Question about Belling SGE12X Front Load Washer / Dryer
Belling SGE12X broken door handlw
The door handle has snapped off. It refused to open and the spring mechanism had gone. On trying to prize it open, it snapped. We have a replacement handle set but don' t know how to get the old one off, or get the door open. Can anyone help?
  • fusewire Dec 20, 2008
    I have the same problem and looked inside and all I found was the locking mechanism (solenoid?). This was before reading this solution but there did not appear to be any way of releasing the lock. There are two wires entering the block at the bottom, how do you actually release the lock. Assuming it can be released what are the problems in replacing the lock?
  • 903 Answers
It's not an easy job to replace a door handle, but to release it for the door to open, turn off the machine at the outlet and unplug. Take the top of the machine off and slide your hand down to the door catch. Depending which type of catch it is, you should either be able to push down a small lever on top or push up a small lever on the bottom or the door catch.
I hope this helps
Posted on Oct 25, 2008
What part do I need? It opens from the inside. The handle is not snapped.
Are you saying the inside door handle isnt snapped,but the door wont open by pulling on the inside door handle or is it the outside door handle thats not working??Both the inside and outside door handle has a spring and other components on the backside of the handle which cant really be seen unless you remove the whole door handle assembly.One of these components are most likely broken or the rod that attaches between each handle and the locking mechanism(part that locks into the door striker to keep the door closed and releases it too)might have come loose from the back of the handle.The outside handle is usually mounted to the door by pop rivets or bolts/nuts.The inside handle is usually mounted with screws,but it really depends on what kind of car youre driving.Youll probably have to remove the handle to inspect it for damage.Open the door and watch the locking mechanism for movement while youre pulling on the door handle.If it doesnt move when you pull on the handle,the handle is definitely broke or the rod has come loose from the back of the handle.
Mar 09, 2015 | Cars & Trucks
Driver's side door latch won't budge once closed. Locked or unlocked the outer handle acts like the door is locked. Any suggestions?
The outer handle has a spring to return it built into the handle I think, so the fact that it returns does not mean it isn't disconnected inside the door. Time for a shop I think (are the replacement switches really $500? Might check with a parts store instead of dealer to see if they can supply that part.)
Jun 30, 2014 | 2001 Isuzu Rodeo
Drivers door wont open
If it were me , I'd remove the inside door panel and take it from there. It may be that you can pry open the lock mechanism with a screw driver or a similar tool, allowing you to open the door - which obviously you must do. Even that, though, will not solve the cause of your problem. You may wind up at the dealer.
Aug 19, 2017 | 1986 Ford Tempo
The front passenger door will not open with the outside door handle or the interior door handle. after taking the inside door cover off, i discovered the interior door handle is broken and the connector...
The locking mechanism is manufactured with carbon composite and plastic levers that the door handles attach to. It is hard to tell what parts that you do need. Remove the passenger side door panel. It will have some screws and maybe a bolt on the inside handle. The panel has snap plug on it and they fit into designated hole in the door. After getting the door panel off, be careful here, there are sharp metal edges that can cut. There are some peep hole to see the rods and connector inside the door. If the plastic hooks on the door locking mechanism are broken. The hole door lock assembly will need to be replaced.
Try your local wrecking yards and tell them what type of vehicle you have and year. Also, state what door it is and what you will need.
Now, if the interior door hand hook on the lock mechanism isn't broke off. The get a cloths hanger and straighten it out and attach it to the opening latch on locking mechanism. This will give you inside temporary handle, while you are trying to fix the door. Safety. GB...stewbison
Sep 06, 2011 | Nissan Sentra Cars & Trucks
Install door latch cable
Technical Instructions
See picture below
1. Remove door trim panel and water shield per
NOTE: Place a strip of masking tape along the edge of door before removing trim panel to prevent scratching the door with the trim panel removal tool.
2. Snap cable housing end from slot on inside door handle assembly and disconnect cable.
NOTE: Use care to prevent bending of cable housing retainer bracket.
3. Remove rear window channel retaining bolt to allow access to door latch.
4. Position a block (screwdriver handle) between the latch and the door inner panel and snap the cable housing end out of slot (towards inner panel) on door latch assembly and disconnect cable at latch.
NOTE: Use care when removing cable housing to avoid bending of the latch. Discard cable.
5. Hook up new cable at latch and snap cable housing end into slot.
NOTE: Make sure the cable housing is fully seated in the slot.
