Question about Mpio FY500 MP3 Player
Invalid MEMORY...help!! My player has started malfunctioning.Whenever i switch it on it says : INVALID MEMORY CAN'T FIND MBR After displaying this sometimes it also blinks the message "Format Please" for a split second.Then I am unable to switch off the player and ultimately pull out the battery to switch it off. Have tried formatting it with the latest software from the website but the software sometimes is not able to recognise the device and sometimes it just doesn't format. I am also unable to upgrade the firmware of the player.
    Problem Solver:
  • 5 Answers
Para quien tenga este problema con estos mp3 y todavía no lo haya tirado, esto es lo que hicé yo el otro día que lo encontré por ahí tirado:
- Quita la batería del mp3. - Pulsa los botones de "Func" y "Play". - Sin soltar los botones, conecta el mp3 al usb del ordenador. - Aparecerá un mensaje para formatear el mp3. - Suelta los botones y pulsa el botón "Rec". - El mp3 comenzará a formatearse solo y volverá a funcionar.
Espero que os sirva. Un saludo.
First of all, sorry for my English
If you still have this mp3 or for anyone who sees this solution, this is what I did:
- Remove de mp3 battery. - Press and hold down de "Func" and "Play" buttons. - Connect the mp3 to computer's usb. - A message of formating the mp3 will appear. - Release de buttons and press de "Rec" button. - Formating will start and in a few seconds the mp3 will work again.
Hope it works... it does in a FY400
Posted on Nov 20, 2010
Invalid sim card
I think your mobile is locked to a particular network so that your Blackberry 6280 says invalid Sim when you put your Sim in it. Find your locked network and unlock it to use your mobile with your Sim. You can find your locked network by switch off and switch on your mobile. At the top of your mobile screen the logo of that locked network will be displayed. After finding your network unlock your mobile using unlock code. Get the code from the site Wickedunlock.com ,and unlock it yourself using unlocking instructions which is given in the site itself.
Apr 30, 2013 | RIM BlackBerry 6280 Handheld
1995 honda odyssey starting problems
Hello! in 1995 stored trouble codes used the On Board Diagnostic I software (OBDI)..Scanners will not work...The control unit LED can indicate any number of simultaneous component conditions by blinking separate codes, one after another...An instrument panel mounted indicator lamp will light and stay lit. If the lamp is on, or if a system malfunction is suspected even though the lamp is off, it is necessary to inspect the electronic control unit LED display. The LED display is on the ECM (ECU), which is located just below the RH side of the instrument panel. The indicator lamps operate whenever the ignition is On and a DTC is stored in the ECM (ECU) memory.
When an abnormality is detected the ECM (ECU) display blinks. The LED blinks a certain number of times, with the number of blinks indicating the number of the DTC. After the LED blinks a number of times there will be a two second pause and the LED will blink out the number of the next DTC..here are the codes..If there is a code send it to me...If there isn't a code I'll take it from there...guru.saailer
CODE DEFINITION
1 ..Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2.. Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 ...MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor
4... CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
5.. MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping
* not 94-95
6... ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7... TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor
8... TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
9... CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
* invalid code for throttle body injection Hondas
** invalid code for V6 engines
10.. IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
12... EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
* invalid code for non-equipped EGR valve vehicles
13... BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor
14... IAC Valve (Idle Air Control) defective circuit or unplugged / defective sensor
15... Ignition Output Signal missing or defective ignition output signal
16... Fuel Injector System defective circuit or unplugged / defective fuel injector
17... VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
19...Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 ..Electrical Load Detector defective circuit or unplugged / defective sensor
21... VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
* invalid code for non-VTEC engine
** invalid for V6 engine
22... VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
23... KS (Knock Sensor) defective circuit or unplugged / defective sensor
30... Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor
* invalid code for 1996
31... Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor
41... Primary Oxygen Sensor - Heater circuit malfunction
43... Fuel Supply System defective or malfunctioning fuel supply system
45... System Too Lean or Too Rich malfunction in the fuel monitoring systems
48... LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor
54... CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
61... Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
63... Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
65... Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67... Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70... Automatic Transmission malfunction with the automatic transmission controls
71... Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72... Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73... Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74... Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80... Exhaust Gas Recirculation insufficient flow detected
86... ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90... Evaporative Emission Control System leak detected in the fuel tank area
91... Fuel Tank Pressure Sensor low input
92... Evaporative Emission Control System insufficient purge flow
Dec 28, 2011 | 1996 Honda Accord
Invalid SIM card on Atrix
LG invalid sim solution
model GS 190
Dec 11, 2011 | Motorola Mobility ATRIX 4G (16 GB)...
