Question about Black & Decker Garden
How to feed a b - Black & Decker Garden
    Sergeant:
  • 316 Answers
Hello,, how to restring black & decker,worx,ryobi,sears cordless and corded trimmers,, turn trimmer upside down,make sure bottom is clean,, push in the two tabs and pull bottom piece out,,remove the black spool,remove any old line and make note how string is attached to spool,you will need 30ft.of # 65 line some stores has this pre packaged for your b&d, insert the lone in the grove or hole and follow the arrow on the spool,line should be wound, now to reinsert the spool make sure that the spool is lined up with the slot to slot on the out side cup also on the auto feed make sure that the small half moon inside clip is towards the center,put spool on making sure to get groves in the spool slot,and get line through hole.put on cap, on the auto feed the line comes out when you turn trimmer on, you should do good to go,hope this help,any comments welcome,thank you..
Posted on Feb 18, 2012
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Why are my facebook settings different on my computer and mobile
The mobile version seems to display the "Pages Feed" (feed of pages you like) and the "News Feed" (feed of people you like) on the same timeline, where the desktop version keeps them separate!
On the left hand menu of the desktop, there is an option for "Pages Feed." There, I found all the posts from my "Liked" pages that were appearing on my mobile news feed, but not my desktop news feed. I clicked on the settings icon to the left of the "Pages Feed," and selected "add to favorites"
Now, on my desktop version of FB, my "pages feed" and my "news feed" are still separate, but at least I can find them
Why is my newsfeed different on my PC iPad and windows phone
Mar 08, 2015 | Facebook Computers & Internet
Unable to pick up papaer on tray 2 error 13.00
common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Dec 13, 2013 | HP LaserJet 5200 Printer
Feed Dogs
when the feed dogs are in the up position the sewing machine
will sew
but when the feed dogs are down postion it will darn
try the feed dog lever again if you can move the feed dog lever and
the feed dogs respond going up and down then you know that
the feed dogs are working and are not broke
but if they do not respond then they need to be checked to see what's
wrong with them
Oct 23, 2012 | Sewing Machines
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
Clark 130en does not feed well. Feeds great on 10
try checking the tension on the feed roller,you may have too much tension which in return will not allow the wire to feed right,check to make sure your feed roller is for the size of wire you are using,next check the tip size for the wire your using.
Mar 17, 2010 | Clarke Power Products Clarke 130EN Mig 110...
How do you get rid of a microsoft feeds synchronization error
Windows Internet Explorer 8
  1. Start Internet Explorer.
  2. On the View menu, point to Explorer Bar, and then point to Feeds.
  3. In the navigation pane, right-click a feed, and then click Properties.
  4. In the Feed Properties dialog box, under Update schedule, click Settings.
  5. In the Feed and Web Slice Settings dialog box, under Default schedule, make sure that an appropriate value is set in the list.
  6. Click OK to close the Feed and Web Slice Settings dialog box.
  7. Click OK to close the Feed Properties dialog box.
Windows Internet Explorer 7
  5. In the Feed Settings dialog box, under Default schedule, make sure that an appropriate value is set in the list.
  6. Click OK to close the Feed Settings dialog box.
Dec 25, 2009 | Microsoft Windows XP Professional
Hp laserjet p3005dn tray1 manual feed problem
you can choose mp first in "paper handing" printer menu or print tray1 is A4 default in properties of printer software.
Jul 25, 2009 | HP LaserJet P3005n Printer
Ep1083 copier
If the machine sees the ADF ( auto document feeder) but does not feed the paper? Does it try to feed the paper? Does it pull the paper is a little and jam? If the machine sees the ADF and it starts to feed the paper but jams --- clean the feed rollers/ tires with rubber restorer or a high alcohol base cleaner. Also a mylar could be pulled into the paper path blocking the feeding of the paper. Take a thin piece of cardboard ( like the devider in a case of pop) and slide the cardboard about 3- 6 inches into the feed just past the feed roller. Gently pull back out and try to feed paper again. If those do not work and the machine does see the ADF, you may need switch, sensor, actuator or feed motor.
Aug 27, 2008 | Minolta EP1083 CS/PRO Copier
Feed dog is stuck
I have the same problem...this is a work around, not a fix. You need a small flat-head screwdriver. 1. Remove the clear bobbin cover. 2. Make sure the feed dog switch is in the DOWN position. 3. Slide the screwdriver under the feeddogs from inside the bobbin area & lift the feed dogs. 4. While holding the feed dogs in the up position, return the feed dog knob to the up position. You have to do this every time you put the feed dogs down...bummer, but I can find no broken part or adjustment that corrects this. If it's inside the machine body, I don't mess with it... I did take off the bottom plate in the feed dog area..one screw holds it.... there is nothing there to indicate a problem.
May 07, 2007 | Singer 2662
Garden Logo
534 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
