Question about Indesit W 123 Front Load Washer
Pump pre chamber lid wont open
I have as per instructions attempted to unscrew anti clockwise the pre chamber lid to clean inside due to a leakage problem but find that it will not unscrew. Does anyone have a solution before I get physical with it and break it??
  • timothy_iles Feb 21, 2010
    I have exactly the same problem, it wont turn all the way anti-clock wise to open
I have a PWE8168 and assuming yours has a similar arrangement:
1) Switch off water and electricity feeds;
2) Pull the washing machine forward a sufficient distance to allow you to tip it back so that you can gain access to the area next to the pre chamber lid. I found my tool box was handly at propping up the front!
3) A torch is handy at this point. Lie on the floor, and use a pair of mole grip pliers to release the springs securing the pipe attached to the left of the pre chamber filter (looking from the front of the machine).
4) Note that if you have not been able to drain your machine already your should have some towels/cloths and (eg) a tuppaware container ready to collect all the water.
5) Slide the pipe off and you should be able to get your fingers into the pump pre chamber and fish out whatever is jamming both the pump and the lid. I got a 5p piece for my troubles!
I would not say that this is a particularly difficult procedure and apart from water collecting, should only take 20 minutes, including reconnecting the pipe.
Posted on Mar 04, 2010
To remove lid on the cistern Mrs wants to put a loo bleach block in it for fresh flush
Hi,some of these lids open by turning the out side silver ring anty clockwise as it attaches to the pump inside,hope this was some help,all the best.
Feb 26, 2017 | Lid Home
To open Indesit washing machine IWD5123 pump lead
It is probably not turning enough to allow it to be removed- maybe because there is crud jamming it. try rotating it back and forth to attempt to free it. You could use gas pliers to add more force to turn it, but be careful not to break it.
Apr 07, 2016 | Indesit Washing Machines
Unable to open pump fillter
Remove the kickstrip, front of the appliance. Unscrew the pump filter by rotating it anti-clockwise, A little water may leak from the pump: this is perfectly normal. Clean the interior thoroughly, removing any visible debris. Refit by screwing the filter into place.
Jan 04, 2012 | Hotpoint Washing Machines
My bosch classixx 1400 express washing machine has become very noisy when draining water, it never used to be. Any ideas?
If it is only noisy when draining the water, then could be something stuck in pump.
There should be a filter located at the bottom front right of washer behind a cover.
Unscrew anti-clockwise to remove and clean, and look inside the pump opening as well to see if anything is stuck there.
Apr 13, 2010 | Bosch Classixx WFL 2462 Front Load Washer
My Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
Dec 09, 2009 | Bosch Washing Machines
Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end of the grinding cycle. Make sure that the grinding chamber is completely cleaned and dried before using the grinder.
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Won't spin on last cycle
The pump is supposedly self cleaning.
There's a 'pre-chamber' behind a panel at the bottom on the front. The top of the panel should tilt forward & up. Turn the 'pre-chamber' anti clockwise, after putting a shallow tray under it to catch the small amount of water that may be there.
I think I have a pdf manual (found on web somewhere) on another computer, I'll have a look & send it to you if you can give me an email address.
Feb 24, 2009 | Indesit W 123 Front Load Washer
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
Ihave had flashing lights on a hotpoint wt540p
The pump is actually a self cleaning pump, but there is a filter located behind the bottom kick strip at the front bottom of the washer.
To access it you should see 2 screws in the panel, unscrew these and remove the panel, then you will see the filter,unscew it anti clockwise and remove the filter, clean as neccessary, see if you can see anything in the filter chamber. and refit it. This should solve your problem.
Plz leave feedback.
Ta.
Dec 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine error code f04
ok these machines are great and they make it very simple F04 means cant drain which usually means money or bits and bobs stuck in pump impeller. On the front of the machine remove the bottom right hand plastic cover by hand this is where the access to the filter and pump can be found, you will see a black cap about 3" which can be unscrewed you may need pliers or something to grip it and turn it, have plenty of old towels ready as the water in the machine will begin to come out when you unscrew it(anti clockwise), just unscrew it a little until the water trickles out and mop it up with the old towels until the water stops then continue to unscrew anti clockwise until you are sure the thread is no longer gripping you cant over unscrew so if in doubt just keep unscrewing....then it needs to be pulled out toward you, you will probably need grippers or pliers for this just wiggle it out and remove it, look inside you will see the drain pump impeller, put a finger in and feel for whatever is obstructing it and remove, now use a finger to feel for the inlet that comes into the chamber from the left, use a finger to feel inside this pipe and remove other bits and bobs in the pipeline that were ready to find there way to the pump, once you have removed whatever is in there clean with a rag the thread and scale and make it nice and clean. In your sink wash the screw cap and little white filter piece that is attached to the cap and careful so as not to cross thread it push and then screw it back in making sure the filter solid plastic part is facing toward the inlet pipe you cleaned earlier as its that solid part that prevents (should prevent but didn't or you wouldn't be doing this) large objects finding there way in to the impeller chamber, screw the cap in and restart the cycle and your done, easy repair anyone can do it..... Don't forget to send me your luv if this works for you!!... Nick (at) 2xx.co.uk
Jun 06, 2008 | Bosch Washing Machines
Indesit W 123 Front Load Washer Logo
831 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
neilmoto
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
