Question about Samsung RS2630SH Side by Side Refrigerator
Loud running motor
The motor/fan in the back (seems to be refrigerator side), is loud. It is on and off. It did this a few months ago and stopped on its own. Now it is up and loud again.
  • Samsung Master
  • 19,396 Answers
It is a compressor problem, you may need to check the compressor.
Posted on Oct 25, 2008
  • Ginko
    Ginko Oct 25, 2008
    Inside the compressor there are springs that hold the motor assembly, and the assembly is banging beacause of high back pressure, as the condenser does not work as it shoud, preventing high back pressures.
    Try moving the refrigerator a bit away from the wall, leave airy spaceon the side that gets hot, where you have the condenser.
  • Samsung Master
  • 13,433 Answers
I think its best you replace the fan, its probably at the end of its life and starting to make more and more noise. This happens alot in computers if the fans are poor quality.
Frig is making loud noise when it turns back on to cool.
proberly ice build up around the fan motor.You may have a defrost problem.
Oct 16, 2014 | KitchenAid Whirlpool Kitchen Aid...
Replace motorized damper
It may be possible that water is splashing from the icemaker fill tub and running down into the fan area and freezing. When the refrigerator goes into defrost the ice thaws and the noise stops.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Jan 10, 2008 | LG French Door Cabinet Depth Refrigerator...
Amana bottom Freezer Refrigerator
Fan motor probably iced up, turn off defrost for 24hrs with doors open turn back on and should be working within 24hrs. Regards Advisor
May 14, 2007 | Amana ABB1927DE Bottom Freezer...
Samsung RS2630SH Side by Side Refrigerator Logo
238 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
