Question about Lexmark Office Equipment & Supplies
Will not receive faxes/sends faxes but no print on the page
Lexmark S405 Lexmark s408
  • Official Brand Answer
  • 3,344 Answers
A firmware update for your models addresses the issue where the printer is having trouble printing out any colors. Please visit the Lexmark website to download and install the Lexmark S400 Series Firmware Update. If more than one download is listed for your model, choose the first download in the list. If it is the wrong firmware level, an error message will tell you which firmware level is correct.
After successfully updating your printer, run the Deep Clean Printhead function on your printer. From the printer operator panel, press the Setup button > Maintenance > Deep Clean Printhead.
Then try printing a document again to verify that the problem is fixed.
If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Posted on Feb 16, 2012
  • 33 Answers
SOURCE: Lexmark 8300 print/scan/fax
There are sensors in the document feeder that detect the width and length of the paper being copied or faxed. Try getting a can of compressed air and go nuts blowing all the dust out of the feeder, if you spray everything you can get to, you will probably blow clean the sensors. Just an educated guess.
Good luck,
Printdoctor
Posted on Jan 04, 2009
  • 990 Answers
SOURCE: lexmark x4270 will send fax but won't receive
Hello sir; The better solution is replace a phone cable.
Posted on Feb 01, 2010
  • 225 Answers
SOURCE: My lexmark S405 willnot receive faxes. It is
Assuming "cable modem" as some kind of DSL modem using your phone line for internet. Both your modem and MFU should be connected to the wall by a filter-separator, usually supplied with your DSL modem. Check its presens and proper connection. Remove any other joints or splitters
Posted on Jun 14, 2010
domnickr
  • 65 Answers
SOURCE: How do I stop the fax from printing confirmation
go to control pannle, open hardware and sound ,then open device and printer,open your related printer and modify settings
Posted on Jan 19, 2011
Printtech
  • 1087 Answers
SOURCE: my lexmark interpret s405 is
There is a recent firmware update that fixes the problem you are describing. Click on this link: Lexmark Interpret S405 Firmware Update to download the update. If you encounter any problem updating your printer, please contact Lexmark technical support for additional assistance. Thanks.
Posted on Mar 09, 2011
S405 printer won't communicate with computer when trying to print
First, make sure that the firmware of your printer is up to date. Just go to http://bit.ly/ghfW8H to download the firmware update.
If the firmware update doesn't help, try to uninstall the Lexmark driver and download an updated driver online at http://bit.ly/rtOKTx. Just choose the Operating System of your computer.
Also, if your printer is connected to your network, try to set a static IP to your printer to prevent it from getting a different IP.
Dec 12, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Do I need black cartridge to fax
Generally you don't need ink to fax. Like sending a email that the receiver needs to print. However some printers will lock up and nag about cartridge empty before they let you move a inch
Sep 12, 2012 | Lexmark Interpret S405 - multifunction ...
I can not get s405 lexmark to receive fax on mac
Although you can send faxes from your computer, I regret to inform you that the S405 printer software does not have the option to pick up faxes. For the receiving option, you can only configure the fax receive settings using the printer software.
I'm sorry if did not have the answer you expected.
Mar 04, 2012 | Lexmark Interpret S405 Wireless All-in-One...
How to get my s405 to receive a fax
You might want to check the User's Guide for your printer. To access it, on your computer, click on Start > All Programs > Lexmark > Pro200 Series > User's Guide. Go to page 62 to know how to setup your printer to fax.
If your fax is already setup - meaning you're already able to send faxes but not able to receive. Make sure that the Auto Answer is on. To check that, on the control panel of your printer, press on Setup > Fax Setup > Auto Answer.
If you have an answering machine, make sure that your fax will pick up 3 rings higher that your answering machine. If you answering machine picks up on the 5th ring, set your fax to pick up on the 8th ring. You can change that under fax setup.
If you have a voice mail service enabled in your phone, you'll need a distinctive ring feature for your fax to work if it's being shared on the same line.
May 23, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Jun 14, 2010 | Lexmark X2470 All-In-One InkJet Printer
Fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
  1. Click Start onestep.gif Programs onestep.gif Lexmark 7100 Series onestep.gif Lexmark Fax Solutions.
  3. Click each tab and change the settings as desired.
  4. Press Save Settings after you finish your updates. Nothing is saved until you press this button.
  5. Click Close.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
  • Enter your company name and fax number.
  • Enter your name, company name, phone number and address as you want them to appear your cover page.
  • Select a cover page for your fax.
Send
  • Choose to use error correction.
  • Choose to use fax header.
  • Select a maximum send speed and a print quality for outgoing faxes.
  • Choose whether to scan the entire document before dialing the number.
  • Select when to print a fax usage report.
  • Select when to print a fax activity report
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
Feb 25, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
