Question about Ovens
Wiring diagram required for baumatic bt2710ss cooker
Fitting new oven selector switch
  • 250 Answers
SOURCE: schematic wiring diagram
I have a copy of a STOVES 720EF Manual (including wiring info) posted on BT Digital Vault. Supply an email address and I will give you access to take a copy.
parsonm
Posted on Jan 20, 2009
SOURCE: Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Posted on Jul 23, 2009
SOURCE: Tricity Bendix SIE504W oven overheating
I have had a similar problem in that the top oven was overheating getting hotter and hotter and have just got a replacement thermostat from Partmaster.co.uk. This is to fit a Tricity Bendix from Currys model number DSIE520 GR. The new one seems just like yours in that it has three lettered connectors A,B and C. With the part came a sheet stating that for a free standing appliance with NO timer (this what my cooker is) the connections to be made are : 2 on old part to A on new; F on old to B on new; G/H on old to C on new and the link from G/H and 6 on old to be removed or "severed". I haven't yet done this as its in my cottage which I'm going to this weekend. Good luck! James
Posted on Aug 26, 2009
barkencoa
  • 3463 Answers
SOURCE: good evening i have a BT2431SS baumatic cooker,i
If it is a fan assisted electric oven, and the fan is wrking o/k, then it will probably be a faulty oven element.
This is located at the rear of the oven compartment behind a removeable cover.
Please rate my solution.
Thanks.
Posted on Nov 24, 2009
SOURCE: Hotpoint EW81 Dual Oven Cooker
Installed the new Dual Regulated switch which operates the Gril, but have got the wires inserted incorrectly. Need help wiring it up.
Wires are 2x Red,Black,brown,gray,Yellow and a red link wire which came with the part
New switch is a Diamond H - 48ER101C1P.
Numbers on switch are S1,P2,2,P1,4,S2
At the moment I have no cooker - help.
Posted on Dec 30, 2009
Main oven selector switch wiring diagram
Nice pic Norman but without the make & model we are spinning our wheels!
Jan 08, 2015 | Ovens
I have a baumatic cooker gas hob with an electric double oven model bt2730ss and i'd like to know how to remove the fan element? I took the plate off and undid the nut that holds the element in. Could...
hi if u have taken out the two screws then the element should be just sat there. make sure its turnt off at mains b4 going any further..... now pull element towards you slowly u should see the wires take one off at a time and swap over to new element ... when done put back together ... if u loose a wire down back just pull oven out and take back cover off to get access...
Feb 27, 2011 | Baumatic Ovens
Aug 11, 2009 | Electrolux Ovens
Baumatic fan assisted oven not heating up
The oven element has failed, you need to fit a new element.
It is a straight forward repair to do.
Remove inner rear panel of oven, you will see the round element at rear.
Unfasten element, detach wires, and fit new element.
Refit rear panel, and test.
Plz rate my solution.
Thanks.
Jan 24, 2009 | Baumatic B180 Electric Single Oven
My neff oven b1664 rear fan element stays on after switched off
I suspect that the fan oven thermostat is faulty,probably a contact welded inside the stat.or possibly a faulty function selector switch.
If the fan is not running, then it is still getting a supply from the thermostat. Fit new stat.
Dec 11, 2008 | Ovens
Schematic wiring diagram
parsonm
Oct 30, 2008 | Stoves 720EF Electric Double Oven
Fitting this cooker into an under bench unit
Yes
Should be no problem as long as you have some kind of vetilation.
Jul 27, 2008 | Baumatic B904SS Stainless Steel Electric...
Ovens Logo
112 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
