Question about Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook
Display is too Dark to work with but brightness lever up to max.
My mac book display remains dark (barely visible- not a workable level) but I can see the display brightness is turned up to the full.
  • Anonymous Mar 28, 2014
    mac is permanently dimmed even though the brightness is set to max
  • 536 Answers
Apparently the backlight for your display is failing. You'll most likely have to have the top half of the macbook replaced per Apple usual service standards.
Posted on Feb 26, 2012
3 Suggested Answers
  • 502 Answers
SOURCE: Screen is dark or dead on my 17" Macbook Pro
This could be a backlight issue, a board issue or an inverter issue. Look at the screen closely, if there is a faint image it's either a backlight issue or inverter issue. To weed out between the two you can just order on inverter, they're 20 bucks on ebay, if that doesn't work, replace the backlight. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, you'll most likely have to google for guides that show you exactly how to replace the backlight or bring it in for repairs.I work for Mac Repair NYC and i have to fix this problem a lot.
Posted on May 27, 2009
SOURCE: Mac laptop displays minimum brightness
Check to see if there is a box right below that... Saying something along the lines of readjust to brightness of surroundings, etc!  Make sure box is unchecked for you, in regrds to your issue and then see if that helps!  I will look a little further into it for you!  Let me know if that helps though!
Posted on Feb 23, 2008
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
Led display shut down when the detector detect an alert
You have the unit in dark mode. Press the Dim/Dark button again to get the unit to full brightness. THe unit has 3 levels of DIM. First the unit is at its full brightness, pressing the dim/dark button will dim the display and the unit functions normally. Press the Dim/Dark button again will futher darken the display but when the unit alarms the display is turned off and remain off during the alert. After the alert is over the unit waits 20 seconds of no alert to turn the display back on.
Mar 09, 2011 | DE-1740 Radar Detector
My display is very dark - can barely see pictures on the display. The fn brightness button doesn't respond. Gateway laptop model M305CRV. Please help
control panel,display,settings you can make adjustments for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general
dpi normal size,larger size or custom settings
hope this helps
Nov 11, 2010 | Gateway M305CRV Notebook
Itouchs brightness is really low but the brightness level high
You tried setting the Brightness to maximum, but the screen remained dark? Could be a problem with the LEDs that light up the screen. Also try turning it off and back on.
Aug 08, 2009 | Apple iPod touch
Display is very dark
Dim screen is usually caused by a bad inverter board especially if you get video to external monitor. Usually cost $100-$200 depending on laptop.
Hope this helps!
Jun 11, 2008 | Toshiba Satellite M45-S331 Notebook
Screen really dark
Did the screen come that dark, or did it go dark recently? Backlight may have burned up, panel may be bad. Had a similar occurance with a Creative Zen- can't fix these things. All you can really do is return it.
May 23, 2007 | SanDisk Sansa e250 MP3 Player
Dark image
Flyback transformers usually have 2 adjustable rods - 1 is for focus the other is for screen (G2) voltage. try turning Clockwise the Screen adjust with brightness-contrast at max. Till you see white diagonal lines, then go back until the lines disappear - then tune the brightness to your desired level.
Apr 27, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
Dark screen
Please check your user manual. There is an save mode. Leaving the save mode will solve the problem. If you need more help please advice.
Jan 12, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
Apple 13-inch MacBook - Intel 2.0GHz Intel Core 2 Duo, 2GB 1066MHz DDR3 SDRAM, 500 GB SATA H... Mac Notebook Logo
205 people viewed this question
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
