Question about Buffalo Technology 500GB DRIVESTATION TURBOUSB USB 2.0 7200 RPM SATA HDD 500 GB Hard Drive
Problem with Buffalo 500GB MiniStation model HD-PXU2 hard drive unallocated. How may I solve it?
Hard drive stated "Unallocated" at the Disk Management.
  • 88 Answers
SOURCE: buffalo ministation
if you dropped your hard-drive and it stopped functioning - high chances that the drive has a physical crash. Best suggestion will be to contact a professional data recovery team if the data on the drive is really important (Coz, they charge a bomb for the recovery) Suggestion would be to talk to drivesavers.com
Posted on Jan 11, 2009
  • 4 Answers
SOURCE: apparently i need to reboot my BUFFALO &
Apparently -- if you don't know how to reboot -- you should perhaps ask some computer wizard among your friends for advice.
You don't reboot a hard drive (or any other device), you reboot THE COMPUTER. Which means you shut it down and restart it. During the startup process (which is synonymous to "booting") the computer checks all its internal interfaces and external sockets, takes an inventory of all devices and checks if they work properly.
Posted on Sep 24, 2009
bob_computer
  • 3153 Answers
SOURCE: xp cannot install this hardware. Buffalo
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
USB flash drives can fail for no apparent reason.
Sandisk Cruzers are especially bad for this.
USB hard drives should be treated with extreme care.
This is a real hard drive ! and knocks and bumps can quite literally kill them.
It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
Note that if you hear a drive clicking or pinging this could be the worst thing you would hear.
Known as "The Click Of Death"
If none of the above steps help look at updating the drivers from the manufacturers web site in the support section
Testimonial: "very helpful advice and correct also. I had changed the usb lead and it cured the problem."
SOURCE: i have a buffalo ministation 500gb,now its not
i had the same issue. the light keeps yellow and the computer jams. ive just submitted a request for Buffalo. it seems those HD live for 6 months only.....
Posted on Apr 22, 2010
  • 11800 Answers
SOURCE: my external hd buffalo ministation
There is nothing you can do: that little fall has destroyed the hard disk's reading heads. This unit is dead, time for a new one.
Posted on Feb 25, 2011
Buffalo ministation not auto-playing or showing in my computer
i have exactly the same problem with HD-PCU2 500gb ministation (Buffalo). i have also gone through the solution given by John Adams. i cannot find the device in disk management, therefore i cannot format the device...is it going to work again..please help
Sep 03, 2012 | Buffalo Technology Buffalo MiniStation...
Cannot read or reformat my 500gb buffalo external hard drive
download Acronis Disk Director Suite via torrent. install the program. open the application. locate the drive that is not working. usually its labeled "unallocated". click on the "Acronis Recovery Expert" button. and again select the drive you want to recover/fixed. there are instructions on how you want the program to run its recovery. its pretty simple. bare in mind before running the application. your hard drive should be connected directly to your PCs USB port and not by any hubs. by this. your computer should be able to read your HD again.
Jan 11, 2012 | Buffalo Technology (USA), INC. - 500GB...
My HD drop into water and can't open it. please help to rescue. A lot of info inside the hard disk.
download the manual, and look for maintenance section
Downloads for MiniStation™ Metro - HD-PXU2
http://www.buffalotech.com/support/downloads/
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 21, 2011 | Buffalo Technology HD-PX500U2/RD 500 GB...
Cannot retrieve data from external hard drive 500GB. Bought in china and not used here yet. I can tell there is something on the drive as disk management shows it having 465.76 GB unallocated. However,...
If it's unallocated, that means the space wasn't turned into a drive yet.
You need to partition the space, and create a drive.
What you need to do amounts to going to Disk Management, right clicking where it says "unallocated space", and say "create basic disk". Then just repeatedly hit next.
If you'd prefer a more lengthy guide, see this:
http://www.bleepingcomputer.com/tutorials/tutorial116.html
Dec 22, 2010 | Hitachi 500GB External USB 2.0 Hard Drive
I cannot access my buffalo drive in any laptop. In my macbook, it says "the device is unreadable."
It means that the hard disk inside it has failed. Sorry, it can't be fixed, it's dead. Time for a new one.
Dec 14, 2010 | BUFFALO hop 320GB MINISTATION METRO(...
Buffalo harddrive is plugged in but hard drive doesn show up in my computer. When i went to manage hard discs. I see the 500gb drive but it is unitilized and unallocated
youve just answered your own question simply tell **** management to perform these actions and its up and running. Right click on your drive to see these options in disk management
Plz remember to vote
Jul 03, 2010 | Computers & Internet
My maxtor 500GB sata hd gives zero number of cylinders
go to the bios system
select booting device
choose hard disk
save & exit
thank you
Jan 15, 2010 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Buffalo Technology 500GB DRIVESTATION TURBOUSB USB 2.0 7200 RPM SATA HDD 500 GB Hard Drive Logo
356 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
