Question about Mackie SWA1501 Subwoofer
Mackie swa1501 it does not power on. I am sure it is the amp. tried changing the fuses but still does not come on
  • 41 Answers
The wires get shaken loose from the constant vibration and you'll need to get a saudering gun and check each connection. especially on the panels.
Posted on Feb 15, 2012
How to open my mackie swa 1501 subwoofer to change the fuse?
Service manual is available for free from https://www.manualslib.com it contains disassembly instructions. If you change the fuse and it blows again, then your amp will need service.
Oct 06, 2014 | Mackie SWA1501 Subwoofer
Mackie sub swa 1501 no LED no output but light on board appears to be on
los transistores de salida estan en corto 2sa1943 y 2sc5200 reviisa los drivers tip 122 y los irf
Feb 18, 2012 | Mackie SWA1501 Subwoofer
Nesecito urgente el diagrama electronico del Mackie SWA1501
  • Espero que esto ayude y gracias por usar FixYa
Saludos, Tony
Aug 26, 2011 | Mackie SWA1501 Subwoofer
Volume reduction with same input ( 4 years old),
What are you using to feed the sub? Are you sure that the signal level you are presenting to the sub is the same?
Dan
Jul 31, 2009 | Mackie SWA1501 Subwoofer
Where is the crossover located in the mackie srs 1500and does the crossover have a fuse.
The Mackie SWA1501 has an active electronic crossover on its main circuit board.
Jul 15, 2009 | Mackie SWA1501 Subwoofer
Need a circuit board diagram for the SWA1501
not difficult...2 screws on the top and 2 screws on the bottom of the box will remove the amp section. Did you change any components that rectified the fuse blowing problem ? ie. like Q17 - 2SC5200 0r Q14 - 2SA1943 are the main output drivers..
My mackie swa1501 keep blowing their fuses after the gig not during but after only running at 60% and just family party music so nothing heavy . also why is thier two fuse holders one is the TA then under...
there are more than 2 fuses in the unit, one is power supply, the others are rail voltage for the amplifier. All must be exact in rating for proper protection from fire and overload. The voice coil coild melt or short, offering partial fuctoinality, but presenting an overload to the amp. Usually this is accompanied by somewhat distorted sound. If you have another one, and are on a budget... swap the amplifiers in the 2 units and see if the problem goes with the amp, or stays with the speaker. Then you will have your answer as to which half of the thing is causing problems. Speaker you can prolly chasnge yourself, the amp will need professional service.
Jun 17, 2009 | Mackie SWA1501 Subwoofer
SWA1501 Sub blows fuses when turned on...
Shorted amp or blown speaker. Other things could also cause it. But there is a short circuit in it.
Mar 08, 2009 | Mackie SWA1501 Subwoofer
Bass pops
Hi There, Have you checked the 3 fuses that clip onto the main amp board? You can access them by undoing the two screws that are on the top and the bottom of the sub. They have flat large heads and you will need a hex key to unscrew them. If it is one of the fuses that has gone it will either be discoloured as in burnt or you will see the metal inside has split. Simply replace these with a new fuse and hey presto you should have eradicated the popping. If you need any parts for the sub or fuses then www.LondonSpeakerShop.com will be able to supply them (that is if you're in the UK). Hope this helps. Grant (from www.LondonSpeakerHire.com)
Feb 01, 2009 | Mackie SWA1501 Subwoofer
Mackie SWA1501 Subwoofer Logo
67 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
