Have a brother MFC-225cw printer but it's not printing black
Just keep cleaning the black ink and after every clean, do a test print. you have to do it numerous times but it works.
Posted on Feb 17, 2013
  • 7 Answers
SOURCE: "brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Posted on May 17, 2009
dj_relly999
  • 4070 Answers
SOURCE: Black not printing on a Brother MFC-290C
in the printer display try head cleaning option, there must be something blocking the cartridge. hope this helps
Posted on Jul 17, 2009
Mix-it-up
  • 832 Answers
SOURCE: Brother MFC 425CN will not print black
Have a look at the bk cart. Did you fix it well into position by clipping the support above the cart?
Can you see any difference by ink fuel before and after cleaning cycle? If there is no difference the valve is not open: drill a hole into the top cover and leave it open. Try another cleaning cycle again.
Posted on Nov 05, 2007
pineworks
  • 4041 Answers
SOURCE: My brother MFC-6490cw injet printer does not print
Hi There
steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Apr 28, 2010
SOURCE: I have a brother mfc-295cn printer that won't print black
Mine wouldn't print black either on Plain Paper, but if I changed the settings to Transparency Paper type it would. Hope this helps
Posted on Dec 14, 2010
How to remove shadow on prints - Brother MFC-9840CDW
Call on Brother technical support number 1-800-243-0019 Toll free. And get Instant support for your Brother Printer from our Brother tech support team?
Apr 14, 2017 | Brother MFC-9440CN Laser Printer
How to clean printer head for brother mfc j265w
Hi .. i have a similar problem ... i juste replaced the Black cartridge ... and when i run a "test print" or an 'alignment print" ... the whole black ink block doesn't appear at all .. only the Magenta, CYan & Yellow are ok. HELP ! ;)
Apr 19, 2012 | Brother MFC 420CN All-In-One InkJet...
My MFC290C printer will not print in black. I changed the ink and it still won't print black. I changed the color of the type and it will print in colors, just not black. I ran the cleaning cylce...
You need to call Brother at 1-877-brother and tell them your mfc is "missing black". They will tell you where to take it to get the print head replaced under Brothers' warranty. This is a VERY common problem and Brother will cover the cost to repair it.
Aug 10, 2011 | Brother MFC-290C Printer
My Brother MFC-490CW prints magenta where it should be printing black. I have done numerous cleanings and alignments. I changed the black cartridge and it is a Brother cartridge, not a refill. Still...
Well, either your print settings have it set to print in a color model that is not the native one (I can get this from CUPS drivers by picking KMCY instead of CMYK, among others) or it is confused enough to need Brother's initializing tool (program, I mean) to get it sorted out. Try de-weirding your settings first, then double-check the print dialog's settings when you retry. Nobody loves magenta-on-white for print.
Jul 25, 2011 | Brother MFC 490cw Color Inkjet...
How do I print in color & can I download the software off the internet with the brother mfc 9600 all in one
This printer only prints black. Down load drivers from brother.com Thank you, Steven 805-520-3003
Jul 08, 2010 | Brother MFC 9600 All-In-One Laser Printer
MFC-240C printer head repair
mY MFC-240C PRINTER IS NOT PRINTING WITH A MESSAGE " UNABLE TO PRINT SEE TROUBLESHOOTING
Nov 11, 2009 | Brother MFC 240C All-In-One InkJet Printer
How to purge fax machine
Try this:
1 Press Ink.
2 Press ▲ or ▼ to select Cleaning.
Press Menu/Set.
3 Press ▲ or ▼ to select Black, Color or All.
Press Menu/Set.
The MFC will clean the print head. When cleaning is finished,
the MFC will go back to standby mode automatically.
If you clean the print head at least five times and the print has
not improved, call Brother Customer Service
Oct 07, 2009 | Brother MFC 210C All-In-One InkJet Printer
Print only black and white for brother mfc 3360c
Power off the printer.press menu and power on .do'nt release menu button until maintenance appear and flashes fax, scan and copy . type 10 . then next type 49. you will see 00000000.just change last 0 to 1. 00000001. press 99 to exit. you will find the printer only prints B/W only.
Feb 10, 2009 | Brother MFC-5440CN All-In-One InkJet...
607 people viewed this question
k24674
jasbo
jasbo
