Question about Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard Drive
SEAGATE ST68022CF USB Device driver - Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard Drive
2 Suggested Answers
  • 1738 Answers
SOURCE: I have the seagate 8gb st1,2 drive st68022cf it
They make a internal hard drive to a external case.
Posted on Dec 29, 2009
I have a Seagate ST1.2 8 GB drive in an I/O Magic enclosure with a flexible USB connector that stopped responding recently. I suspect the USB connection has failed, not the drive. I would like to recover...
Yes, the disk-drive can be "transplanted' into a new enclosure.
Just be sure that you buy the correct enclosure (SATA-interface if your disk-drive has a SATA-interface, or parallel-ATA if your disk-drive has a parallel-ATA interface).
Feb 01, 2011 | Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard...
Windows xp will not recognise the seagate freeagent desktop drive
Assuming you have tried other usb ports and had no change,remove the usb connection, then go back into device manager and select the usb controller, right click and select delete as this will erase any input driver the usb port recognises. Restart the pc and then the controller should be reinstalled automatically as it sounds as though the controller has become corrupt for some reason. Go back into device manager and check there are no exclamation marks, reconnect the drive and see if it's recognised.
Oct 05, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Tip
Thanks! My 4 year old MP3 player - Creative Zen with a 8 gig Seagate ST 1.2...
My hard drive was dead and wasn't recognized by the computer, it didn't even start, just a few clicking noises, which according to some of the experiences is the same as a DEAD Hardisk. Anyways, as I read that sometimes this happens as a result of a hit, well, I wacked my HD as a last hope for it to recover its "memory" (as in the movies) and believe me or not, it worked! I don't know if this might help yours, but it saved mine!
The way I did it was like this: I started the pc and when the HD started to run and I heard a couple of clicks, I hit it against the table while in vertical position (assuming that the arm of the HD might slightly move better that way) one time, and then when the spinning and the first click was heard agin I hit again. After that I heard the typical searching sound of a HD, and you can imagine I started to pray that what I heard wasn't my anxiety sound (if it has any). Now I am a firm believer in the old trick of whacking the old TV to get the vital signal back!
Good luck to you too!
on May 20, 2009 | Western Digital 250GB MyBook External USB...
I was given a seagate momentus 5400.3 hard drive and i want to use it as a external usb drive i bought an external case for it and plugged it into my laptop, it see it but in device manager i am getting a...
Try connecting it to a different computer.
EXACTLY what error-message do you get?
When you double-click that entry in Device Manager, and click "reinstall drivers", allow Windows to connect to the Internet to look for a device-driver for the USB-to-disk-drive adapter (no device-driver is needed for the disk-drive itself).
Dec 11, 2010 | Seagate Momentus 5400.3 Hard Drive
I have window server 2003 OS and 500 GB free agent desktop USB hard disk is not showing in my computer. So how can i rectify it?
I just finished a Chat exchange with Seagate Tech support. MS Server OS's are not supported for FreeAgent devices.
It appears that whatever drivers exist in the XP install that recognize the USB device connection are not the same in the MS Server environment.
I plan to check the USB device drivers from both systems and see if the XP USB device drivers will work on Server 2003.
Oct 11, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have a Maxtor Personal Storage and I am
I found this info on Seagate forum (Seagate owns Maxtor). http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&thread.id=38
The error 10 is an indicator of a drive gone bad. But, there are a few on there that say they were able to get them working again. If you device is under warranty, try working with Seagate support first for a replacement. If you have data on them, you may need a recovery specialist to salvage that data.
Bret
www.1-2-1ComputerServices.com
Oct 06, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Dec 30, 2008 | Seagate FreeAgent Pro 1TB External USB...
Driver not detected - backup failed
I assume Seagate suggested you "reinstall" the drivers. If that's the case, you may still need to refresh your computer's device list to properly identify the drive.
If you're running Windows you may try opening "Device Manager" and uninstalling the device from the list, then "detect hardware changes". This may make your computer redetect the drive like it's a new device, but may not.
I suggest phoning Seagate back and ask to talk to a knowledgable tech, not the scripted phoners.
What operating system ARE you running anyways?
Mar 11, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
No detection or read
You could try to download and install FTK - Forensic Tool kit to grab the info. But sadly if the memory won't detect, your looking at having to use expensive software/hardware to grab the info.
Jul 08, 2007 | Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard...
Seagate ST1.2 ST68022CF 8 GB ATA-33 Hard Drive Logo
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
