Question about Technics SL-1210 Turntable
Both technics 1210's stopped working, internal fuses intact. Please Help!
Both my 1210's have stopped working at the same time. I assume a power surge has taken them out. All other equipment on the same extension are fine (Mixer and amp). Fuses in both plugs have been checked and are fine. I have removed the plastic cover under the platter and inspected the two internal fuses f1 and f2 on both units. they are clear glass and I can see they are all fine. Is it possible for both transformers to go at the same time? Is there anything else I can try? Any input would be greatly appreciated thanks!
5 Suggested Answers
  • 6 Answers
SOURCE: technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
Posted on Jun 03, 2008
  • 310 Answers
SOURCE: No power to my 1210 MK2s
Check the wire or check the fuse in the board.................
Posted on Jun 12, 2008
SOURCE: How to remove a Technics sl- db20 platter
pull
Posted on Jul 28, 2008
  • 476 Answers
SOURCE: The platter on my Technics SL 1200MK2 stopped spinning
If you remove the rubber pad from the top of the platter then you should be able to lift the platter off the servo drives' center shaft,
from memory the unit is not attached just held on by gravity,if the servo magnet is gone the take it in for a service and pay the man for his time,
My first problem on my 1200s was a pitch control issue and easy to fix,with a little cash,never use second hand parts unless you know what you are doing because when they fail on you while playing to a packed dance floor then youll get more of a supprise than you barginned for,
Misterdj
Posted on May 03, 2010
Dash and tail lights only went out
Were any of the fuse ever blown?
If so, do you know the circuits they were on?
You replaced perfectly good bulb/lamps?
You have a fuse blow one time only,you stop
You look up the fuses circuit & what is on it that
may be a problem & do some testing
You have wasted not only time, but I assume, lots of money
on parts, for no real reason, when you consider you never
tried to find a problem
This dislike for repair shops & fear of the cost, may be your
only problem
Nothing works, because you did nothing & now expect
us to guess
How do we guess,please tell us
We have no vehicle to test,can't go by what you have done
Oct 29, 2014 | 2002 Nissan Xterra
Technics SU-X302 Problems
Greetings
Is there any indicator on or its all off?
anyway i will assume that there is none
1.check power fuse if blown.
2.check power transformer if there is any output voltage
3.check internal fuses
more information will give a better idea.
try these steps and hope this helps.
Dec 25, 2013 | Technics Audio Players & Recorders
Battery discharges while driving.
need to replace alternator
Dec 18, 2011 | 2001 Dodge Neon
Help my tv has stoped working
Hi ,
Here are some DIY steps that may help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is quite technical and fatal.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope it may help you.
Thanks for using fixya.
Feb 10, 2011 | Toshiba Televison & Video
Why my TV does not turn ?
Assuming that you don't even have a standby light on the led.
  1. Check the power cord - check the cord it might be opened (no continuity).This is due to frequent bending and pulling.
  2. Check the internal fuse - sometimes the fuse fail because of the power surge, replacing with new one cure the problem. However if the fuse blew again then this is an indication that you have a shorted parts on the power supply. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
  3. If the fuse is intact then you have a faulty in the power supply or on the load. You might have an open fusible resistor,open volt regulator ic, shorted H-out IC.
The #3 should be done by an expert or qualified technician because isolating the problem on the regulator section is technical.
But first check if the unit is under warranty then avail it because the manufacturer will fix it for you for free or a little charge only.
Have a nice day!
Jan 27, 2011 | Zenith Z32X31D 32" TV
I have a 2002 Freelander 2.5 SE automatic V6. All the interior lights are working apart from the centre console lights. The fuel, temperature, rev counter and speedo are all working. The heated rear screen...
The internal panel lights work off the left hand side of the side lights and are protected by the 10 amp fuse for this side. I had replaced both stop and tail lights with a heavy duty bulbs and because the left hand side powers the panel lights as well, obviously it was too much for the circuit. The right hand side was okay.
Oct 30, 2009 | 2002 Land Rover Freelander
Windows & locks not operating
TRY REPLACING ONE OF THE CIRCUT FUSES UNDER THE HOOD , IT IS A 50 AMP THEN THE DOME LIGHT SHOULD WORK, HOWEVER HAVE NO IDEA ABOUT THE WINDOWS AM HAVING THE SAME ISSUE , WITH THE WINDOWS.
Feb 13, 2009 | 2004 Jeep Grand Cherokee
Hi fi wont turn on !
hi. im assuming its a technics / panasonic system judging by the F 61 error code? try testing the cooling fan at the rear (assuming it has one) i once had the same error code on my technics amp and it turned out to be a faulty cooling fan. after replacement out of a scrap unit, the amp worked perfect.
Aug 07, 2008 | Audio Players & Recorders
Technics SL-1210 Turntable Logo
97 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
