Question about Apple Audio Players & Recorders
Hand me down ipod is locked and I can't reset it
  • Dawn Waddle Feb 16, 2012
    thanks for the help! The "home" button needs to be replaced. Now searching for a good repair man.
  • 25 Answers
Hi there check this link :http://support.apple.com/kb/HT1320
i hope this information will help you Best regards
Posted on Feb 16, 2012
HOW TO UNLOK THE A1136 IPOD
click start control panel scroll to folder options tick in the box to show hidden files and holders
connect your Ipod to your computer
click start click click on you Ipod to open
then go Ipod controls device there should be a folder saying locked
right click select rename to open or delete the folder your Ipod should now be open
or you might do a factory reset
The iPod A1136 is the fifth generation iPod from Apple that uses a click wheel to scroll through your device's media library, and may occasionally lock up when you attempt to play a song or display a photo.
This error error occurs when the hard disk is unable to access the information and stalls while opening a file.
A reset of the device usually corrects the problem, as it clears the device's memory and any errors.
Check your iPod's buttons to determine if the cause is due to a hardware error before resetting the device, as the problem may be due to the iPod's hold switch.
Slide the hold switch at the top of the iPod to the right, and slide it back to the left to ensure the switch is in the off position.
Hold down the center button in the click wheel, and at the same time hold down "Menu" on the click wheel.
Continue to hold the iPod's buttons until the device's screen shuts off, turns back on and shows the Apple logo.
Plug the iPod's connector cable into the dock connector on the bottom of the iPod.
Plug the other end of the cable into your computer's USB or FireWire port to charge the iPod.
Wait at least two hours for the iPod to charge. Launch iTunes on the computer, and click "Controls" of the iTunes menu.
Click "Eject iPod" in the sub-menu to disconnect the device.
The iPod takes four hours to completely charge its battery.
hope this helps
Oct 18, 2012 | Apple Ipod Video 5.5 Gen Black 30gb Mp3...
hope this helps
Oct 18, 2012 | Apple iPod MA446LL/A MP3 Player
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Jan 05, 2012 | Apple iPod nano
Enter code i pod \
Hi
Things You'll Need
Dec 30, 2011 | Apple iPod nano
I pod touch enable
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod and you can reset it to factory defaults.
Nov 27, 2011 | Apple iPod touch
My ipod touch is locked and i forgot the passcode
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod and let you restore it without the code.
Nov 26, 2011 | Apple iPod touch
How do I enable a disabled ipod touch?
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod. Then you should be able to restore the iPod back to factory defaults.
Nov 24, 2011 | Apple iPod touch
How to restore your ipod through itunes if its disabled and you dont remember your four digit passcode
You can reset it using iTunes. Open iTunes, plug the iPod in using USB, then turn of the iPod, once it's off hold down the home and lock buttons for 10 seconds, then release the lock button while continuing to hold the home button. After a few seconds iTunes should detect the iPod. Then you should be able to restore the iPod back to factory defaults. Even if you've forgotten the passcode.
Nov 21, 2011 | Apple iPod touch
My ipod is disablesd how do i restore it
Nov 01, 2011 | Apple iPod touch
IPod 30 GB stopped working
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod.five_rs/
If there is no effect, then you have to contact apple, or your dealer for repairs, becouse a part is most likely damaged.
If you need more assistance let me know. Good luck.
Jan 13, 2008 | Apple iPod MA446LL/A MP3 Player
51 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
