Question about Jetway N2VIEW Motherboard
Boot problem Hi I just got done putting my MB together and I go to boot up the post screen comes up and after I get a blue screen from windows saying A problem has been detected and windows has been shutdown to prevent damage to your computer. If this is the first time you have seen this Stop error screen, restart your computer. If this screen appears again follow these steps. Check for viruses on your computer. Remove any newly installed harddrives or hard drive controllers. CHeck your hard drive and make sure it is properly configured and terminated. Run chkdsk /f to check for harddrive corruption, and then restart your computer. Well I took my HD and put it into another computer and it booted up fine so now what.
Was the operating system installed on another computer? Or a computer with different hardware? If so the drivers for the hardware are not configured properly on the HD or in the BIOS. If this is the case you should format the HD and re-install the OS.
Posted on Apr 11, 2007
Windows 7 not installing in Hp XW4100 workstation
Sounds like you need to format the hard drive then try a new install
Jun 21, 2012 | HP Workstation Xw4100 PC Desktop
How to dual boot xp and vista?
First of all partition a drive up. Make sure its a large capacity drive, something well over 100GB.
Boot the computer with CD/DVD set as the first boot device and pop the XPmag-glass_10x10.gif CD in the drive and allow setup to begin. When you come to the screen where you select the drive partition you should see the drive listed with all the space listed as unpartitioned. If the drive was in use previously, you'll need to delete all the existing partitions. To do this you'll have to hit the 'D' key followed by the 'L' key. The screen instructions will be visible to guide the process.
Once all the existing partitions are deleted the display will show the total unpartitioned disk space.
Hit the 'C' key to create a partition. Personally i partion mine to 80GB (81920MB)
On the newly created partition, (not the raw one) install XP on that. Carry on with the installation until its final restart, it will be a light blue screen.
Quickly pop the Vista disk into the drive and start the Vista install. When it askes where you want Vista choose the unallocated partition. If you let XP load up first then you will not have the dual boot option on start up.
If you have done this correctly then each time the computer restarts during Vista install you see a boot message on screen saying "older version of window(XP) and Vista.
Lets Vista fully install right up until it loads the welcome screen. Then you can restart the computer, choose older version of windows to complete and load the XP operating system.
You then have to switch between them both to install drivers, software etc.
If you want to use both operating systems at a time then you need a virtual operating system installed but they are not that good as memory is kept at a minimum.
Good luck and please post back if you need anymore advice.
Regards.
Jul 15, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
I have i think a copy of Windows Home edition with service pack 1 which with the online updates has now been updated to service pack 3. Now I want to reformat my computer but when I put the disc in it wont...
You will have to boot from the CD to do what you envision. Put your CD in and turn on the computer ... if it boots from the Hard Drive ... you must go into the BIOS and change the boot priority. You will probably have to hit f2 or f8 or f12 or some other key depending upon your computer manufacturer - during the POST (Power On Self Test). Go to the boot priority screen ... make the CD a riority over the hard drive ... reboot and try again.
Thanks for your interest in FixYa.com
Jun 14, 2010 | Microsoft Windows XP Home Edition Service...
Ran the Tshibery disk recovery disk. Completed and
Complete the recovery again but leave the discs in the computer. That way if the computer needs some files while rebooting it will take them off the cd....if not it will load and that will be the end of that. Just remember when you boot the computer for the first time to initiate the recovery, when it says to boot from cd touch any key...that is only done one time when you first initiate the recovery...after that do not touch any key if it says that...just let windows boot on it own. Once windows boots on its own, then you can take the recovery disc out and put it away.
Sep 07, 2009 | Toshiba Satellite A60 Notebook
Blue screen when trying to boot windows
you have the "blue screen of death" i had this same problem and the easiest way to fix it is to take the hard drive out and put it into another computer back up all files you want to keep on it have a boot disk for the right windows operating system on it use the boot disk with it once it is back in the right computer and then put all the files you saved back on it. the blue screen of death occurs when there is a registry error on your computer. if the blue screen of death appears again then you need a new computer.
Jun 30, 2009 | EliteGroup nForce3-A Motherboard
Toshiba Satellite 1800 Disk Drive Problem
There's an issue with the way yout laptop is booting, either its set to the incorrect boot device or windows cant properly access the hard disk. Take it into a PC repair centre.
May 17, 2009 | Toshiba Satellite 1800-S253 Notebook
Hard Drive Not detected/Windows still boots
Try setting the first boot device as the device with the boot sector on it.
Feb 26, 2017 | Computers & Internet
Blue screen
ok next try to repair ur windows using windows xp installer....to do is put ur windows xp then boot cd... then r for repair....but not the first r i mean first r is the recovery console just enter then the u see a second r...thats it click r to repair window...if it happen blue screen again maybe ur memory have a problem...hope it can help you
Sep 02, 2008 | ASUS MB M3A78-EMH HDMI RT Motherboard
I replaced motherboard and can't boot-up
When you say posts, I assume it can get to the BIOS setup screen. Does it recognize any of the HD's? Your ATA controller or SATA controller may not be enabled. I wonder if the Windows installer detects a major hardware change and refuses to work under their obsurd anti-piracy policy.
Feb 12, 2008 | EliteGroup nForce3-A Motherboard
Trouble with appian typhoon
Sounds like a nice setup! And just for the record, the company did not go out of business but changed the name of their business (now calling themselves "colorgraphic". You can find the necessary info by going to http://www.appiangraphics.com and selecting Support->Appian (http://www.appiangraphics.com/newsite/products/typhoon_downloads_manuals.html). I would recommend going into the Desktop Management Control utility (once you are booted up) and make sure the "boot to Single Screen" option is selected. From what I read you should still see everything but it might be spread across the two screens. Has this been the case since day 1 or is this something that used to work OK but no longer does? That would help a bunch. If it used to work and now doesn't, can you think of anything you might have done to cause it, like recently installed software or Windows update? The above website should give you the necessary information to solve the problem. It does appear they no longer provide support for the Appian cards (which are really just ATI cards). Good luck!
Dec 06, 2006 | Appian Graphics Typhoon (64 MB) Graphic...
Jetway N2VIEW Motherboard Logo
112 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
