Question about ViewSonic VA1703wb Monitor
Va1703 wb blinking problem
Hi.I have a view sonic VA1703wb monitor and it suddenly goes off when i turn on my system.Usually it wud get alright after constantly pressing the power button in the monitor for an hour or so.But now everytime i press the button in the monitor,it comes up for a sec and then goes off. What might be the problem? Do i have to change the monitor itself??
  • 1,684 Answers
That is a sure indication of a failure in the power supply board. The problem is that Viewsonic used two different power supply boards in the va1703wb model. If you want to do the repair yourself you should be able to. If you can open the unit and send a picture of the power supply board to us at tech@ccl-la.com we would be glad to show you what parts need to be replaced to rebuild the board and get it back up and running.
Posted on Feb 15, 2012
3 Suggested Answers
SOURCE: View Sonic VA720 monitor goes out after power goes
replace the logic board, not the power supply board. you can find logic board on ebay as low as $29...
Posted on Nov 15, 2009
  • 115 Answers
SOURCE: view sonic va1703wb model no: vsa11534 serial no:
Follow the following steps:
To obtain warranty service, email service.us@viewsonic.com.
To obtain warranty service, the following will be required :
The original dated sales receipt (include reseller name, address, phone #, product model, product serial number, and your name if applicable)
Your name
Your company name
Your shipping address (no P.O. Boxes accepted)
The serial number of the product
A description of the problem
Regards
Ashly
Posted on Feb 03, 2010
I have view sonic VA1703wb lcd & the problem is screen is blinking all capacitores r ok but still this problem so any one have a solution of this problem ?
The only thing you can try is turn down the brightness, this will address some monitor issues, if this fails the inverter transformers should be suspect.
Mar 05, 2012 | Computers & Internet
I have view sonic VA1912WB 19'' black lcd monitor.. recently im acing problem with it..after i turn on the system the green light blinks and there is no display on screen.. after several(5-6)...
try another monitor on your system if you can barrow one somewhere to eliminate that it may be the computer... if it is the screen check the warranty on it at the view sonic web site... also check the cable from the comp to the screen to see if it is lose. try another cable or if it has hdmi dsub or dvi try those types as well. it may have a lose connector on the one your using...
May 20, 2011 | ViewSonic VA1912wb 19" LCD Monitor
The view sonic VA1701WB display is totally white on the screen during up the computer and i check the CPU is booting up but at the same time monitor screen is totally white please reply the reason.
It can be due to:
Dead T-CON board on the LCD panel assembly due to blown fuse or just dead board.
Dead power supply on the logic board that supplys the power to the T-CON board.
Learn more here:
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 19, 2010 | ViewSonic VA1703wb Monitor
VA1703wb... Monitor beeps when I turn on the pc then goes black
Please read below and look at the pictures of failed VIEWSONIC nd othe monitor before try to DIY repair.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 06, 2010 | ViewSonic VA1703wb Monitor
View sonic va1703wb model no: vsa11534 serial no: qfcko70600651 is it warranty please tell me because my mointor was no display
Your name
Your company name
Regards
Ashly
Feb 03, 2010 | ViewSonic VA1703wb Monitor
Nov 15, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Hi i am using viewsonic lcd VA1703WB monitor.i am getting a horizantal line in the middle of the montor.i bought the system in jan07.please give a proper advice to rectify the problem.
The most likely cause is blown diodes in the screen.
You will have to take it to your local Viewsonic agent to check it out.
Best wishes,
Graemevm
Nov 13, 2009 | ViewSonic VA1703wb Monitor
Sound on the View Sonic Monitor
Yes, they are on the front of the screen. There should be a volume up and down button right on the front (usually to the left of the power). If there isn't a separate up and down, try the Menu or 1 and 2 buttons.
Aug 18, 2008 | ViewSonic 19.0" VG910B 1280X1024 TFT LCD...
Monitor won't display resolution properly after Windows Update
I was having the same problem. Believe it or not I fixed it by unplugging the monitor, and when I restarted my PC I again had the 1440 × 900 option.
Regards,
Jeff
Nov 06, 2007 | ViewSonic VA1703wb Monitor
ViewSonic VA1703wb Monitor Logo
161 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
