Question about Southbend GS25CCH Gas Double Oven
Southbend fan replacement
Fan replacement
Fan motor is slowing down and not keeping the desired temperature
The circuit diagram for the standard control model shows the blower has a two-speed motor, connected directly to the power line in "Cool" mode, or connected to the temperature control in "Cook" mode. When the blower slows down during cooking, switch it temporarily to "Cool" mode. If it goes to normal speed, the problem is with the mode switch contacts or the wiring terminals between the fan mode switch and the temperature control board, or the control board itself.
If the speed does not change, check the wiring terminals at the speed switch common terminal (I assume your problem occurs in both low and high speeds). If you find tarnished, loose, or burned terminals, clean, repair or replace as needed. (In extreme cases, a loose terminal will cause the wire to overheat, damaging the insulation, oxidizing the terminal and causing a high-resistance condition that will reduce the voltage available to the motor.) If the connections are all good, the motor bearings are probably getting sticky at high temperatures. Let the oven get hot enough for the blower to slow down, then shut it off and check the blower bearings while wearing oven mitts.
May 12, 2014 | Southbend SLGS-22SC Gas Double Oven
My oven pilot light will not stay on
you may need to replace thermocouple and re-try it....good luck.
Nov 06, 2012 | Southbend S560DD (Gas) Oven
The gas orfices were changed to propane from natural gas. What size of gas orfices does this oven require? Or will any licensed gas fitter know this and have them on hand to convert this oven back to...
Sorry to read about your problem, I hope this helps you out.
you will have to contact southbend for that info..it is not a common practice to convert these units.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 22, 2010 | Southbend SLGS12SC Gas Single Oven
Hello, I have a Soutbend cooker serial N° NX
Call Rick at Restaurant Parts and More. 1-888-814-1110
Be sure to have model and serial numbers to ensure the correct part.
Nov 18, 2009 | Southbend S560DD (Gas) Oven
Oven wont heat up. replaced thermostat and ignition control
plz.check fuse near fix into/with the main transformer this connects capacitor and transformer
Aug 05, 2009 | Southbend SLGS-22SC Gas Double Oven
Wiring diagram for Southbend steamer Model 2000F
Southbend does not have their information for your steamer on-line. You can get your schematic/diagram by contacting them
Contact Southbend Technical Support 919-762-1000
Apr 29, 2009 | Southbend Convection SteamerKettles Direct...
Do we need an exhaust flue for a southbend half size gas oven?
Depending on your local code, you will need an exhaust hood due to the byproducts of the gas burning. Some locals allow for electric ovens to go without hood. Gas units generally require a hood system with proper fire suppression equipment. You may want to check with your local fire and building inspectors.
Mar 22, 2009 | Southbend S560DD (Gas) Oven
I have a southbend silverstar.
check your fan to see if it is clogged or dirty
Oct 10, 2007 | Equipex PZ-330 Electric Single Oven
Southbend GS25CCH Gas Double Oven Logo
27 people viewed this question
Top Southbend Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you a Southbend Oven Expert? Answer questions, earn points and help others
