TOSHIBA e studio e250 fuser unit
Paper not feeding through fuser unit
SOURCE: Toshiba 2060 Paper Jam at the fuser
I think i found the issue. There is this plasic actuator piece that has two parts to it and its melted. I think that is the piece that detects the paper leaveing the fuser. Here is a picture of the part that is melted. http://www.precisionroller.com/actuators-for-toshiba-2060/details_8856.html
Does any one have a repair manual that they can send me on the correct way of installing this part?
Posted on Jun 19, 2008
  • 117 Answers
SOURCE: toshiba 2060 jams (accordion/fans the
sounds like a broken fuser drive gear.The fuser operates a nearly 400 degrees Fahrenheit and the drive gear cracks and falls off.Lots of trouble for a 50 cent gear.They are mad of fiber or plastic.take a few of the covers off near the fuser and disconnect the cables and the fuser slides out
Posted on Mar 24, 2009
  • 628 Answers
SOURCE: Error code C380 paper feed failure
c380 indicates auto-toner error for black developer (K).
Check following:
Is the harness between the LGC board and the developer unit drawer connector open-circuited?
Is any harness inside the developer unit or the auto-toner sensor harness open-circuited?
Is the auto-toner sensor connector or the connector CN341 on the LGC board disconnected?
IF connector no problems, then u probably need to replace the auto toner sensor.
Posted on May 28, 2009
  • 7 Answers
SOURCE: Canon ir2800 making high pitched squealing noise
change the film aswell......film will last longer if cleaning assembly is changed rountinly
Posted on Sep 30, 2009
  • 628 Answers
SOURCE: toshiba e studio 520 copy
Did u try scan to E-Filing only? See whether got faster or not.
Posted on Mar 30, 2011
Toshiba e studio 120, paper not feed. any help please? thanks
Change the feed tyres ..or clean them...but better to replace
Feb 21, 2016 | Toshiba e-STUDIO 120 Laser Printer
Misfeed in copier and total counter 463898
Your information too general. But base on your meter reading counter, I assumed a lot of your copier's parts might worn out.
1) Check any paper jammed remaining in the copier. You might accidentally tore the paper and the other tore remaining paper still in the copier.
2) Open and close all the covers. its all on the right side.
-fuser cover,side cover (T/S block section), duplex cover, drawer 1 cover (just below bypass), optional drawer cover (if there is LCT or LCF)
2) Replaced the feed, separation rollers for the drawers,
3) Check the fuser condition. Replace them if condition is not good.
Mar 08, 2015 | Toshiba e-Studio 350 Copier
During multiple feeds, the 1st copy is okay, but on the next succeding copies, top margins spacing varies that will cause the bottom copies to be cut
Meikriezl Ulit:
Remove the paper tray and use a "Q-Tip" dipped in alcohol to clean the paper pickup roller and the double-feed prevention pad (below the paper pickup roller.
Feb 24, 2013 | Toshiba Office Equipment & Supplies
Toshiba352 e030 code
heat roller up sensor clean .
Mar 08, 2012 | Toshiba e-Studio 350 Copier
Toshiba e-Studio 232 Black and White Copier C430
Fuser Unit problem. The fuser is the part that heats up and is located right where the paper exits the machine. Most common problem causing this code is the thermistors go bad. You most like need the 2 thermistors replaced in your fuser unit.
Nov 22, 2011 | Toshiba e-Studio 232 Black and White...
Can I get any technical info on the sensors related to paper jams?
what info are you looking for? these usually jam in the fuser, or the jams happen when the feed sections are not working and the paper never makes it out of the tray, then it will seem to be "phantom jams" but the jam sensors rarely go bad.
Oct 04, 2010 | Toshiba e-Studio 202L Copier
Error h4
H4 in 161, fuser low temp.; instantly solve it by simulation (c-auto-c-auto) 14; check thermistor; check fuser lamp by 5-02. it is to blink!
Jul 07, 2009 | Toshiba e-Studio DP170F Plain Paper Laser...
SERVICE CALL C380 paper feed failure
Chances are based on the amount of copies on this Copier it may be time to replace those Paper feed Tires
Check the Copy Count then call a Toshiba Indepenant rep to see when tire are replaced for your unit I would start there first.
if in the Ct area
Http://www.copierspluswwllc.com
we can help
May 27, 2009 | Toshiba E-Studio 3511 Color Copier
E studio 16
More than likely you have bad feed tires in the tray you're pulling from or if the drum unit is stuck there probably is paper jammed up in the unit.  Replace you feed tires and check your drum separation claws when you are able to get the drum unit out.
Oct 11, 2007 | Toshiba e-STUDIO 16 Printer
32 people viewed this question
k24674