6. Apply a light film of Teflon grease to the barrel end of the cable. See Figure A.
7. Install return spring. See Figure A.
NOTE: Ensure that the push button rod is located between the spring and the door inner panel.
8. Install foam block at latch. See Figure A.
9. Position water shield over the return spring and install push pin to retain upper portion of water shield. See Figure B.
NOTE: Push pin goes in the same hole as the return spring.
10. Clean hands of grease before performing step 11.
11. Remove protective backing along the lower edges only of the water shield. See Figure A.
12. Install latch water shield at door latch. Pinch the exposed adhesive surfaces together to secure the water shield. Check to insure water shield is not showing through the door shut-face latch access hole. See Figure B.
13. Attach cable to inside door handle assembly and snap cable housing into slot.
NOTE: Make sure the cable housing is fully seated.
14. Check the gap as shown in remote control using a 3/16 drill bit shank end. The drill bit shank should fit in the gap without any clearance and a tight fit is preferred. See Figure C.
15. If the drill bit is too loose or does not fit, adjust by bending the cable bracket as required.
16. Place plastic wedge on remote bracket as shown. Wedge must fit with at least a light press fit for retention. See Figure D.
17. After installation, Apply a dab of special Teflon grease, supplied with the service cable to cable housing openings at inside handle end. The grease should surround and contact the cable all the way around, to seal the opening between the cable and the cable housing.
18. Check all latch functions to insure correct assembly of latch system. If the inside handle does not release properly, replace the inside handle remote release mechanism.
19. Reposition and install trim panel using new push pins if required.
Dec 07, 2010 | 1993 Ford F250
We broke the door handle on our Malber 1000 Can we order a new one and can we fix it ourselves?
Mike, in Washington D.C., again. Of course you can do it yourself. First call Joel (Malber in NY) at 800-600-8913 or 516-294-6660 . Tell him which model machine you need a door latch for (if you aren't sure, check label in rear). Once you've received your new latch assy (about $20): Open door, and notice white plastic "ring" around glass is actually 2 pieces (front and rear) snapped together - with a seam around periphery. Unsnap (separate) them by either getting your fingernails into the seam and pulling them apart - or prying them open with a spackle knife or thin screwdriver blade. Once it starts coming apart, just work the opening all the way around. Remove front "ring" and set aside. Using a 1.5mm Torx screwdriver, remove 2 small screws holding broken latch assy. Note the way the ends of the spring go under the 2 screws. That's the way it has to go back. Slip new latch assy into place, pressing vertical "hinge pin" and ends of spring into slots (near screw holes). Replace 2 screws. Test latch with door open - is it working? Try closing door. All good? Replace front "ring": Open door and, while pulling out on latch handle, slip the ring over the latch handle and get it into approximate position. Let go of latch (it snaps into "closed" position) and adjust ring so it doesn't bind the latch handle (meaning it's free to move). Now, beginning anywhere on outside edge, begin snapping rings together - and continue all the way around. Test that door latch still operates smoothly and that door latches shut properly. FYI: There is no adjustment for this latch assy - it just fits precisely where it's supposed to. Good luck and God Bless ...
Sep 26, 2010 | Malber WD1000 Front Load Washer/Dryer
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a 99 528i, driver side door won't open from inside or out.
to be honest i would need the car in front of me to diagnose correctly but from the sound of it the mechanism inside the door is worn,the lever that springs open the jaws has worn to the extent that it will not push the two contacts inside the lock open to allow the door pawl to swivel around releasing the door.Only way is too remove the door trim if you can and operate the mechanism with a big screwdriver to open the door then renew the mechanism
Mar 08, 2009 | 2008 BMW 528i Sedan
Both front doors on my "93" Corsica won't open.
You have to open the Window all the way And I Assume your looking Down Threw the Glass opening to View the Linkage,
their is a Spring for the Return of the latch, While looking at the Latching system, Look for the Spring that When you "Try" to open the Door it's Suppose to Compress, Most likely the Spring is Not Fully Releasing,
You may try WD40, And work the handles for a few mins and Then Try to Unlock the door for it to open, OR you can Try a LONG Screw drive to Slide the Spring to fully Non compressed state and then Make sure the Door Lock is in the Open State before you try the handles..
Feb 03, 2009 | 1995 Chevrolet Corsica
Belling SGE12X Front Load Washer / Dryer Logo
467 people viewed this question
Top Belling Washing Machines Experts
shaun taylor
Are you a Belling Washing Machine Expert? Answer questions, earn points and help others
