Question about Motorola Mobility M25 MP3 Player
Trouble Reformatting...Please Help...
I tried to reformat my player by going to My Computer>Format like it told me to, but it won't respond at all. I searched and someone else had this problem, but the solution someone gave didn't make sense to me. They said you reformat it through the Music Manager. But how do you reformat it through the Music Manager? I don't see anywhere on it that you can do that..
Some have had success with updating the firmware....
Posted on Sep 13, 2006
SOURCE:
My MP3 MF001 worked a few times. then it was restricted to the first 5 music numbers . then it would not play anything. it turns on and off but will not play or respond to the next/last softer/louder...
Most digital mp3 players can be reset to factory settings. Also, By going into start computer right click the hard drive its connected to and quick format. All songs will be deleted and you'll be ready to begin anew.
Jan 03, 2010 | Audio Players & Recorders
It seem to be on but dosent show any music
When you plug an mp3 player into a 2nd computer with a different operating system, a reformatting takes place, rendering it unusable on one computer or another without reformatting the player
Danger: reformatting a player will erase all of the songs on that player
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Jul 07, 2008 | SanDisk Sansa e250 MP3 Player
Bad track error. songs arent deleting after reformatting and resetting multiple amounts of times.
There are 2 ways to format an mp3 player - if you were formatting the mp3 player from "My Computer," then try reformatting from Windows Media Player instead - I have a "tips and tricks" entry on How to Format an Mp3 Player for details
If that doesn't work, then double-click on My Computer, double-click on the Sansa player, and go to the various folders that it lists - music, voice, etc. Delete the songs ONLY - do not delete the dat, bat, ini, inf, or other system files
Jun 08, 2008 | SanDisk Sansa e250 MP3 Player
Possible Hardware Problem?
Reformat the player and reload the songs. (warning: reformatting erases all songs on the player)
If the reformatting causing any issues, you can always rebuild the original software from Dell's own website:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PDA_MP3_DJ_DITTY&os=WW1&osl=en&catid=&impid=
May 21, 2008 | Dell DJ Ditty MP3 Player
Help me out please?? -Frannie Rogers
Try reformatting the device. To do so, go to My Computer. Even if it is corrupt, it should appear there. Right click the drive showing your player and select "Format", "Auto Format", or "Quick Format". If the computer asks you what type partition you want to use, choose FAT 32. You will then need to re-install the firmware. You can get it here:
http://www.rcapearl.com/download.aspx
Make sure to choose the correct version. This will probably be the 1GB version, unless the two others have something different.
Don't forget to vote!
Apr 16, 2008 | RCA TH1101 MP3 Player
My mp3 needs to be reformated and I need to know how to reformat it. Please contact me at jennifermariegordon@gmail.com. Thank you for your help.
To reformat it (assuming you have or have access to a Windows computer) all you must do is plug in the mp3 player to the computer. Go to "My Computer". Right click on your mp3 player and select "Format" or "Reformat". If it asks you what type of partition you should use, choose "FAT32". Most mp3 players use this. If you know for a fact that your mp3 player used a different partition type, choose it. Otherwise, choose FAT32. The computer will do the rest. After reformatting, you may have to download the firmware again. If you can't play songs after reformatting, this is probably why. To get the firmware, try going to the website of the company that manufactures your mp3 player.
Apr 13, 2008 | Audio Players & Recorders
I have tried EVERYTHING and NOTHING is working for this problem
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Mar 31, 2008 | SanDisk Sansa e250 MP3 Player
How dom i reformat it
you need to format your mp3 by clicking the option button in your mp3. do not reformat in computer because it has a different system. after reformatting you need to download the sonique stage this will serve as your player in your pc and automatically transfers the music files in your mp3 once insert this into usb port. hoping that this will help you
Dec 10, 2007 | Sony NW-E505 MP3 Player
Reformatting a hard drive
open my computer, right click your device, select format
Aug 12, 2006 | iRiver H10 MP3 Player
Motorola Mobility M25 MP3 Player Logo
110 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
ka4iup
ka4iup
john h
Andrew Taylor
Andrew Taylor
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
