Question about HP Compaq WF1907 Monitor
Using a Compaq WF1907 monitor with a Playstation3
I have been successful connecting my Playstation3 to a Compaq WF1907 monitor. I am using a HDMI to DVI cable and the picture comes in clear with a higher definition than a standard tv.
One problem...... no sound. Isn't the DVI port supposed to to transfer both picture and sound signals? If my PC connections to VGA and speakers are still attached will this affect the sound signal even with the PC turned off?
Any suggestions for rectifying this problem would be greatly appreciated.
No. HDMI transfers picture and sound, but DVI does not. You need a audio line as well.
Posted on Mar 30, 2009
Compaq WF1907 19" monitor backlights are on, but
Check the monitor on another computer to verify if using correct setting for this monitor will allow a clear image to be displayed.
In windows 7, the monitor should be detected and installed automatically.
What version of windows are you using?
Dec 25, 2010 | HP Compaq WF1907 Monitor
My monitor is making a humming noise from the speakers , because i use other speakers (not the ones on the monitor) this is a problem what could cause this
It is probably a problem with the audio jack, try using other speakers or connect another audio source to your monitor. If the problem persists, you better contact your vendor for a faulty product
Jun 19, 2009 | HP Compaq WF1907 Monitor
Cannot install: HP Compaq WF1907 Wide LCD Monitor Update.
I found in the folder of Hp the file that does the " UPDATES".
So, thanks for the offer to help me, but all is well now with me and the Hp UPDATES.
Regards
Frank
May 19, 2009 | HP Compaq WF1907 Monitor
No image
This monitor series( HP Compaq WF1907) seem to have a inherent problem with the sleep mode control circuit. You should take this unit into the service center for repair. Hope this helps.
Apr 01, 2009 | HP Compaq WF1907 Monitor
Can't successfully download the software driver for hp w1907 moni
Hi! Here's link for your problem...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3351967&lc=en&cc=us&dlc=en&lang=en&cc=us
Just select the operating system you're in and click the link that says Drivers!
If you're using windows Xp, click on the link below:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39951.exe
Hope this helps!
Mar 14, 2009 | HP Compaq WF1907 Monitor
We have everything connected in our monitor but for some reason you cant hear any sound whatsoever. We have a Compaq WF1907 monitor
Hi there!
I could post the whole solution here but I found a link that could direct you to an illustrated solution:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01289551&lc=en&dlc=sk&cc=sk&lang=sk&product=3351970#N367
I Hope this helps!
Feb 18, 2009 | HP Compaq WF1907 Monitor
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
HP Compaq WF1907 Monitor Logo
207 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
