Question about ASUS P4P800-X Pentium Motherboard
CPU Not Functioning
Was using my computer. Suddenly the monitor says I need to check the signal cable.
I make sure it's fastened.
Still no image.
Looks like the CD/DVD ROM have no power (or at least aren't responding). On boot up no Windows music and other start up sounds come over the speaker. On our network connection the computer is listed as unavailable.
  • Anonymous Mar 26, 2014
    my screen stay's blank even though the computer is powering it may seem that im nt getting signal even thought it is coming through, coz if i eject the vga cable from the box the screen tells the is no signal bt when i put it in screen goes blank
  • 21 Answers
Sounds like your motherboard died. All the syndromes listed are related to tasks preformed by the motherboard.
Unfortunately you can't fix a dead motherboard.
You can buy a new one fairly cheap, either the exact same motherboard, or one that has all the exact same features.
look at newegg.com or tigerdirect.com they always have good deals
Posted on Oct 25, 2008
VX922 only shows "No Signal" on black screen
The monitor shows no signal probably it didnt detect the tower
Ill be advising you to remoev the cable that conencts the cable
used a clean cot or rug clean both ends of the cable , clean also the area whre you plug in the cable , the ports on the monitor and on the CPU make sure its clean .
Then plugged it in , in case nothing happens
try to used another cable that conenct from the monitor to the CPU
you may aslo try to used other CPU to checked if monitor is working fine or try other monitor to checked if the port on the your CPU is working fine
May 23, 2011 | ViewSonic VX922 19" Monitor Flat Panel
No signal to monitor
Check all conections between the tower and the screen, make sure all are secure, if no joy, unplug the tower and remove the side panel to see if the graphics card is in securely, maybe take the graphics card out and put it back in again to be sure. If you have another monitor or monitor cable try replacing to see if the situation improves.
May 05, 2011 | Acer Aspire M1641-U1521A PC Desktop
Screen said please check video cable connection?
This is an indication that the monitor is not receiving a video signal from the computer. Check both ends of the video cable - both the connection to the monitor as well as the connection to your computer's video card, and make sure that both are secure. If the connections are secure and the problem persists, buy a replacement video cable. If that fails to fix the issue, try swapping out a different video card.
Mar 02, 2011 | HP Computers & Internet
Suddenly today, for no reason, the monitor stopped turning on when the "on" button is pushed. I have checked the cords numerous times, and both the monitor and the computer have been turned off and on...
Try swaping power cables of CPU and monitor. Also, check power button on Monitor. Make sure you have power supply in boards.
Second, try removing VGA cable from CPU and check what you see on screen, if any display like no signal or no vga. That means your Monitor is working but onboard VGA has problem.
Hope this helps a bit to try yourself before taking it to repair center.
May 20, 2010 | BenQ FP71G 17" LCD Monitor
No signal on monitor
Dear Brother,
  • Check your Monitor Cable
  • Check your Cables PINS Broken/Damaged
  • Check Properly Plugged in the Cable to both PC and Monitor
  • Check your Display Card
  • Check your Motherboard Connection With Display Card
  • Unplug the Cables end From PC and Monitor
  • Unplug From Power too and Then Correctly Plug in
  • Connect CPU to another PC(for making Sure problem is for Monitor)
Your Problem can be Solved...... Hope This HELPED YOU Thanks For Using FixYa
Apr 06, 2010 | Mag Innovision InnoVision LT765 17" Flat...
My monitor suddenly lost signal and hasn't returned
do you mean the processor fan that is located near on the left top corner on the motherboard? if that stopped working then turn of your pc immediately. probably the cpu overheated. if that fan does not work replace it immediately as it will burn the cpu.
Jan 25, 2010 | eMachines T6534 PC Desktop
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
No signal when power button turn on
Sounds like either the power supply unit's fan isnt functioning and the the uniy over heats and the computer then wouldnt boot up (to protect itself) or the processor is overheating. But rather seems like a power supply problem
Jul 06, 2009 | Acer AL1916W 19" LCD Monitor
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
Is it my monitor or my video card
1.there might be a problem with your signal cable. if one of the pin in the signal cable is open. it might also happens
2.adjust signal cable.
3.Check VGA video card is working properly. unplug the VGA card and Re-plug to its slot. if your mother borad has inbuilt video card. this process cannot be performed
4.Even problem with operating system might also happen.. problem with Video Ram memory
5.if you want to check whether your monitor is ok. just get Cpu Box alone frm friends for a while for a testing.
6. if your monitor have problem then contact service centre.
Oct 15, 2007 | Samsung SyncMaster 551 15" CRT Monitor
ASUS P4P800-X Pentium Motherboard Logo
145 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
