Question about Anno 1404 for Windows
Anno 1404 will not run message says Direct X fails to initialise
It just will not start just says failure to initialise Direct X
When push quick start button, why does it display Erro 30 and doesn't run?
Hi There....This is a great message for ALL PRECOR 956/966 owners. This failure usually relates to a "communications" error between the upper and lower electronics. This particular failure is a direct result of a failed IFT drive module, or the lower drive "box" that is made by Advanced Drive Technology. The brains of this lower controller has failed and cannot "talk" to the upper board anymore due to several failed parts inside this box. You are lucky to have this failure arise over a fatal blow-out. Now replacements thru Precor or a distributor will be $550+ and are usually low stock items at places, but you can get repairs and exchanges of this Precor IFT drive by emailing gregATbuyfitnessrepairpartsDOTcom for much less than all other vendors. Currently these IFT drives are 380 exchange and 199 repair and turnaround is one day. Good Luck!
Feb 11, 2016 | Precor 956i Experience Series Treadmill...
How to change the serial key of anno 1701
Open Regedit
32-bit
HKEY_LOCAL_MACHINE\SOFTWARE\Sunflowers\Anno 1701
64-bit
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Sunflowers\Anno 1701
double click "SerialNo" and type in serial.
-Cutta Chase Beats
Mar 20, 2013 | Ubisoft Anno 1701: Dawn of Discovery
FERGUSON F20250DTR I have had this appliance since Christmas and have not had any problems with it up until now. Then suddenly, last night I have lost sound output and am also unable to access my...
\'hard-drive initialisation failed\' = the hard disk has died. Since also the sound is gone that means you had a catastrophic failure in the box. It is still fixable, but it will be very expensive to do it. Time to return it or have it serviced under warranty. If both options are out then just junk it .
Aug 19, 2010 | Televison & Video
Everytime i turn on my t3010d tablet pc it comes up with a pop box that reads API failed to initialise. what is this about?
"API failed to initialise" (sic) This means that an Application, Interface has not been able to establish a "Connection" with the base Program, it wishes to associate itself with.
Some program that is loading on startup, bootup, isn't working properly, it would most likely be best to, either stop it from starting. or reinstall the faulty program, that's failing. It may be nothing major, but the error message is a bother.
Jun 20, 2010 | Fujitsu LifeBook T3010D Tablet PC
On start up message 'disc failure 19.1' comes on.
POST Error Code of: 19.01 Flutter and then 19 blinks
Check and reseat hard drive cables. Replace hard drive, if necessary.
Hard Drive Part Number is: 121K39240
http://www.sparepartswarehouse.com/Xerox,Printer,Part,121K39241.aspx
You can also contact a local Xerox Authorized Service Partner to see if they will sell you the part.
Nov 27, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Water filter initiation failed
Did you this steps?
Fill the tank with fresh water.
Let the filter soak for 30 minutes.
After 30 minutes discard the water in the tank and refill with fresh water.
Place a container under the spout.
Press the cup button in the middle.(Filter on, yes)
Press the cup button again.(press ok, initialisation)
The machine initialises the filter.
Press the cup button again.(done initialisation)
Then press MENU repeatly. When the "exit" message is displayed, press the cup button. In this way, the machine ends the start-up phase.
Best regards
/Mirran
Sep 24, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Walter initiation failed
Did you this steps?
Best regards
/Mirran
Sep 24, 2008 | Saeco Vienna Espresso Machine
Unit wont start up after power failure
Answer on fixyourownprinter.com. Search there to see how to lubricate rod under scanner glass. Common fault. Mine responded instantly starting up fine after rod lubrication which stops scanner initialisation routine and leaves you looking at hourglass.
Jul 30, 2006 | HP PSC 2510 All-In-One InkJet Printer
Anno 1404 for Windows Logo
134 people viewed this question
Top Anno Video Game Consoles & Games Experts
James Wishart
Are you an Anno Video Game Console and Game Expert? Answer questions, earn points and help others
