Question about Troy Garden
How to remove gear on Honda hrb 475 mower
Drive jumps when any engaging drive
jgr4
  • 9 Answers
SOURCE: Scotts Classic 20" drive gear problem
In addition to lubrication problems, the plastic pinion gears can wear down or deform. This can cuase them not to engage, even if well-lubed.
I found some replacements at http://www.reelin.com. The parts number for the pinion gear is 30737-2, 30737-3 (left and right) for the Scotts Classic.
You can find the owner's manual, with part numbers, here:
http://www.reelmowersetc.com/2000-20.pdf
Posted on Jul 14, 2009
SOURCE: Honda HRB 216 self propelled mower Cable Broke for self propelled
there is a panel in front of the gear that completes the curve of the blade path that you can remove with a single bolt on the outside of the mower between the wheel and the deck
Posted on Aug 07, 2009
  • 93 Answers
SOURCE: I am trying to find a free instruction manual for
Go to Honda Website , you should be able to get it from there.
Posted on Sep 15, 2009
  • 78 Answers
SOURCE: honda lawn mower wheel drive works, but needs adjustment, how?
Take the covers off the drive,there should be a hollow bolt the cable comes thru, it should have 2 adjustment nuts This lengthens or shorts the cable. There also may be a adjustment on the handle.
Posted on Oct 27, 2009
  • 420 Answers
SOURCE: Craftsman 6.0 lawnmower frontwheel drive won't engage .
Make sure the belt has not slipped off of the pulley on the engine output shaft just above the cutting blade. It is common with those type of drives for debris to make the belt hop off.
Posted on Jun 02, 2010
1999 Honda F6 C Valkyrie starter spins but won't engage
Hi, Anonymous the starter drive/Bendix/clutch is a mechanical gear driven component that engages the clutch pack ring gear to turn over the engine. It has an internal mechanism that allows the gear to turn in one direction and once the engine starts allows the drive gear to free spin. If gear free spins in both directions then the drive gear has failed, it is not serviceable and needs to be replaced.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
starter spinning not engaging flywheel Honda Tech Honda Forum Discussion
1999 GL1500 starter won engage GL1500 Information Questions goldwingdocs...
Honda GL1500 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1997 GL1500C Valkirie Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 25, 2014 | 1999 Honda F6 C Valkyrie
How to replace drive cable on honda hrb 216 tda
Disconnect both ends, attach new cable. Google model number parts for illustration.
May 08, 2013 | Honda Garden
Not starting
sounds like the starter drive is worn out or the drive gear is not engaging the flywheel need to remove the starter and check drive gear
Oct 04, 2012 | Husqvarna Ariens 46 In Deck 20 HP Kohler...
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
Dear Sir, Have you any idea where i can get a Manual for my Honda HRB 475 lawn mower. Thanks.
Well you could do a google search, failing that going to the honda site and doing some clicking could help.
Aug 30, 2011 | Garden
Rear wheel drive on mower does not engage
Its possible that the cable slipped does the pulley turn on top of trans.if so does the shaft turn if so then your gears on wheels need cleaned or replaced.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Apr 29, 2009 | Garden
Open Questions:
Garden Logo
699 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
