Question about Vtech V.Reader Interactive Reading System
How to calibrate Vtech Storio?
The touchscreen of my daughters computer is not working well. When I touch to one point, the computer touches other. I tried to calibrate it on my pc, but after calibrating it was the same (I used downloaded Explor@ Park).
Https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Posted on Nov 28, 2012
  • berniebug64
    berniebug64 Nov 28, 2012
    https://vtech.box.com/s/68ee102d30c31a7c...
    reader)
    computer menu
    •Double click the
    •From the drop down
    •When the following
    •Once the format is
    •Please note, once
    https://vtech.box.com/s/68ee102d30c31a7c5a4d
2 Suggested Answers
SOURCE: Ik krijg een zwart beeld met touchscreen
Even bellen met de klantenservice van VTech (www.vtechnl.com) dan krijg je een SD-kaart toegestuurd en met die kaart kun je de Storio resetten en updaten. Het heeft namelijk te maken, werd mij verteld, met een update die ik niet heb uitgevoerd. Daarna zou het niet meer voor mogen komen.
Posted on Oct 27, 2011
The touchscreen of my sons vtech storio wont work, even after calibration? he only got it yesterday for christmas!
connect your toy to the Learning Lodge. Go to Calibrate Touch Screen option....make sure that you are also using fresh batteries.
Dec 26, 2013 | Vtech V.Reader Interactive Reading System
My Vtech V-reader freezes on calibration screen
I just found a solution to this: Turn off the vreader, then press & hold the help "?" button. While holding the "?" button, press power. My system bypassed the calibration step and booted correctly.
Jan 05, 2012 | Vtech V.reader Reading System
Vtech storio in touchscreen calibration mode
Hello I buy my son the V.reader for christmas the next day it say Touchscreen Calibration Utiliy, Touch crosshair to calibrate I need help
Dec 28, 2011 | Vtech V.Reader Interactive Reading System
Ik krijg een zwart beeld met touchscreen calibration utility op mijn storio, naar 4 maal drukken op kruis slaat hij vast en doet niks meer
Oct 21, 2011 | Vtech V.reader Animated E-book System
It keeps saying touchscreen calibration utility touch crosshair to calibrate. we'v done everything that we could to fix it. it will not go back to the page with activities.
I need help I buy my son V.reader for Christmas it say Touchscreen Calibration Utility Touch Crosshairs to calibrate. I need help? how do I fix it?
Aug 19, 2011 | Vtech V.reader Animated E-book System
Does not work on the edges, can not access start by touching. when the screen is touched the arrow appears about half an inch away
Sounds like the calibration for the touchscreen needs to be reset. If you check in the control panel, there should be a ELO shortcut that allows you to calibrate/test the touchscreen. Try running through the calibration and see if the touchscreen behavior improves. If the calibration doesn't fix it, then you may have an issue with the touchscreen itself.
Mar 07, 2011 | Elo CarrollTouch touch-screen Monitor
My garmin nuvi 660 touch screen dosen't work
To calibrate the touchscreen on a nuvi 300 or 600 series:
  1. Power the unit On.
  2. From the Where to? / View map screen, touch Settings (wrench icon).
  3. Touch Display.
  4. Touch Recalibrate.
  5. A new screen will display that says Press Dot.
  6. Touch the center of the dot.
  7. Keep touching the center of the dot as it moves around the screen.
  8. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated.
If your touchscreen is not responding to any touch and preventing you from recalibrating the touchscreen using the instructions above, please follow the steps below:
  1. Connect your nuvi to your computer with a compatible USB cable.
  2. Open the Garmin Nuvi drive located in MyComputer/Computer. (Note: Mac users can locate the Garmin Nuvi drive icon on the Desktop.)
  3. Open the Garmin folder.
  4. Locate and delete the GUPDATE.GCD file.1
  5. Safely disconnect your nuvi from your computer.
  6. Power the nuvi Off.
  7. Power the nuvi on by holding the power button.
  8. Continue holding the power button down for 1-2 minutes until the screen calibration option displays.
  9. Touch the center of the dot as it moves around the screen.
  10. When Calibration Complete appears on the screen, please touch OK.
The touchscreen will now be recalibrated and should respond properly.
Oct 24, 2010 | Garmin Nuvi 660 GPS Receiver
I have a garmin nuvi 660. the touch screen isn't working
  3. Touch Display.
Oct 24, 2010 | Garmin nuvi 650 GPS Receiver
My touchscreen is off point, and my calibration wont work
have you tried reswtting it to factory settings. make sure there is nothing putting pressure on the touch screen. If this soesnt work you may have to replace your touch screen. mysciphoneshop.com offers replacements, but they have to be soldered in be careful if you decide to do this.
Apr 04, 2009 | Dual Electronics CECT P168 Cellular Phone
Vtech V.Reader Interactive Reading System Logo
1,121 people viewed this question
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
Are you a Vtech Toy Expert? Answer questions, earn points and help others
