Question about Philips GoGear SA178 MP3 Player
Just hangs on when trying to turn on
Cannot connect to my PC, cannot charge, pushing any button does not help,
It just hangs on displaying philips on it ..reset button doesent helps anyway..
can you suggest something please??
Leave it in the computer for at least 3 days and then disconnect it that should do the trick
Posted on Nov 26, 2008
Cant turn on, where is power button
There are 5 buttons on the phone. A center button and two to the right and two to the left. Press and hold the hang up button, the bottom right button, for a few seconds until it comes on. If that does not work then the battery needs to be charged. When it is connect to the charger it will display a battery icon on the screen filling with green blocks to indicate it is charging. If you do not see this try holding down the start/hang up button as discribed above. If you still do not see the charging icon on the screen then remove the battery, make sure the connection on the battery and phone are clean and not bent. Then put the battery back in and connect to the charger. It gets reset when the battery is removed and should now work. If it still does not charge then you have a bad phone.
Nov 29, 2013 | SVP Black Dual SIM Quadband I5180 with...
Ipod repair
will it sync with your computer ?.... if its charged try pressing the middle and top button at the same time and hold for a few seconds until the apple appears on screen
Dec 20, 2009 | Philips GoGear HDD075/17 MP3 Player
It hangs on the first screen!
when i plug it in to charge it just stays on the philips welcome screen and just stayz like that wen i reset it does the same thing
Sep 10, 2008 | Philips GoGear Flash MP3 Player
Sa177/00 "recovery mode" problems in Philips Firmware Manager
Try to defrag the drive .... is not workd thn format it manually frm PC n reset the set hopefully it will get back to normal. i did this with mine go gear n its fine now.
Sep 03, 2008 | Philips GoGear SA178 MP3 Player
It Bricked itself
Recovery Mode for Philips' GoGear
Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.  Then click on the “Repair” button to start the repair process.  Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.  If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded.
-Tha Mp3 Doctor
Aug 13, 2008 | Philips GoGear HDD6330 MP3 Player
Please help
Try to hold down the power button while pushing the volume button up at the same time. This resets the device. It should help
Jun 02, 2008 | Philips GoGear HDD6330 MP3 Player
Mp3 philips hdd082/17 not charging and not connected when connected to usb
WARNING: this process will erase all songs off the GoGear.
Disconnect the GoGear from computer.
Turn the GoGear off.
Hold in the volume + button.
Reconnect the GoGear while holding in the volume + button.
Continue holding the volume + button.
After 5-50 seconds, Windows will pop-up a "Found New Hardware Wizard." - complete the wizard (BTW, you can take your hand ff the volume + button now).
Good To Go (Gear)!
-Tha Mp3 Doctor
Mar 24, 2008 | Philips HDD082 MP3 Player
Wont stay turned on.
1) Make sure the usb charger is in the lock position before trying to charge.
2) Open Philips Device Manager and try repairing the device. [connect your GoGear to the computer, open Philips Device Manager (Start-->All Programs-->Philips), and click on the repair tab. Now, disconnect your GoGear from computer. Turn the GoGear off if it is not already. Press and hold the volume + key and connect the GoGear to the computer (while still pressing the volume +). A window will pop up saying a repair is being performed. now you can let go of the Volume + button. The repair will get your device working normally again. WARNING: the repair process will delete any music/other media file from your GoGear.]
3) after repair, perform a firmware upgrade ("Update" tab in Philips Device Mgr while GoGear is connected to computer - see Philips website for more details)
Worst case scenario - Even rechargeable batteries have a limited number of charging cycles. The battery for the SA178 is an LI-Polymer 300mAh 12-hr battery. Philips won't fix it for you, but you might want to find a local repair service.
-Tha Mp3 Doctor
Feb 07, 2008 | Philips GoGear SA178 MP3 Player
Philips hdd070 MP3 player has gone dead
i think it's hanged. Let it be the way is it, once the battery is exhausted and at that time when u start it, it should be OK.
Aug 22, 2007 | Philips HDD070 MP3 Player
PHILIPS GOGEAR 6GB
The same thing happened to me. I contacted Philips and they sent me this solution, which worked for me. Question My GoGear has no power/no display even connected to the power supply with the AC adapter. What should I do? Answer Do a soft reset by pressing and holding the Power On/OFF button and the volume + key for a couple of seconds. Then connect your GoGear to a power outlet with the AC Adapter to charge the player again for around 30 minutes. Try turning the unit back on and see if the display appears. If the display is able to come on again, keep the player connected for another 3-4 hours until it is fully charged before use, else contact our Customer Care Center for assistance.
Jul 12, 2006 | Philips HDD1630 MP3 Player
Philips GoGear SA178 MP3 Player Logo
59 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
