Question about Hitachi 57S715 57" Rear Projection HDTV
Video input from dvd player shows as black screen w/ squigly color lines
I used to be able to play dvds on my hitachi hdtv. now, i start a dvd and get a black screen w/ squigly color lines. if i move the video plug to the adjacent plug to the left, the dvd works but only in black and white. audio is ok. i had the dvd player serviced.
    Problem Solver:
  • 5 Answers
Have you tried other devices for input...vcr, or other dvd players to see if it is a problem with the player or with the tv? Check the output setting for the dvd player (1080i etc) and ensure you are connecting to the proper inputs for either analog or digital signals (RCA inputs or RGB).
Posted on Nov 24, 2007
  • MIchael Van Ness
    MIchael Van Ness Jan 01, 2008
    Found out from another blog that I had a bad crt assembly.
Why GE TV plays color DVD/VCR tapes in black and white
Some inputs on tvs won't process the color signal. Try one of the other inputs. Mine does the same. If u have already used the working ones on something else, U will need a switch to select one or the other available at Radio Shack if u can find one.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_9c859f4aa7e5ab10
Jan 22, 2018 | GE Televison & Video
I have a Fisher DVD-S1100 DVD Video Player. Several years old. While it still plays DVDs, the color is gone and display is simply gray and white. Is this a common failure mode (it is not listed in...
Hello
Does your TV have two
separate video inputs, or just two sets of video input jacks and only ONE
video input
Try disconnecting your VCR from the TV (or turning it off) and see if the
color comes back on your DVD.
Also make sure that your video connections are properly connected(check your manual for how to connect the AV cable)
Also, try playing the DVD in your computer and see if it is black and
white on your computer monitor too. If so, then it is supposed to be in
black and white.
Apr 11, 2011 | Fisher Televison & Video
Can i connect a regular dvd player to a hitachi flatscreen hdtv?
Yes you can. Simply connect the appropriate color inputs.
If you use red green blue for video, and red white for audio you will get the best picture
If not stick to yellow for video and white red for audio
Just remember color that is on the back of dvd goes to same color on the input for the tv
Mar 21, 2011 | Hitachi P50H401 50 in. Plasma HDTV
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar).
Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV.
Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row.
Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV.
Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will).
Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal.
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
Mar 15, 2011 | Audio Players & Recorders
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
Feb 23, 2011 | Kenwood VR-406 Receiver
Bose lifestyle 48 dvd black and white only
Go to the "Bose" menu screen viewing on your TV (make sure no dvd is in the player) Go to your Video controls and check your output, chances are, if your using the component output your player is set to "S-Video". Should fix the problem. Hope this helps. If it's still not viewing correctly, post a comment and I will help you some more
Jul 26, 2009 | Bose Lifestyle 48 System
Prima HDTV has a black screen on TV, but works fine while Playing DVD
try turning the channel up or down with the tv remote to input 1 or 2 depending on which one is being used for the dvd player. tv should use input 1. dvd should be on input 2.
when turning the channel set it to show the dvd screen, then go up 1. if it doesn't show, return and go down 1.
Oct 22, 2008 | Prima C2012 TV
Confused about Connections
Bob, you can do this, grab 3 rca cables, 1 yellow 1 red 1 white.
the holes on the back of the dvd are colored coded, you guessed it yellow ,red, white, plug the cables into the matching colored holes, your done with the dvd player, now take the other end of these 3 cables and guess what the plugs on the back of the tv are the same color code as well, take a flashlight and find the 3 colored holes marked " input 1" stick the yelloe cable in the yellow hole , red in red hole, white in white hole, turn on dvd player & tv, grab your remote for the tv and find the input button and push it until the screen show "vid1" or "video 1", input 1 what ever yours says and you`ll be watching your dvds. Good Luck & Happy Holidays, BMW Rider
Dec 01, 2007 | Hitachi 57F500 57" Rear Projection...
Dvd into vhs input
If you can watch TV normally then it should be a button on your VCR remote. It could be "Input", "Line" or "Aux". Tvs with more than one input line will may require 2 presses on that button, one for each line. This is the best answer that I can give not seeing your remote. Any questions?
Nov 07, 2007 | Hitachi VTFX685A VHS VCR
Hitachi 57S715 57" Rear Projection HDTV Logo
101 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
