Question about Sharp R-1874 Convection/Microwave Oven
Trying to remove 1874 Microwave from 05 Dynasty. Mounted in slideout
This unit has no cabinet above and no front plate added above. I found the 45 degree bolts uder the microwave but am unable to locate top or side screws holding the microwave up and allowing it to release. Would appreciate any help. Damper motor is dead and going away next week.
Dynasty, There 2 long bolts toward the front floor of your overhead cupboard, could be under false floor of same. The lower underside will possibly be secured to mounting plate at back. Be sure to remove these screws otherwise you may bend your mounting plate.
Posted on May 22, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp R-1450 micro over range removal
Those specific installation instructions are no longer available, but I have a couple for other models that may be close enough to help.
I have uploaded them here and here.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 21, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: removal from a motorhome
We regularly repair the circuit boards of microwave which are hit by storm surges, etc.
This repair usually runs $39.95 to $64.95, depending on if we have to replace the low power transformer. I just thought I'd mention this if you're interested.
But if you've decided on replacing it, the installation manual should be helpful in removing it from the wall. See it here.
You will need the free Acrobat Reader to view or print it.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
Posted on Oct 06, 2008
erpaalai
  • 999 Answers
SOURCE: I have a Sharp Carousel II microwave oven mounted
Model number is on the side of the control or along he bottom of the frame. The control panel should be removable with a screw or 2 and sliding up to unlatch. the fuse is behind there. To remove it off the wall there is 2 screws coming down from the cabinet above and the unit tips towards you and lifts up off a lip on the back plate. Eric
Posted on Aug 11, 2009
  • 1891 Answers
SOURCE: Trying to remove my Sharp R1830 microwave. We
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Posted on Jan 10, 2010
Testimonial: "Thanks so much...appreciate your help. The old microwave is now off and a new one in its place! Thanks again!"
MicrowaveSvc
  • 9047 Answers
SOURCE: I am trying to remove
We have the service manuals for these models and have uploaded them to our site here and here to help you.
Or our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you're having trouble with the display or cooktop lights, we solve these problems for the $39.95 with a one-year guarantee.
Posted on Aug 21, 2010
My Sharp Carousel under the cabinet microwave is dead......how do I remove it
Look in the floor of the cabinet...there will be two screws that go down into the Microwave...There can be very long... but turn them out and then tilt the oven down in the front and lift it off of the back plate on the wall...
heatman101
Apr 30, 2011 | Sharp R-1874 Convection/Microwave Oven
Remove mounted GE Spacemaker Microwave JVM140K
There should be 2-3 screws thru the floor of the cabinet above the m/w that secure it in the front. Once those are removed the m/w will slide straight out on rails mounted to the wall plate.
Dec 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do i remove an old oven
It is much easier for two people to remove the microhood. If attempting alone, please move the range out so you can get under the micro to support the weight. If the range stays in place, protect the top from damage.
1. make a landing site to the side, to protect the floor when putting the micro down after removal.
2. Disconnect the power cord in the cabinet above.
3. loosen the two screws in the bottom front corners of the cabinet above. When removed the front of the micro will drop, be ready for the weight. Busy times, tools in hands microwave coming down in front.
4. tilt the front down. pull the cord out of the upper cabinet.
5. with micro still tilted down in front, lift the back of the unit upward to free it from the wall plate.
6. remove the fasteners in the wall plate and remove.
Congrats, begin celebration.
Jul 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do I remove my Hotpoint microwave RVM 44004? Two bolts visible from the cabinet down into the microwave. Removed them with zero result. No other fasteners visible in top or side cabinets.
1. make a landing site to the side to protect the floor when putting the micro down after removal.
Jan 20, 2010 | Hotpoint RVM1435 Microwave Oven
How do you un-install a kenmore 665.61639100 microwave?
the link below will take you to the installation instructions if needed.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0211226.pdf
Dec 26, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
I can't find bolts or screws that hold the unit in place. I need to remove the microwave in order to install new one.
HI there,
Here's HOW;
  1. Remove the face plate above the door.
  2. There were 2 bolts in which you will need a screw driver to loosen it
  3. This bolts go all the way to the back of the microwave.
  4. You still need to remove the one - three screws that's above of the cabinet. You may have to jar it loose if it still stuck.
Hope this helps.
Let me know for further instructions.
Aug 04, 2009 | Microwave Ovens
How do I install a replacement Frigidaire over the stovetop microwave - professional series, without removing the cabinet above it? I need to know how to best remove the existing microwave.
Remove everything from the inside of the microwave, (such as glass tray). Unplug the microwave, probably in the cabinet above. There are two screws in the cabinet above the microwave, near the front, that supports the front of the microwave. The back is hooked on a mounting plate attached to the wall behind it. An assistant is a good idea though this can be accomplished alone. It is best to move the stove out, if you are going to try alone. Please be carefl there is considerable weight to support here. Support the front of the microwave while the two screws are removed in the cabinet above. Slowly tilt the front of the unit down until you can pull the cord out of the bottom of the cabinet. With the front still tipped down, lift the back from it's support and remove it.
Jul 18, 2009 | Microwave Ovens
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Nov 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Sharp R-1874 Convection/Microwave Oven Logo
98 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Jim Thurston
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
