Question about Philips Magnavox 42MF521D/37 Television
42mf231d/17 fails to turn off manually or w/ remote.
Unit will not turn off manually nor w/ remote. Image and sound go off, power indicator stays on and screen appears to be energized. Any suggestion will be appreciated. Thanks. My Magnavox 42MF231D switch turns blue then goes off when I first plug it in. after that it wont come on at all unless I unplug it then it does the same thing again. Can anybody help me please?
My remote does not work at all. Also I can not change inputs using the buttons on the top of the set. I even bought a Harmony Universal Remote. The results are still the same...no response.
Posted on Nov 27, 2009
Magnavox suggests unplugging the tv for exactly 10 minutes to reset the tv---try that---or call the service number for assistance
Posted on Jan 18, 2009
No picture or sound magnavox 42MF231D/17 only 2 of the green blinking lights are working
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Oct 10, 2015 | SNK Magnavox 42MF231D 42 in. Plasma TV
My Magnavox 42MF231D 42" T.V
You may have a weak power supply. This would indicate one or two capacitors that are weak or bad. This model may be about 4 years now and this is a good indicator as these capacitors need replacing. The other problem may be the infared board in the TV that receives the signal from the remote may be a problem as well. I would certainly investigate my first thought. The latter is kind of rare. Thanks for asking and show a few hands of support.
Nov 29, 2010 | SNK Magnavox 42MF231D 42 in. Plasma TV
I have a Brookstone large button remote, with no instruction manual. Tring to set it to a RCA colortrack 26" TV. Is there anything i can do?
Hi
Try this:
Automatic Programming
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control (TV, VCR, SAT, DVD) until POWER INDICATOR illuminates. The remote control is in programming mode.
3. Press POWER button on remote and release . The POWER INDICATOR flashes once and stays on indicating the unit is in Power scan mode.
4. Press CHANNEL+ or CHANNEL- repeatedly until the device turns on.
5. When the device turns on, press ok to store the code.
Good luck pls rate
Dec 18, 2009 | Televison & Video
42'' Magnavox 42MF231D/17 with picture/sound problem
Hi my name is Roety,
I can help you with your issue ,
Sounds like a bad SSB small signal board
login as a guest and check price and availability at
encompass.com
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Oct 31, 2009 | Philips Magnavox 42MF521D/37 Television
Magnavox 42MF231D/17, screen just turned black,
power supply or inverter board failing if the power board is the problem it will have blown caps
little cans with puffy tops because the caps have vented if you don't see that then your inverter has died that model id out of production so try shop jimmy. com
Sep 22, 2009 | SNK Magnavox 42MF231D 42 in. Plasma TV
Cannot find manual. need to program menu
Hi and welcome to FixYa,
The user manual for a Brookstone 538744 is available here. It is in pdf form and would need Adobe Acrobat Reader to view the file.
Good luck and thank you for using FixYa.
Jun 25, 2009 | Brookstone 538744 Remote Control
Remote control code for Magnavox 15MF605T/17
oif the codes in setup don't work for the direct tv remote, here is a code list at the end of the post
Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
Hope this helps you out, good luck.
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
there's no signal comes to you tv that why the screen is blue, the problem of your tv is the tuner, so check the the requirment of the tuner to determen if its good or not.
Sep 17, 2008 | Philips Magnavox 27MS343S 27" TV
Codes for palsonic televisions
Hi, that TV is not listed in the code list for your model.. You can try an automatic search by doing the following:
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. The
3. Press and release power. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
4. Press CHANNEL + or CHANNEL - repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
If the device responds, the remote control has been
programmed. If the device does not respond, repeat steps 2-5.
For future needs, here is the link to your manual:
Bookstone 538744 remote manual
Apr 12, 2008 | Brookstone 538744 Remote Control
Philips Magnavox 42MF521D/37 Television Logo
468 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
