Question about Breville Gourmet Rice Cooker - Stainless-Steel
My rice cooker just stop working in less than one month after using it what could be the problem?
I used it for less than a month and now it longer switches on, I tried everythingincluding trying a different cable
  • 3 Answers
If its less than a month. I would take it back to the store i bought it from and swap it for a new one
Posted on Feb 15, 2012
Completely stopped working. Plugged it in and the lights wont come on and it doesnt cook rice. Had it maybe right at a year.
Had mine 3 months and mine has done the same thing THREE times. ...with THREE different cookers!
Jun 10, 2011 | Rival RC61 6-Cup Rice Cooker
How much rice to haw much water
Use 1.5 to 2 cups of water per cup of white rice. Use less for short grain rice. Use 2 cups of water per cup of brown rice.
Mar 29, 2011 | Black & Decker Black Decker HS1000 8Cup...
My Toastess 20-cup rice cooker stopped working right in the middle of a cycle. I tried a different outlet, and it still doesn't heat up, and doesn't even turn on. The unit is 6 months old.
You have a bad connection because the wiring has been bent around too much and has failed...this will not be repairable and you need to replace the cooker...
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
How much Rice and Water go in the Cooker
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
Jul 05, 2010 | Toastess TRC-18 20-Cup Rice Cooker
The rice dries out in the "keep warm" mode
You have a strange problem. I use my rice cooker often and the only thing that I can think of that may be casing your problem is if the steam vent is clogged. A clogged vent would cause the steam to condense and run to the bottom.
With the machine empty of food, you could try pouring hot water through the vent to see if this clears any clogs. If it does not, it could be other problems that I can tell you will cost more money to fix than to replace with a new Rice cooker.
Good Luck.
Apr 25, 2010 | Zojirushi NH-VBC18 10-Cup Rice Cooker
Started rice cooker it was on..when I went back to check on it it was off and won't turn back on. I tried unplugging the ricecooker and plugging into a different outlet but it still doesn't work. The rice...
There is a sensor that regulates how hot the cooker gets and shuts it down to the warm setting when it senses that the heat is too high...meaning that all the water has cooked off....my guess is that the sensor failed and as far as I know it is not replaceable.
heatman101
Apr 07, 2010 | Oster 3072 20-Cup Rice Cooker
Purchased Durabrand Rice Cooker model HRC 18G working fine Is there a User manual for this cooker? All that is needed is ratio of water to rice including plain long grain and Basmati rice for 1 - 4...
Instructions quoted from the Durabrand Rice Cooker model HRC 18G manual...... 1 cup of uncooked rice rice will make about 2 cups of cooked rice. Add rice to the inner pot. Maximum four cups uncooked rice for the model. Many varieties of rice can be used including basmati, wild rice, arborio risotto, saffron rice and long grain rice. Whole grains, such as barley can also be prepared with the rice cooker, follow instructions on the package.
For every cup (160ml) of raw rice, add 1-1/2cups of water. For stickier rice add slightly more water, for fluffier rice use slightly less water.
When your rice is cooked, the cooker will automatically switch to the warm function and the yellow warm light will turn on. The cooker will stay in the warm function untill is disconnected from the wall outlet. The cooker will keep the rice warm 158F - 212F
Hope this helps, its quoted right out of the manual I have for my cooker
Jul 27, 2009 | Kitchen Ranges
Rival rice cooker stopped working
Mine just did as well today. Thought I blew a fuse, but no, just not working, although it did finish the pot of rice.
Jul 10, 2008 | Rival RC61 6-Cup Rice Cooker
Rice cooker stopped working after one month's use
You probably should bring it to a service center. since youve mention a span of time not using your cooker, the thermal capacitor may be busted.
hope this helps.
Nov 12, 2007 | Panasonic SR-SH15PS 8-Cup Rice Cooker
Rice cooker
First you have to make sure that the power outlet is working fine using a Multi Tester. Next is disconnect the Power Plug from the Rice Cooker and test continuity within the cord.  make sure those two are both working good.  next step is to open the Rice Cooker Bottom.  Again using a multi tester, Test the continuity of the Thermostat, make sure multi tester setting is on the ohm setting. reading should be zero, if reading is higher than 200 ohms, the thermostat is defective.  Which is the reason why your cooker is not turning on is due to an open in the circuitry.  Check warranty with the store you purchased it from or the manufacturer of the rice cooker.
Aug 22, 2007 | Black & Decker RC550 10-Cup Rice Cooker
Breville Gourmet Rice Cooker - Stainless-Steel Logo
106 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
