintendo DS Lite is not working when i put games
Take a small flashlight and look in the game slot if any of the pins are bent even slightly they will not make good contact with the game. If they all look straight then it may be dirt down in there blow it out or take an old cartridge and insert it in and out about five times and this might polish the pins.
Posted on Oct 10, 2009
The suction cups on my oil rubbed bronze soap dish are no longer tight enough to sick to the wall of my shower. it's been fine for over two years until now. can you buy new suction pieces or do i have...
Sometimes this happens when the suction cups are somewhat dirty.
Wet the suction cups, leave for some time, and wipe with a clean cloth until the suction side is shiny. If it is not shiny at places that suggest those places are not cleaned thoroughly. Wet again and wipe again until you get a shiny surface.
Check the wall where it was attached. If you see any patches wet the area and wipe with a clean cloth.
You can apply just a tad bit of oil (I use coconut oil) to the suction cups.
Try this - and let us know the results.
Thanks for using FixYa!
Sep 05, 2011 | Allied Brass Soap Dish - 432.ORB - Oil...
Tip
How to remove wet TAR from your vehicle
If you drive through WET TAR on the road, and you notice some splatters on the side of your car. It can be very difficult to remove them.
But make use of some BRASSO......just put a little bit on a damp cloth and wipe away the WET TAR from your vehicle. Wash with water and soap afterwards.
on Sep 28, 2017 | Miscellaneous
Tip
Laptop or Monitor Cleaning
LCD and plasma screens have a anti-glare coating or anti-reflective coating. This is so any bright light doesn't reflect and wash out the picture. It does help but it also makes cleaning the screen a bit of a problem.
As this is a coating on glass it is actually possible to clean t off by using the wrong cleaner. There are great glass cleaners out there but most are chemically based and too aggressive. In other words they attack the coating.
So what do you use? Paper towels, a drop of dish washing or liquid soap and water. And you need to use a bit of a technique or you will see smears or smudges on the screen.
You need to get two sheets of paper towels. One is your dry wipe. Wet one with water. Then add a drop of liquid soap or detergent. Give it a couple of gentle squeezes to distribute the soap. Then give it a bit harder one to get rid of excess water. Depending on the coating you may want a second piece that has only water and just damp not wet.
Now we clean the screen. First take the soapy towel and wipe down the screen getting it wet. You don't want running water just enough to wet the screen. If you have the soap right you will just see the odd bubble. Once you have the screen wet, wait about 30 seconds and now scrub it using the soapy towel with a circular motion. If there is anything on the screen it should come off. If something is stubborn just keep scrubbing it or use a fingernail to scratch it off and wipe with the soapy after.
Now we need to get the soap off. If the screen dries and has streaks you may need to use the wet un-soaped towel to wipe/rinse of the soap before drying. To dry the screen we want to use the dry towel and use large circular motions. Go over it once and turn it over so the dry side is being used. Keep using those big round motions and at the same time ease up of how hard you push the towel. The idea is to have little pressure on the towel as you finish. That's the trick to getting it streak free.
This takes a minute to do but lets you safely clean your display without damaging the coatings. It also works on any glass surface.
on Jul 07, 2010 | Computers & Internet
Water spilt on it
Take out the battery. Put the DS Lite in a ziplock bag full of rice. Leave it overnight. The rice should absorb the water.
Please remember to rate my solution to show your appreciation.
Amardeep
For more tips visit my blog at http://thegeektweet.wordpress.com
May 28, 2011 | Nintendo DS Lite Console
Ds not Reading games
1 make sure to put it in the right way
or if the ds game is dirty broken or has water ion it it wont read so take tissue and rub the gold part with water then take a dry one and wipe it off
Feb 10, 2010 | Nintendo DS Lite
Tip
How to clean your screen (TV-Laptop-Monitor)
on Apr 16, 2010 | Televison & Video
Saved data could not be read?
This just happened to me. I used a tissue and gently wiped out the slot- then blew out any dust/debris with my breath. Gave a gentle wipe to the pins on the game card as well with a tissue. Restarted a few times and now games are working fine.
Apr 07, 2009 | Nintendo DS Lite
Wet DS lite. Top Screen now blank in one corner
you need a new top srceen, you can get these screens on ebay for about 20.00
Let me know if this helps!!
Jan 28, 2009 | Nintendo DS Lite Console
DS lite Top screen got wet this morning
Go into the ds and dry off the top screen it does work.
DS Lite shuts off when I press the B button, and at random.
that happens when i click my laptop buttons too hard... i think u should try to wet it a bit and dont press TOO hard
Sep 30, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
41 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