I have Samsung gt c3303 .But whenever i install any Jar file it say Jar file are invalid .what i do for it
i have Samsung gt c3303 .But whenever i install any Jar file it say Jar file are invalid .what i do for it
Feb 17, 2011 | Cell Phones
Invalid memory can't find mbr is mpio fy400
Para quien tenga este problema con estos mp3 y todav?a no lo haya tirado, esto es lo que hic? yo el otro d?a que lo encontr? por ah? tirado:
- Quita la bater?a del mp3. - Pulsa los botones de "Func" y "Play". - Sin soltar los botones, conecta el mp3 al usb del ordenador. - Aparecer? un mensaje para formatear el mp3. - Suelta los botones y pulsa el bot?n "Rec". - El mp3 comenzar? a formatearse solo y volver? a funcionar.
Hope it works...
Nov 12, 2010 | Mpio FY400 MP3 Player
I tried turning my mp3 player on and it said "invalid memory, cant find MBR"
Invalid MBR = Invalid Master Boot Record.
This means that your player Flash Memory drive is corrupted and unfortunately may need to be reformatted if you cannot repair it using some Disk drive or Flash drive utility.
You can try to use 'Properties -> Tools -> Error Checking -> Check now' to fix the issue.
If you have a backup of the music on your player, I would simply use Windows Explorer and FORMAT it using FAT32.
Hope it helps.
Dec 22, 2009 | Mpio FL300 MP3 Player
Whenever i switch on my system, it displays NTLDR MISSING PRESS CTRL+ALT+DEL... WHAT SHOULD I DO?
NTLDR is a file which is kept in the windows directory in the sytem32 folder, and is basically the boot loader.
Most of these problems are caused by bad BIOS configurations but sometimes the files are just corrupt.
Try going into the BIOS and setting it to default configurations, save the changes and exit the BIOS. The computer will restart and hopefully boot into Windows.
If you still get the same error message then follow this instruction bellow:
  1. Insert a Windows XP bootable CD into the computer.
  2. When prompted to press any key to boot from the CD, press any key.
  3. Once in the Windows XP setup menu press the "R" key to repair Windows.
  4. Log into your Windows installation by pressing the "1" key and pressing enter.
  5. You will then be prompted for your administrator password, enter that password.
  6. Copy the below two files to the rootdirectory of the primary hard disk. In the below example we are copyingthese files from the CD-ROM drive letter, which in this case is "e."This letter may be different on your computer.
    copy e:i386tldr c:
    copy e:i386tdetect.com c:
Good luck and please post back if need anymore help.
Nov 10, 2009 | Microsoft Windows XP Home Edition
Coby DVD shows Invalid Disc HELP PLEASE
Did you make the disk if you made the disk your computer has to give it a digital signature so the DVD player can read it if you're using a regular DVD then I would very carefully using rubbing alcohol and Q tip clean the actual laser I would be very careful doing this if too much rubbing alcohol is on the Q tip it will ruin the laser you can also try resetting the DVD player by taking out the battery and unplugging it from any power source and leave it that way for at least 20 seconds to a minute if that doesn't work you might have something else wrong
Jul 18, 2009 | Coby TF-DVD7005 Portable DVD Player
Hope it works...
Nov 23, 2008 | Mpio FY400 MP3 Player
Inquiry
Not all DVD players will play VCDs. If it never has played a VCD, then your's doesn't.
Hope this helps, and please rate my answer, good OR bad!
Good luck!!
Feb 04, 2008 | Televison & Video
Mpio FY500 MP3 Player Logo
196 people viewed this question
Top Mpio Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
David Roberts
Level 1 Expert
JonSnell Electronic
JonSnell Electronic
Are you a Mpio Audio Player and Recorder Expert? Answer questions, earn points and help others
