Question about Kenmore 24032\24036 Top Load Washer
Sears washer I got the new clutch. Installing it went fine. Now I have a problem with the centerpost seal. I got a new one but I cannot get the old one out, it tore on me getting it out. So Now I'm comitted to replacing it. What am I missing here? I don't want to do anything wrong as I do not want to damage the shaft or housing.
    Sergeant:
    Champion:
  • 291 Answers
You will need to buy a seal installer tool at a parts house to install it ,,,, if you have a socket large enough to fit over it and still on the rim of the seal you can use it but greese it up before trying.
larry
Posted on Nov 25, 2008
Leaky washer
Janet I am VERY SURPRISED at this Whirlpool would do this...Shame on it! LOL. OK, Enough goofing around! Da Problem is Z in the Tub! It can be the following 1) Tub Seal (Most common) 2) Pump not draining (Second Most) 3) Washer exterior Drain to house. I forgot to mention this Is Very Common!. Janet these are the Easy fixes. The hard ones involve the tub being cracked (OMG!) or hose connections are cracked to/from washer and interior. Using the Wrong Soap! I know it is a reach but I have to mention it. If it is not the tub seal or the tub. You Gotta problem and you have to weigh the age of your washer vs purchasing a New one. If it is less than a yr old the Manufacture will take care of it. If you call Sears, plan on at least around $130+Parts. That may Pay for itself cause the person repairing it will guarantee the work. Good luck
Dec 27, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer LXR7244JQ1 has leak
There is a video at www.appliancehelponline.com/servicemanual.html this will show you how to disassemble. No special tools required. When you remove the casing you will be able to run the machine to see for sure if it is coming out the tub seal. Might just be a hose or the pump.
Mar 26, 2010 | Whirlpool 3.2 cu. ft. Plus Washer
I have a kenmore 80 series topload washer. It washes the clothes just fine fills and drains just fine, but it has a leak. I looked under the machine and found nothing wet. Checked all the lines still...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.########) and you'll see a list of major sub-components with diagrams and parts.
Check the areas for the motor and pump and the Agitator Basket and Tub.
If you've checked the hoses to and from the pump the problem points to either the pump itself or to the Centerpost gasket.
Neither of these is too difficult to replace, the Gasket requires removing most parts of the washer although the pump is an easy replacement.
Nov 04, 2009 | Kenmore 24032\24036 Top Load Washer
70 Series Kenmore washer pouring water underneath washer.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Check the areas for the motor and pump and the Agitator Basket and Tub .
Sep 24, 2009 | Kenmore 24032\24036 Top Load Washer
Direct drive Sears top load washer shaft seal
they make a special tool to replace it and you can pick one up at a appliance part house and they dont cost much
Oct 25, 2008 | Kenmore 24032\24036 Top Load Washer
Re: gearcase
Its hard to tell without seeing it. If the clutch is covered in oil (from the gearcase), it may be a good idea to replace it. Otherwise, you can reuse the old one. Let me know if you get to a point where you're stuck and need assistance.
PS The gearcase has specific instructions on the container that it be shipped in the UPRIGHT position. This prevents the gearcase oil from leaking out. In addition, there is a small breather hole on the top of the gearcase, that is sealed with paint prior to shipping. Don't forget to use a scribe or an awl to open this breather hole BEFORE installation.
Oct 08, 2008 | Kenmore 22622 Top Load Washer
Clothes got tangled with rubber seal inside and ripped it. How do I fix/get a new seal?
This part is a problem on many front-loaders and never really goes away. The rubber seal is a replaceable part and should be supplied under warranty. There is no way to fix it.You should try very hard to get Sears to pick up the labor cost as well.
Mar 14, 2008 | Kenmore Elite 45986 Front Load Washer
Code dc appears and has trouble draining and spinning during last 12minutes
I just did a repair on my FAV6800AAW by lubricating the needle bearings in the clutch pulley hub, the tub displacement sensor checked OK per the service manual check. I was getting dc/uc errors, washer was purchased in 7/05. I have basic mechanical skills and used a socket wrench to remove clutch pulley hub, just follow the service manual removal steps to remove clutch pulley hub. Pull the plastic cover off the clutch pulley hub and inspect the spring, clean/lube needle bearings and the clutch hub coupler that drives the spinner shaft. I used WD40 I may need to re-lube down the road with a good light grease. It took a few tries for me to get the clutch pulley hub to stay on after re-install and power up, getting the clutch pulley seated properly is the trick. I did not remove the washer tub for this fix, I believe I saw a posting where someone did. I just leaned the washer back to get a better reach angle, it is a tight work area. I did not want to junk 3.5 yr old $1k machine with out trying a fix. If you want to work on this model get the service manual, I found it online and I believe you can order it in PDF format from Maytag. Good luck!
I just went thru my 10th load of a mix of light, medium heavy loads and all work fine no unbalance errors (DC/UC). Doesn’t fix the tangle problem :) Prior to this fix I could only run the washer with no clothes in it to complete a cycle with no dc/uc error codes.
Jan 13, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Kenmore 80 series washer not spinning
you need the gear box not the timer.
Dec 20, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
