Question about Sony Audio Players & Recorders
A.D.F audio error
It keeps on comeing up with adf audio error when i turn it up and it cut the music off 4 a sec then back on
  • 41 Answers
Change your settings. sometimes if it is in theater mode or sourround sound will disconnect it. you could try a different speaker size. if there to larger it want output right.
Posted on Feb 15, 2012
My harman kardon avr 100 keeps cutting out every 3 secs. i can hear the music but constently keeps cutting off. its very annoying... any ways to fix this probem?
Check the impedance of the speaker wires going into the amplifier. It sounds like at least one set of speakers is overloading the amp (shorted, or almost shorted)
Jul 24, 2011 | Harman Kardon AVR 100
Tv keeps cutting off
checked at the secondary power supply there's a component (capacitor, resistor, dioode) which change in value.
Jul 31, 2009 | Disney DTD1363-CAR 13" TV/DVD
Cut out
rewire the subs-each sub you want in series=8 ohms per sub-then at the amp wire the two 8 ohm subs in parallel which brings the ohms back down to 4 ohms which is optimal for the amp and it shouldnt shut down on you any more-try that-good luck
May 30, 2009 | Kicker ZX400.1 Car Audio Amplifier
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
ADF error
Hello sir; Make sure there have no paper chips in the paper path, then turn power off and back on, if still have problem, then check the paper sensor is moving freely.
Apr 28, 2009 | Ricoh Aficio 2020 All-In-One Laser Printer
When i play music loud the sound cuts out
i would try getting a new amp, the speakers may be blown.
Dec 30, 2008 | Audio Players & Recorders
Amp cuts off with bass
possible bad turn on relay in amplifier. Service will be required.
Dec 20, 2008 | Car Audio & Video
Sony handycam dcr-pc300/330
Make sure the batteries are fully charged. It may be your batteries may show they are charged but are too leak to operate the camera. Try a new one
Apr 07, 2008 | Sony Handycam CCD-TRV37 Camcorder
Speakers All Cut out Including Sub When Music is Played Loud
UNPLUG THE GREEN WIRE FROM THE COMPUTER AND PLUG IT INTO A CD PLAYER IF IT WORKS BETTER ON A CD PLAYER THAN THE COMPUTER IT SELF THERE MAYBE A PROBLEM WITH THE SOUND CARD AND ALSO TRY THESE STEPS I AM GOING TO GIVE YOU I AM SURE ONE OF THEM WILL WORK.
1. Please ensure that the all the connections between the satellite speakers and the subwoofer are firmly connected.
2. Next, please connect the green colored 3.5mm audio jack to another audio device such as an iPod or an MP3 player.
3. Ensure that the SoundTouch remote control is firmly connected to the back of the subwoofer.
4. Connect the power cord from the subwoofer and connect it to another single power outlet in your house. If you have an automated voltage regulator (AVR), please connect the power cord through the AVR instead of connecting it directly to a power outlet in your house.
5. Power up the speaker system and check whether the power button on the SoundTouch remote control will light up.
6. Turn on the Matrix Mode ON. This option is on the SoundTouch remote control. This is to ensure all speakers from the speaker system will produce audio that will be played from the audio device.
7. Play audio from the audio device. Check and see whether the all the speakers will produce audio being played from the audio device.
IF NONE WORK TRY THESE STEPS:
Jan 12, 2008 | Logitech Z-5300 Computer Speakers
Power-on "initializing" power-off, repeat same cycle(process)
The all-in-one product display always reads "Initializing" This may occur in a low power situation. Follow these steps in order to determine the cause:
  1. Verify that the computer and the all-in-one product have a three-prong power plug.
  2. Unplug the product cable from any power strips or surge suppressors, and plug it directly into a grounded (three-prong) wall outlet.
  3. If the all-in-one has an ADF with an external cable plugging into the back of the product:
    1. Turn off the unit.
    2. Unplug the power cable from the wall outlet.
    3. Unplug the ADF cable from the back of the product.
    4. Plug the ADF cable to the back of the product.
    5. Plug in the power cable, and turn on the power.
      • If no change, the problem is not the ADF.
      • If the problem clears, turn off the all-in-one, unplug the power cable, and plug in the ADF.
      • If the error returns, the ADF is defective. Contact HP Customer Care to get the ADF replaced.
  4. Unplug the USB or parallel communication cable from the back of the all-in-one and try to power up the all-in-one. The computer may be grounding out through the communications cable. If this corrects the issue, check the grounding of the computer and outlet. If the above steps did not resolve your issue, contact HP for additional issue verification or the servicing of your product.
Jan 04, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
44 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
