Question about Kenwood Car Audio & Video
Kenwood kac 7205 flashes red and blue
When it gets power it blinks red and blue than shuts off
SOURCE: kenwood kac 859 amp
The amp will reset every time it's turned off. The red light flashing, instead of staying constant is a warning that one of the protection circuits are activated. If the amp is bridged wrong, it can do this. If the load impedance is too low, it can also do this... don't trust the speaker, it it says 4-ohm, it may actually be 3.8-ohm, which could cause a problem if two speakers are wired in parallel. If it's not getting enough power, it will turn off briefly, but will turn back on after a second. A capacitor is not necessary with this, just use 4 gauge cable and have a good battery... make sure the ground is good, that one is commonly ignored.
Posted on Aug 21, 2007
  • 631 Answers
SOURCE: kenwood KAC-PS201T
The first thing you must do is to confirm that you have voltage at the amp. Just because the fuses look good, that doesn't mean you're getting power to the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Posted on Jan 22, 2008
SOURCE: WIRING MANUAL
tough ****
Posted on Mar 31, 2008
djmaximus_87
  • 26 Answers
SOURCE: kenwood kac-x1r flashes code e-03
HI DUDE EVERY REMOTE WIRE THEY HAVE FUSE NEAR THE BACK OF PLAYER TRY TO CHANGE IT .... R...TRY UNPLUG UR AMP .. AND ..FIX IT BACK
Posted on Jun 23, 2009
etirbynnor
  • 655 Answers
SOURCE: Kenwood Excelon KAC-X811D blinking e-03
Hello mogly20,
The amp probably won't know if it's you or the homeless guy, so try smashing a glass bottle on it like he did. If that doesn't work, I'd recommend you locate another homeless guy and buy another amp.
Hope this helps.
Posted on Aug 09, 2009
Lg 47lg70 turns off and on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 24, 2014 | LG 42LG50 42 in. LCD HDTV
Power light blinking on nv53a gateway
Your Gateway laptop comes with a series of LED lights that alert you to the state of your computer. You'll notice there are blue, purple and red lights that either blink or display solidly. Each light, blinking or solid, has a different meaning. The blue blinking light on your laptop indicates that it is in Standby mode. Your laptop goes into Standby when you close its lid without shutting down the computer. To turn this light off, you'll need to take the computer out of Standby mode, and if you want to ensure that the blinking blue light does not return, shut down the computer after each use.
Open the lid of your Gateway laptop and press the power button. Once Windows loads, enter your password if required. The blue light will no longer be blinking because the computer is no longer in Standby mode. Shut the laptop off when you finish using it rather than simply closing the lid to stop the blue light from blinking again. Click "Start" from your Windows desktop and click "Shut down." Change your computer's power settings to keep if from going into Standby mode when you close the lid if you'd rather not shut down your computer every time you use it. Click "Start" and click "Control Panel." Click "System and Security" and then click "Power Options." Click "Choose what closing the lid does" from the list of options on the left side of the window. Select "Hibernate" from the drop-down lists under "On Battery" and "Plugged In." Click "Save Changes." Your laptop will now bypass Standby mode when you close the lid and it will enter Hibernate mode instead. Hope it helps.
Jan 23, 2013 | Gateway MT6730 Notebook PC
Sharp lcd tv.lc45gd4u no power red light blinking two times pauses then repeats
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there. Blinking codes to so many brand TVs are described in detail here.
Nov 12, 2012 | Televison & Video
II get sound for about 15 sec. but no picture and then shuts off
kp57ws50_57_in_rear_projection_hd_228277.jpg Problem with Sony KP-57WS520 57 in. Rear Projection
This model is really prone to one problem in particular--screen even briefly comes up bright red, green or blue and set shuts down.
15 seconds from turn on front power light should blink as set checks several things internally---if something wrong it does not let picture show.
Usually after shut down or failure power light will blink a sequence of blinks but not always depending on problem.
Did you see the screen at all go red, green, or blue before?
the more you tell me the better I can help
Mar 28, 2012 | Sony KP-57WS520 57" Rear Projection...
Epson tx121 two red light and green light blinking
HOW TO SOLVE THE GREEN & BLUE LIGHT STILL BLINKING
Mar 06, 2011 | Computers & Internet
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
No picture & the red power light just blinks
If it shuts off and then the power light starts blinking red or never turns on but the power light blinks red continuously that is usually indicative of the convergence ICs (STK 392-110). You never want to replace the ICs without also replacing the resistors that are associated with them. There are usually 6 resistors, one for each of the colors and there corresponding direction, IE Red horizontal, red vertical, blue horizontal, ect. In the case of this model tv all of the resistors are 2.2 Ohm and 2watts. You will find them right where the STK 392-110 ICs are. Right in front of them. They are blue and have this color code on them: Red, red, gold, gold. These are represented by stripes on the resistors. You can get the parts from www.bdent.com They carry the ICs and the resistors. If you do not feel comfortable completing this repair I could do it for you if you send me the board. My email address is: missionelectronics@sbcglobal.net The cost is 375.00 and that includes all parts.
Good Luck.
Mar 08, 2009 | Toshiba TP43H95 43" Rear Projection...
Tv troubleshooting
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
Oct 30, 2008 | JVC HD-61Z575 61" Rear Projection...
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
Car Audio & Video Logo
74 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
