Question about Sony Walkman NWZ-B135 MP3 Player
How to replace my sony earphone jack - Sony Walkman NWZ-B135 MP3 Player
Earphone jack doesn't seem to work
tried to hooked up with other earphone jack first, if still doesn't work check the earphone jack of the tv which may have loose contact joint in the board.
Oct 14, 2012 | ViewSonic Televison & Video
No sound for earphone, there are no rca jacks, the earphone is used to attach speakers, but there is no sound from the earphone jack
if their is a sound from the internal speaker then the problem is with in only in the earphone jack or in the connection. to access the internal part of the tv you need to remove the rear cover. locate the earphone jack terminal re soldered and check the connection at the board ( PCB). you can check also the continuity, attached powered pc speaker then use an analog tester and check weather their is a connection coming from the stereo input jack going to the terminal of the earphone jack of the tv. if no connection replace with new earphone jack. good luck hope this can helped.
Aug 14, 2012 | Insignia Televison & Video
My system is stuck on (c2) headphone and I can not any sound, unless I put the headphones in.
Hi Steve,
This is an indication of faulty earphone jack, this is where the headset directly hooked up. See sample picture below.
When the you hooked up the headset to this jack, internal switch will released the contact to cut the audio goes to the main speaker out of the unit. Once you pulled out the headset plug, the audio will back to the main output speaker out through this switch.
In your cased, there's a malfunction in the internal switch of the earphone jack that's you haven't sound output at the main speaker out.
You may spray contact cleaner directly to the earphone jack while inserting and pulling out the headset plug to clean the lead. If the symptom still persist, you must replaced it with new one to back the unit in normal operation again.
Hope I helped you.
Have a nice day!
Thanks for using Fixya
May 17, 2011 | Sony DAV-S400 System
The earphone jack connection produces sound in only one ear. Partially with drawing the jack produces sound in both ears. Clearly, the jack is not making a good connection once inside its 'port'.
This is usually the result of faulty earphones. Try replacing the earphones you are using with the ipod and it should work normally.
Good Luck!
Jan 13, 2011 | Apple iPod nano
My itouch earphone jack creates static in earphones.
sounds like the typical ipod and ipod touch common situation. It seems to be the dreaded headphone jack on the bottom or top of the device has gone belly up. You can either take it to your local apple store or look online and search your problem and see if anyone else has the same issues you have and see what can be done.You can send it to ipodsquad.com to get repairs or check your local apple store.
Oct 12, 2009 | Apple iPod touch
Sony Trinitron Model KV 20M20
You may have a bad H board which is the board that has the voulme/channel buttons on it. You may want to have a Sony asc give you an estimate to repair. Good Luck
Dec 04, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Loose earphone Jack on sony mp3 player NW s705f
you will need a very small soldering iron (pencil) and solder and solder the jack back on the board
· http://www.noboundrees.com/micro_fix/
· http://www.pcpages.com/thebishop/nomadfix/
· http://www.instructables.com/id/Zen-Micro-Headphone-Jack-Fix/
Oct 17, 2007 | Creative Labs Zen Micro MP3 Player
RIGHT EARPHONE
either the speaker or the jack is out. I wonder have you tried them in more than one device. If you have and it still dosn't work. Most likely the speaker is out. your only fix is gonna be taking the earphone apart, pulling the speaker than, finding somewhere that carries one you can replace it with... or of course there is a simpler solution... Buy a new pair. Either way, Good Luck
Jun 19, 2007 | Sony MDR-V7000DJ Professional Headphones
Sony Walkman NWZ-B135  MP3 Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
