Question about Edirol HQ Orchestral (hqor)
Saving preset in Cubase
When I save my project in Cubase SX 3 with Edirol Orchestra changed Instrument on positions, panning, etc..., after reopen the plugin is set back to default. Thank you Thomas
  • Anonymous Mar 31, 2008
    Hi I have the same problem except with Fruity Loops.
  • Anonymous Nov 08, 2008
    its the question. whats the answer? :)
Try saving the performance within Orchestra itself - under the system menu. It's a *** coz you have the load this performance each time you load the song, but easier than having to remember how you set it up the first time!!
Pan and level can normally be set from the midi channel playing the voice.
Posted on Jul 08, 2008
Again i have the same problem. if anyone knows PLEASE TELL ME..
Posted on Jun 30, 2008
SOURCE:
How to delete markup in word 2010
Is it possible that "Track Changes" is still on? Look on the Review tab of the Ribbon. Make sure Track Changes is off. Then make sure the Display for Review is set to "Final", and try saving and reopening your document. That should work. If not, your last option is to save with a new name, Accept or Reject all review changes, and then save and reopen, etc.
Jun 15, 2014 | Microsoft Word 2010
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
I need to sync my snowball into cubase sx... its only recording on the left input not the right input of the audio wave. please help get back to work.
This is strictly a software setup problem. I use Sonar, but Cubase has to have the same features. Look for a PAN control and also where you MIGHT be able to select that both channels of the stereo are mapped to the single input. A work-around might be to bounce the input to a second track and then do a channel swap on one of the stereo channels, then combine them. I think Cubase uses the word "flip".
Search your documents for keywords: flip, bounce, swap, pan, and assign input. You can also copy and paste the recorded channel to a second stereo blank channel before flipping it and combining.
Mar 14, 2013 | Blue Microphones Snowball Professional...
When i playback in WDM mode, i hear ckrackles and pops, when i playback in the other mode the ckrackles and pops are gon, but the input and output goes to none. how do i get rid of the ckrackles and pops...
1. check your user manual for clicks/pops.
this could be due to devices connected to the Edirol UA-25 or a television or microwave.
2. this also could be due to the setting in Windows Energy saving settings.
that is the Windows "sleep mode" and power saving mode.
3. this could also be due to the USB cable.
4. you may need an external filter device for the process you are using.
5. read your manual on Troubleshooting Noise ( clicks and pops).
Jun 14, 2011 | Edirol UA-25 External Sound System
I had a cubase sx file open on my computer and suddenly there was a fluctuation in power and my computer went off. I booted my computer again, tried to reopen my cubase file and it says ''invalid project...
That probably had nothing to do with Cubase then. However if it did, it might be too big for the computer - or it could be a possible virus/trojan
Mar 17, 2010 | Steinberg Cubase SX3
Can't export song as audio mixdown on Cubase SX
I had this same problem, only it was after a reinstallation. Fixed it by changing the Output in the Audio Mixdown settings box to
"BUS 1 (Stereo)".
Jun 14, 2009 | Steinberg Cubase SX3
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
Usb mic in cubase sx3
you have a pci audio card so maybe you can add an extra input device by going to devices panel or press F4 shortcut.
and choose your usb mic.
also you can check your wavelab audio inputs. they must have the same config so if you can record woth your usb mic and your poci card in wave lave you must be able to do so in cubase sx
hope it works
Apr 01, 2008 | Steinberg Cubase SX3 (502010600) for PC,...
Edirol HQ Orchestral (hqor) Logo
464 people viewed this question
Top Edirol Computers & Internet Experts
Ben Armstrong
Mark Ferris
Level 1 Expert
Steve Allison
Steve Allison
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
