Question about KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range
Touch pad is blank kitchenaid KGRT607HBS6
Gas range , range top works , can unplug power for few hours and plug back in some time PF appears other times nothing then after hour comes on with lock on
4 Suggested Answers
SOURCE: kitchenaid electric range
This one can be a little tricky. I really need to know a lot more information to give you a good answer. You are right pf does mean power failure. This is detected by your power board the is located under the cooktop. If you select cancel the pf should disapear and you should be able to use your oven. You didn't mention whether the control board displayed the pf before you actually tried the oven. If it did, and it gives you that error every time you use the cooktop for a period of time, you could have a problem with the thermister located right behind the console. To remove the console just remove the screws on the under side then lift the console straight up and off.
Posted on Jul 21, 2007
SOURCE: kitchenaid range
could i get a more complete mod num on this range my tech data shows no f1 e2 code f1 is usually the eoc there should be more numbers after 307 theses are the engineering codes and are model specif
Posted on Dec 28, 2007
SOURCE: Kitchenaid Superba Gas Oven Touch Pad not working
We have a gas kitchenaid KGST307HBL9 and the touch pad is blank, but we discovered that you can still touch the buttons and it will work. (example touch bake; temperature; start). It will beep when the target temperature is reached.
Just so we don't forget and leave the oven on, we turn the oven light on as our signal. A little work, but not wanting to "fork" out the money at this time to repair.
Also, if you are handy RepairClinic.com has many items and can also answer question. We've used them for several of our appliance repairs.
Posted on Jul 02, 2009
Touch pads on my kitchenaid range do not work
contact a service man PF can distroy circuit boards .
Dec 31, 2014 | KitchenAid Kitchen Ranges
Touch pads on my kitchenaid electric range do not work, no error appears
Do the buttons beep when pressed if so bad control do know the model number the keypad and control might all be in one the PF is normal indicated Power Failure
Kitchaid electric range display PF what to do
PF indicates a Power Failure. Turn off the power supply (for 30 seconds or more) to the unit and then back on, select/touch the range cancel/clear pad and reset the clock. The range should work again, unless there was damage to the control during the power interruption.
Oct 05, 2014 | KitchenAid KERS807SSS - Freestanding...
Kitchenaid model YKGSC308LSO is showing code PF
Press and hold the Start pad for 5 seconds until "Control Lock" appears on the display. Repeat to unlock, and "Control Lock" will disappear from the display.
Apr 19, 2014 | Kitchen Ranges
After self clean oven panel went black
Sometimes these can be fixed by unplugging it for a few minutes and plugging back in. I am assuming this is a gas top and electric oven. Verify the incoming voltage at the back of the range (not at the receptive but where it comes into the back of the range. Disconnect the plug before taking off the rear access cover and verify all the connections are tight before plugging it back in. Set volts to AC on your meter and check power between neutral and line (hot wire usually black). If this range uses 220 volts then check between the 2 lines (usually red and black). If the voltage is 120 or 220 respectively then you may have a fuse that blew (sometimes it is a fusible link in one of the power feeds) or a board.
Apr 05, 2017 | KitchenAid Kitchen Aid 30 In. Stainless...
I have a PF erorr code on my oven screan
"POWER FAILURE" code, unplug the power from the range for 20 minutes or longer, plug back into the power outlet, set time and if the micro-processor didn't take a hit during the power failure you should be up and going once again.
GOOD LUCK !
Aug 26, 2010 | KitchenAid KDRP467KSS Dual Fuel (Electric...
My Kenmore oven won't work there is a PF 5AB error
The PF on your control indicates a power failure and should be removed by pressing the cancel button. The 5ab code indicates the range is in the SABBATH mode.
If a power failure occurs when the SABBATH mode is set, the oven will return to the OFF mode and will turn the power OFF to the oven.
To ENABLE SABBATH mode:
* Open the oven door
* Press STOP/CLEAR
* Press both the HOUR "UP" and "DOWN" arrow pad at the same time - and hold for 5 seconds.
SAB ON will disappear from the display.
To disable SABBATH mode: Repeat the steps above and SAB OFF will appear.
To set the SABBATH mode for use during the SABBATH/Holidays:
* Press BAKE
* Pres TEMP "UP" and "DOWN" Arrow pad to enter a different temperature other than 350 degrees. (Between 170F and 500F)
* Press COOK TIME
* Press HOUR/MIN "up" or "down" arrow to set cook time
* Press DELAY START to set a delayed cook time (optional)
* Press and hold TIMER OFF for 5 seconds
SAB will appear on the display indicating it is ready.
* Press START
* To STOP cooking - press STOP/CLEAR
* To exit the SABBATH mode and return to normal operation - press and hold TIMER OFF for 5 seconds.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 05, 2010 | Kenmore 71414 / 71419 / 71410 / 71412 Gas...
Jun 03, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Power failier
beleive it or not set the clock,I work at an apartment complex and the cleaner always unplugs my stoves to clean behind ,everytime I plug back in PF,Just set the clock hours and minutes,Its just telling you you lost power incase you had something cooking in the oven,you wont think that your oven is broken,and also so it doesnt start automatically by it self please rate this solution thanks
Jul 13, 2008 | Whirlpool GS460 Gas Kitchen Range
KitchenAid KDRP407HSS Dual Fuel (Electric and Gas) Kitchen Range Logo
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
