Question about Gateway MT6705 Notebook
Screen only display 4/5 of it the other 1/5 is pure black but the back-light is on
Here's how it look, took a camshot of it. showing the notification area with the desktop clock and beside it is the black part --- theres no scratch or any line showing on the screen, the back-light of the black part is perfect i can see the it from corner to corner, so i thought i could be the driver or the screen resolution, but i already installed the driver for it..also did the factory system recovery from the Gateway Recovery Center and also tried the Device driver recovery, tried to reformat it to windows 7 and roll it back to vista and reformat it again using the vista os that comes along with the laptop but still no good. the screen still display only 4/5 of it..also tried change the screen resolution from 1024x768 to 800x600 but didn't work.. from the moment i turn on the laptop even from the bios setup settings the screen also display only 4/5 of it the other 1/4 is still black. hope you guys can help me out with this. I already tried everything that i could do but mann this one is a tough one..please pleaseee help
  • Gateway Master
  • 16,820 Answers
Your pics are missing, try an external monitor,
Posted on Mar 03, 2017
  • 18 Answers
SOURCE: How to run recovery (located in D: drive) in Gateway Notebook Mseries 6816 laptop with Vista
Are you sure it not cause by virus? you can try online scan for virus. It might cause by virus that make system properly to work stable
Posted on Sep 26, 2008
SOURCE: My recovery CD (gateway 7330gz PC) are no working
I have the same problem with my Gateway 7330gz. My laptop got infected with spywares and it was so annoyed that I have to think about recover the system. So I did it with Gateway Recovery software. I chose the recovery option (press F11 when boot up)from hard drive since my dvd drive was broken. It went well but when it boots up again and Windows XP says detecting and installing the drivers and such, it was frozen haft way through. I turned off power many times to reboot but it kept freezing at that point. I search Internet for help and seen this post. Wonderful! I press F2 to go to BIOS setup screen, use right arrow key to move to Advance menu option. There I use down arrow key to select SpeedStep, hit (-) key to disable it. Then F10 to save and exit, hit enter for OK button. The system boots again but this time it was no longer freezing, the setup process went through ok and continues...I am so happy and type this message so it might help others with the same issue. Thanks
Posted on Nov 28, 2008
  • 192 Answers
SOURCE: Help me please - Gateway FPD2185W
Ok, I have some news on this that I know you will not like, but the whole point of this site is to try and help you fix the problem, or at least, try and point you in the right direction.
The news:
I have done some extensive searching on this problem over the last month, as I have also had a friend with a similar problem that you are describing. There is a manufacturer's fault on the main power board, this has been recognised by Gateway, but as it happens inconsistantly (it may happen after a few months or a few years), they are not prepared to recall the product.
Obviously this doesn't help us as consumers that buy their products. The blue screen that you describe happens with alot of visual hardware inc. graphics cards that affects the whole market, and has now become affectionately known as The Blue Screen Of Death (BSOD).
If you are one of the lucky one's, and it is still under the manufacturer's warranty, get it sent back asap, and ask for a replacement to a similar model. If not, the only thing you can do is get it repaired or get a new/2nd-hand one.
Like I said, I'm sorry this isn't the news you wanted, but I didn't think it was fair for you to hang on.
Posted on Dec 09, 2008
  • 415 Answers
SOURCE: Cannot boot Gateway MX6421 after Unmountable Volume Error screen
If you happen to have your COA #, just go to and reload windows.
Let me know if theis helps.
Thanks for thr rating.
Posted on Mar 22, 2009
  • 13433 Answers
SOURCE: Error 39, corrupt DVD/CD-Rom Drive
Heres the solution to that problem.
Posted on May 03, 2009
Laptop wont boot up, black screen, has power
You didn't post the Make, Model of Laptop or the OS you are using. I'll use a Win 7 solution. Boot the Laptop, open the Control Panel, select Power Options, set to High Performance, select Change Plan Settings, set SLEEP to Never, select Change Advanced Power settings, go through the settings , set SLEEP and Hibernate to Never, Power buttons and Lid to shut down. Always shut down and unplug your laptop when not in use to prevent damage from power surges and possible Fire hazard IF the battery malfunctions. A reboot every day will reset the computer.
Apr 21, 2013 | Computers & Internet
Living pure 4 in 1 broken switch
you can take out filter and inside unplug the 4 wires and directly connect black to black and white to white with electrical tape...make sure you tape it good-reassemble
Feb 28, 2013 | As Seen On TV Living Pure Pro Series...
My LTV-32w6 westinghouse powers on & has sound but displays black screen with very faint colored vertical lines. It shows like this for about 1min before it goes into standby mode & the blue power...
Depends on what is causing it...
Vertical bands of faint black are generally caused by filtering capacitors and can be found in the power supply or the 5 volt supply or even the Video processing is not an easy task to identify the source of Video hum bars.....we also call them Jailbars.
Another problem seen is faint black lines caused by the TV set being in 4:3 mode all the time....right at the edge of where the picture ends and the black pillars begin, we see a faint black line that never goes away and is normally seen with a full screen....
That is actually image retention, but it's caused by the crystals that create the picture becoming polarized or ionized over a very long period of time....and it's not easy to DE-Polarize them !
But there are some theories out on how to do that....
Certain people suggest running the TV overnight with an ALL-WHITE picture and some suggest an ALL BLACK PICTURE...and some suggest alternating between both !!
Now, a black picture is easy to make, you just deactivate the Video Mute (blue screen) and set it to an unused Video INPUT overnight....
About the only way to make a white screen is to use the USB port for pictures and take a very bright outdoor shot of a piece of white paper that hopefully is out of focus too....That would create an all-white picture that you can plug into your TV set overnight....
Now if you decide to try this, deactivate any displays on your TV set...all you do is press the display button until the Video and/or USB input numbers disappear....
Next day , set it back to normal TV and see if it's gone or if it's REDUCED....try it again if needed, or try the exact opposite if you see NO RESULTS....
Sep 20, 2012 | Westinghouse Televison & Video
What does "E" in the display area mean, toner empty? (We don't own a manual)
E means ERROR. If copies are totally black check to see if the lamp under the glass turns on & scans over your document. Odds are that the lamp is burned out and needs replacement.
Jul 23, 2012 | Sharp Z50 - Z88 Toner
Lg lucid screen went black
Remove your battery, and leave it out for a minute or so, put it all back together, and charge... it may look lie it isn't, but since this phone seems not to have an LED the navigation buttons are your only indicators of trouble(pure speculation).
Your battery is probably depleted. i found out the hard way that a Droid X won't charge it properly... hope this helps
Jun 24, 2012 | LG Lucid 4G MobiPhone - Black Verizon...
Full screen fluctuation in Acer Laptop.
Sound very much like your LCD inverter might be going luckily there pretty cheap and you should be able to find one on Ebay.
An LCD (liquid-crystal display) inverter is a component in laptop computers that supplies the power to provide a backlight to the monitor, enabling the user to view what's on the screen. This component is commonly the culprit when the monitor goes out and can be moderately simple to replace.
Feb 03, 2010 | Dell Inspiron 6400 Notebook
DSC W80 Black Display and Black Photos
I talked to sony assistance and they said nothing really helpful. They told me to try:
- Putting everything default again
- Taking out battery and holding down the power button for 30sec and putting back the battery,
None of these worked.
Dec 06, 2007 | Sony Cyber-Shot DSC-M1 Digital Camera
I had the same problem - not entirely sure about the causality but it seemed to work again after I took the memory card out and put it back in. Worth a try I guess.
Dec 01, 2007 | Cameras
Gateway MT6705 Notebook Logo
143 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
