Question about Epson Office Equipment & Supplies
Reset epson paper counter - Epson Office Equipment & Supplies
4 Suggested Answers
gwbm
  • 353 Answers
SOURCE: My epson stylus c86 is
TONYCRVTTE and NOVGUNS
Have a look at:
http://files.support.epson.com/htmldocs/sc86__/sc86__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
If it's a paper jam, look for and remove paper in feed system. If no paper, is the print head properly parked under the right-hand end of the cover? If not, you may have stuck or detached parking mechanism. Come back to me if this is the case for further help.
If it's "internal error", it usually means the waste ink pads need changing. You can overcome this problem temporarily by using the SSC utility - download from
http://www.ssclg.com/epsone.shtml
and reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C86 Service Manual". You will often find them
for sale very cheaply on E-Bay.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help.
Please rate this advice.
Posted on Feb 15, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
  • 4 Answers
SOURCE: T11 Counter Reset
SSCLG can not counter reset the new T Series printers... please check
http://inksystem.vacqum.com
There is an adjustment program for T11 you can download..
follow the readme file and you are good to go
Posted on Nov 12, 2009
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Why my epson stylus c 67 ink and paper flashing alternately and cannot print, printer occured a problem
Look at this link for the app to reset the waste pad ink counter, and the video helps too; remeber to clean your waste ink pad because it can spill ink to your desk in a extreme case; you need to open your printer to clean the waste ink pad; search for instructions online.
PD: I have reset my counter six times and cleaned the waste ink pad two times; after six years I keep using my printer correctly.
http://www.dailymotion.com/video/xgkbji_resetting-protection-counter-on-epson-printer-ssc-service_tech
Jan 09, 2013 | Epson Stylus C67 Photo Printer
When i turn on the printer all the lights are blinking, i have reset the printer many times, restarted my computer and nothing has worked to help the problem. I just printed yesterday with this printer...
The Epson Stylus Color 880 has 4 LEDs. If all 4 are flashing or blinking then the printer has a maintenance request error. It means that the waste ink counter has reach its limit. The remedy is to replace the waste ink pads and reset the waste ink counter. You can use the SSC service utility to reset the protection counter. You can download the utility from here http://inkjetprinterhelp.us/epsonSSC.html
You can also use the control paler to reset the counter. Timing is the key to success when you reset the counter using the control panel so keep that in mind. To reset the protection counter using the control panel (front panel):
Step 1.Turn the power on while holdint the following buttons doen. Paper feed, cleaning button. (thr paper out light will flash for 3 seconds)
Step 2.While the paper out light is still flashing press the cleaning button for 10 seconds. The following leds will flash in sequence Ink out lights black and color, Paper out light. Once the printer starts to initilize the counter should be reset. This will reset the protection counter.
Feb 17, 2011 | Epson Stylus 880 InkJet Color Printer
I have epson stylus photo r230 printer. when i give print, the paper stops in the middle and centre red light start blinking
Hi!
I believe your waste ink pad counter registers that it is already full.
You may reset this counter by using the SSC Service Utility for Epson.
You may download it here: http://www.ssclg.com/epsone.shtml
Reset and Reboot.
Feb 14, 2011 | Epson STYLUS R230 InkJet Photo Printer
Hi, epson c66 has 2 red lights on. no paper stuck and cant move the cartridges to change. any idea
hi dude
your printer's ink waste pads are full and the counter needs resetting Try this site and software
It allows resetting of the counters, and gives much more control over cleans etc. (Also will allow cleaning when the red Ink light is flashing)
Aug 10, 2009 | Epson Stylus C66 Inkjet Printer
Same problem nothing words showing on paper!!!!!
Check if your resetter need to date setting first. set date to 1 Jan 2007. Run program. select particular adjusment.menu waste ink counter. Click main pad dan platen counter. check and initialization.Turn off. Turn on again and check it.
Jun 16, 2009 | Epson Stylus Photo R390 InkJet Printer
I have an epson photh R300. The ink and paper light blinks. i put all new ink in it and it says "printer parts at end of service life." It won't move or do anything after that all I can do is...
the printer's counter shuts the printer down after "x" number of prints, since the ink-pad is typically saturated with excess ink at that point. You won't have to take it to get serviced if you simply blot the excess ink from the ink-pads and reset ther counter. To reset the counter, download this program and install.
http://inkjetprinterhelp.us/epsonSSC.html or http://www.ssclg.com/epsone.shtml remember to blot excess ink off the ink-pad, and then follow the instructions to reset the counter. Good luck!!! JohnsGroovyWebsite.com
Aug 02, 2008 | Epson Office Equipment & Supplies
Resetting ink counters on epson c42ux
You can try the other software you can use to reset the counter.
http://www.coldreset.com/modules.php?name=News&file=article&sid=95
Also make sure that on the ssc software, you have selected the correct printer model.
http://www.ianwillis.co.uk/c42/
Mar 24, 2008 | Epson Stylus C42UX InkJet Printer
Ink and paper led lights flashing
you really needed to download that resetting ink counter, to refresh the counter back to zero... printing might have reach 5000 copies, it has really a counter thing... go to the link below and get it, instructions are there too.
Oct 24, 2007 | Epson Stylus Photo R200 InkJet Printer
Epson CX3200 printer error
i just fixed the problem .. you have to reset the protection counter FIRST .. then do the reset using the triangle and colour buttons.. this it the link for the SSC utiliity to reset the counter www.ssclg.com/epsone.shtml .. my printer works fine again
Oct 18, 2007 | Epson Stylus CX3200 All-In-One InkJet...
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
